  New Posts New Posts RSS Feed - Never again, Again !
Post Options Post Options   Thanks (0) Thanks(0)   Quote wayoutthere Quote  Post ReplyReply Direct Link To This Post Posted: September-26-2024 at 4:12pm
I found some more silicone, and froggy's still missing, not too worried about him, all the voids are full of water.
Just a few minutes to cut out.
host image url
Post Options Post Options   Thanks (0) Thanks(0)   Quote wayoutthere Quote  Post ReplyReply Direct Link To This Post Posted: September-27-2024 at 3:04pm
7 households lost power at 1600 hrs yesterday because a certain neighbor behind me can't maintain their property. I have offered to use my truck tools time and money along with the access i have thru the yard to cut back clean up and remove the waste, all I ever hear is how rhe plants will get stressed.
So starting on monday i will begin forging a new relationship with code enforcement by stopping by the office 3 or 4 times a week to complain about it and several other mouthy nosey neighbors who have trees and sheds inside the pud&e and without permits.
No thanks by the way for 30 feet of gate on the north and 12 feet of gate on the south property to access the utilities by the power company, they were upset i wouldn't let them drive 26 thousand pound truck over the watermain concrete and lawn.
The boss did say thanks for runnin to dunkin at 0700 tho.
As i understand it the hurricane caused some serious damage over on the gulf side for which i am sorry to hear and the bs here in the 32905 in no way even comes close to what other people are dealing with this morning.
Also after a sleepless night worried about froggy, i am happy to say that while outside watching the power company and doing some clean up this morning froggy was found alive and well hanging out on the side of the house.
Post Options Post Options   Thanks (0) Thanks(0)   Quote wayoutthere Quote  Post ReplyReply Direct Link To This Post Posted: September-29-2024 at 5:03pm
You are all invited to come on down and pick up the NINE bags of waterlogged foam scraped out of the 96 nautique., and tell me it doesn't weigh over 500 pounds.
That of course does not include the portion of the airbox that is foam filled or the stringers that water ran out of when i drilled drain holes in them.
There are 8 more holes to drill and i'll try to film them so you can see how bad they are waterlogged.
Plan is simple, cut the stringer tops off. Block up the boat, square it up and water level it side to side so the stringers can be ground down even/level by 1 full inch.
Most likely refoam the stringers and cap with 2 layers of 1208 and pull a mold.
The wide portion will stay wide as that is were every one jumps in the boat.
The stringers then get cut out of the 96 and get fit into the 84, maybe have to narrow the width
(see blue tape)
whatever happens i will have a stringer mold that will fit the NWZ hulls and at the least will know how to modify them to fit in the 01 hulls.
The 96 stringers are 26 inches apart
The 84 stringers are 21 1/2 inches apart the tie ins between the inner and outer stringers may need to shortened to fit (see blue tape)
In either case neither boat WILL NOT have foam filled floors and both will be fiberglass srringers not filled with foam.
3/4 inch, 6 pound corecell wrapped in 2 layers of 1208 or 1708 will bring that 1 inch back up to final elevation in the 96. The 84 will get the same floor to it's proper elevation.
BUYER BEWARE these things are sponges. Pull an engine mount lag and a transom or floor screw and stick a q tip in it. take it to the scales.
There was no dry foam anywhere and the hole i drilled by the driver seat i thought was gonna pop the fuse or shock me, it poured out of the tie in stringer.
I'll photo and measure the truck as well as post miles and weight slips after the dump on wednesday. Monday i got lawn and power washing in the morning and titles in the afternoon tuesday i got an appointment at 1400 and will be elbows and ***************s until that time.
I got video of the foam way up under the open bow completely saturated and running out.
I can pick the tongue up now that's how bad. I'll post the vid if theres any doubters.
Post Options Post Options   Thanks (0) Thanks(0)   Quote wayoutthere Quote  Post ReplyReply Direct Link To This Post Posted: September-29-2024 at 5:49pm
On another note or two,
the last 3 days have been busy and i didn't find out until today how bad the hurricane was and how hard some states were hit and that there was loss of life.
Second, i wanna hear the constructive criticism or regular criticism concerning both rebuilds before either goes too far utilitarian and no puff. When i read slalom tractor i think 70's/80's range rovers before they went all poofy and started getting stuck on wet pavement.
Post Options Post Options   Thanks (0) Thanks(0)   Quote wayoutthere Quote  Post ReplyReply Direct Link To This Post Posted: September-30-2024 at 9:39am
Woke up at zero 4 was at the gates before they opened. Post dump 1 3/4 inches
free image hosting
Post Options Post Options   Thanks (0) Thanks(0)   Quote wayoutthere Quote  Post ReplyReply Direct Link To This Post Posted: September-30-2024 at 5:49pm
https://youtu.be/6Llg7NYAH1Q?si=rSVIPBnNmcopDKld
Post Options Post Options   Thanks (0) Thanks(0)   Quote wayoutthere Quote  Post ReplyReply Direct Link To This Post Posted: October-01-2024 at 1:27pm
Outboard stringers wet but not as bad as the rest of the boat, maybe 50 pounds from both.
Post Options Post Options   Thanks (0) Thanks(0)   Quote wayoutthere Quote  Post ReplyReply Direct Link To This Post Posted: October-01-2024 at 1:30pm
https://youtu.be/xmiB_I6yQYM?si=vc7csoR3ON-s6oOz
Post Options Post Options   Thanks (0) Thanks(0)   Quote wayoutthere Quote  Post ReplyReply Direct Link To This Post Posted: October-01-2024 at 1:43pm
Somebody asked about the 84 2001 battery/cooler hatches, said i'd measure it tuesday, here ya go and if anyone can point me to the source for this speedo part off the 96 snob i'd appreciate it.
The wood panels measure, 15 7/8 inches X 11 inches, they are 3/4 plywood, the trim lip is 1/4 inch and rhe radius is 3 1/4 inches
Post Options Post Options   Thanks (0) Thanks(0)   Quote wayoutthere Quote  Post ReplyReply Direct Link To This Post Posted: October-01-2024 at 1:44pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: October-01-2024 at 2:08pm
Those Airguide speedo pitots haven't been produced for quite a while now, but if you PM your address to the guy that your carburetor was donated to, he'll send you a couple of genuine replacements. (used but in good shape) Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote wayoutthere Quote  Post ReplyReply Direct Link To This Post Posted: October-02-2024 at 7:41pm
Keno, be sure to pass along my thanks to that guy.
And to finish that pm, your obviously 1 of those guys,
Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: October-03-2024 at 7:54am
Not much to add, but I do sympathize with your project. I can’t say that I’m surprised that the foam is wet, it seems inevitable- closed cell or not.
I find these pics of the composite structure fascinating, big thanks for sharing. I don’t recall anyone digging in quite so deep and thoroughly before (and documenting it). I’m sure I’ll think of more, but a few questions while you’re in there poking around:
How thick is the layup of the ICS? Is it different on the mains vs secondary structures?
I assume there are backing plates on the inside of the main stringers for the engine cradle to bolt to?
Whats the inside of the stringer system faces look like now that you’ve cut some of the tops off? Gel covered? I would have guessed they were laid up on a male mold.
Now that the foam is out, I assume the spray relief pockets are visible on the inside? I can’t really make them out in the pics.
GottaSki View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GottaSki Quote  Post ReplyReply Direct Link To This Post Posted: October-03-2024 at 8:10am
Great work man
WIsh i took the time to review this in detail sooner.
on the 96, have you considered blowing the foam out of the main stringers and leaving their structure mostly intact, aside from a few access holes?   I did not have foam in my rcb's stringers, they were hollow, but foam disintegrates with a stout power washer and turbo tip
River Rat to Mole
Post Options Post Options   Thanks (0) Thanks(0)   Quote wayoutthere Quote  Post ReplyReply Direct Link To This Post Posted: October-03-2024 at 3:08pm
TRBenj,
the only layer count +/- i can give at this point would be the hollowed out portion of the outer stringers and tie-ins, the wide parts and that would be (edit, 2-3 layers) of biax material, its not very strong because of the span, and not very consistent in that area.
The narrow portions forward and rear sections of the outboard stringers are strong, so are the engine stringers, i'll have a thickness once they are cut.
My guess is a male mold too but there is no gel inside or outside. All the stringers ars laid up in a biax material. In fact so is the hull and deck.
Engine stringers are modified with 1/4 inch aluminum and the engine cradle is lagged into the sides and down thru the top. Yep lagged, no thru bolts. Even lags on the transom for hardware that is covered by foam/floor.
Yes, the spray relief pockets and hullside reliefs are all visible and thus far the layup looks good.
Only problem is it looks like the stringers have a flange on the hull so it's a lap joint instead of a "L" or 90 degree bonded to the hull. That means foam could have squeezed in there like it did between the floor and top of the stringers. Have a better picture when all the foam is out and it'll photograph better too.
Gotta ski,
Yours might havexbeen the thread i was looking for about powerwashing the foam out, that was a great idea.
Right now i bought a 5 pack of sawzall blades, the trailer windshield etc should get mu money back but i can't relax at night unless i'm q tippin fiberglass dust outta my ears so we'll try and make something from this hull.
Another intact 01 or pre 01 boat is the ticket to completing the snob, no rush, 1 will pop up and be the hardware, interior and engine donor, the hull will be a bar and grill
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: October-09-2024 at 11:58am
I think Dan is getting wayoutofthere and heading north to Ohio right about now to avoid a meeting with Milton Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote wayoutthere Quote  Post ReplyReply Direct Link To This Post Posted: October-11-2024 at 12:46pm
I did get wayouttathere on tuesday. Took only documents, non replaceables and the don't let that stuff fall into the wrong hands items.
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: October-12-2024 at 8:11pm
I see the pitots escaped to Ohio with you. Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote wayoutthere Quote  Post ReplyReply Direct Link To This Post Posted: October-19-2024 at 8:57pm
Pitots are safe, made it back friday at 1300 hrs. We were extremely lucky.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: October-20-2024 at 9:35am
Not looking for layer count, just thickness… if that’s easier to grab.
Not following your comment on the “modified with aluminum”… perhaps a better description or pics would shed some light on how the boat was built?
Post Options Post Options   Thanks (0) Thanks(0)   Quote wayoutthere Quote  Post ReplyReply Direct Link To This Post Posted: October-20-2024 at 3:51pm
TRBenj,
I'll cut and get a thickness and photograph the locations. Give me a couple days.
When they laid up the stringers or afterwards a piece of 1/4 inch aluminum plate got boded to the inside of the stringers were the engine goes, maybe in the back too were the angle is lagged to the stringers for the rear hatch and tank support.
I'm moving not sure when so focus is on prep for travel and winterize, hence cut it open get the water out and service the bearings.
From the brochure
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: October-21-2024 at 8:11am
I’ve seen the brochure, just trying to see what it looked like in real life… if you get a chance to take some pics, would be interesting to see
Post Options Post Options   Thanks (0) Thanks(0)   Quote wayoutthere Quote  Post ReplyReply Direct Link To This Post Posted: October-21-2024 at 10:52am
I wont get a picture of the inside of the engine stringers until they are opened up, that could be next week or in 1 1/2 years as there is a bigger project gearing up and will kick off at the last second. Meanwhile here some thickness pictures and i'll fill in the blanks and show an idea later when i got some time
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: October-21-2024 at 1:14pm
All these pics are really neat to see, thanks for sharing. Looks like 3/16” ish on the mains and 3/32 - 1/8” on the floor and secondaries?
Post Options Post Options   Thanks (0) Thanks(0)   Quote wayoutthere Quote  Post ReplyReply Direct Link To This Post Posted: October-23-2024 at 9:35pm
Yep, pretty close to those thickness.
couple pictures of the rear were the gas tank can be seen, in the outlined area, the stringers have a flange that crosses all the way from the inboard stringer to the hull side. From the inside it looks like the hull would have a 1/2 inch step but it doesn't.
Another outlined picture of the out board stringer up fron has an elevation change.
That's were they put the floor pan.
My idea is to pull a mold of the stringers and also make a floor pan template/mold.
Think i got dealing with the hard parts of the stringers front and rear, the tough to get at or tough to get out sections so a diy'r could fix his waterlogged maloon special by keeping short sections of existing stringers intact (but clean out the wet foam) and cut in the 50% of stringers section that is easy to get to and easy to get out then tab in a floor pan to finish it off.
Boom, no foam filled rebuild it original waterlogged mess like the factory does.
Same for the 84 hull, well maybe not theres not a problem but theres a problem.
I'll start a seperate thread.
Meantime what your looking at is, aaggh who am i kidding who knows what it is, foam filled
block with a pvc pipe that starts up front by the bow eye behind a dam and dump into the airbox by the front of the stringers. It dumps all that water into the voids around the drivers seat and no doubt is what filled up the empty cavity under the driver se
Anyway, that chunk of foam up there under the bowrider i'd bet weighs 200 pounds.
It's gonna have to wait, crawling up there isn't topping the list and really the deck should come off.
I was in there pulling off 20 pounds of sound deadoning material from the hull sides, so i'll repeat it's a convertible, it's a ski boat, the whole point is to feel hear and smell everything that's going on. you sit next to v8 designed in the sixties. If you want nvh go buy a ***************ing bentley.
gif upload
Post Options Post Options   Thanks (0) Thanks(0)   Quote wayoutthere Quote  Post ReplyReply Direct Link To This Post Posted: November-06-2024 at 4:39pm
I flushed out the exhaust and with some plumbing caps/couplers installed and sealed off the muffler for winter storage and dipping the boat in to get it on the trailer straight which it does not do, i had to ratchet strap it into position while the boat was just floating.
yay! Something else needs fixed!
Also peeled off the decals and rubber non slip with plastic razor blades ( no damage)
Wow it hasn't been cleaned yet but what an improvement.
Since i'm ski nautiques biggest fan now when i transport it i can tell people its a mastercraft or somethng is why it's all waterlogged and had to get cut open
In the process of that one of the plastic hinges broke (screwdriver points to hinge) and need a replacement or do i just pick up stainless ? No gas shocky things will be going back in the boat at all ever, period.
New hubs tires and spares, extra hub parts etc etc too.
All cleaned repacked etc etc across both trailers, fingers crossed i won't have to call highway tire tow and robbery. Did i mention highway tire tow and robbery already, maybe i should read my own thread.
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: November-07-2024 at 7:28am
Well no you haven't, so I guess it's time to hear about highway tow and robbery Wink
And here's a link to one place where you can get the plastic hinge
and someplace else referenced in the link below to an old thread here on CCF
Post Options Post Options   Thanks (0) Thanks(0)   Quote wayoutthere Quote  Post ReplyReply Direct Link To This Post Posted: November-08-2024 at 8:48am
Flat tire on 40 E leaving lake havasu tri axel 30 foot scarab. It took hours and they clipped me.
It was in good shape but the heat and dry out there really takes it's toll.
Is what really happened.
The take care of the trailer lesson i learned 40 years ago so 2010 in havasu was unexpected.
Here in my part of florida we have family owned business ferguson's, .there motto is if we don't have it we're both in trouble. Counting the 2 ski boats in the yard now makes 7 trailers worth of parts from them over the last 10 years. Great guys, no pc in there i'll tell ya, like a corner bar in the 80's
Walk in buy some hubs some extra parts tell some jokes and the havasu flat tire memory get's embellished via their motto and my b.s.. " if you don't maintain your trailer with parts from fergusons, it's your fault when you have to call highway tire tow and robbery"
Hello highway tire tow and robbery how can we help you?
My trailer is busted on the highway 500 miles from home, they told me i needed a part but i didn't get it.
No problem sir how much was the part or service you chose not to do?
142 bucks.
Ok just add a zero to that 142, multiply by 3 and we'll be there in about 6 hours.
Is how i like to tell how it happened
Fixed into the right thread.
Because the windshields are 3 things :
1. no longer available
2. absolutely must haves
3. expensive.
I think it's a good idea to remove and affix them to the boat(s) floor or some ply for safe keeping, they haven't broke yet but why push it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote wayoutthere Quote  Post ReplyReply Direct Link To This Post Posted: November-14-2024 at 3:34pm
Level of difficulty 2 of 10, no fumes no burning skin. Works almost right away.
It didn't do much with the decals and did nothing to the pinstripes.
I used more than needed to keep it wet but still used less than 1/2 a 2 qt bucket.
Anybody have a product that removes pinstripes letters and decals i would appreciate it.
They fell off the snob, on the 01, they are like iron.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: November-14-2024 at 3:52pm
Eraser wheel
