  New Posts New Posts RSS Feed - Engine timing
Engine timing
DasBoot67 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DasBoot67 Quote  Post ReplyReply Direct Link To This Post Topic: Engine timing
    Posted: August-02-2023 at 6:14pm
What is the timing setting on a 289 mustang right hand rotation is it BTC or ATC and looking for the degrees
Status: Online
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: August-02-2023 at 10:52pm
It’s always btdc. But your balancer may or may not be marked correctly for your engine rotation. I recommend checking it before using the marks to set the timing.
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: August-03-2023 at 7:31am
You should probably give some info like the year of the engine, and who marinized it.
Let's say it was an Interceptor from 1968, you could look in the reference section and find a manual that'll have that info or click on the link below. The number in the manual would be for the original distributor setup
Why are you asking about BTDC  or ATDC?
Is it because you're checking the timing and it looks kinda backwards, in which case you probably have a balancer with LH markings like TRB mentioned, he has a boat with backwards markings, see the link below
