  New Posts New Posts RSS Feed - ProTec Ignition Swap
 Rating: Topic Rating: 1 Votes, Average 5.00  Topic Search Topic Search  Topic Options Topic Options
wkebrdr View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wkebrdr Quote  Post ReplyReply Direct Link To This Post Posted: April-09-2024 at 11:56am
I searched around, but what spark plugs are you using since going to the DUI?
Bill
92 Ski
malcolm2 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote malcolm2 Quote  Post ReplyReply Direct Link To This Post Posted: April-09-2024 at 12:23pm
I will have to check.  I don't remember off-hand.  I will get back here and reply with that.
It has been quite a while, and I will say that this change was fan-dam-tastic.  No more hiccups, super quick starts.  ZERO ISSUES.
Post Options Post Options   Thanks (1) Thanks(1)   Quote Jonny Quest Quote  Post ReplyReply Direct Link To This Post Posted: April-09-2024 at 1:18pm
Autolite 764 or 104 plugs.  0.055 gap with the DUI.
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: April-09-2024 at 6:08pm
Since this is your first post, nobody knows whether your engine has the standard heads or gt40 heads.
So..........the bestest, most correctest answer is to use the same plugs that are in it now because there were different plugs depending on the heads used Wink
1993R View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1993R Quote  Post ReplyReply Direct Link To This Post Posted: June-29-2024 at 7:36pm
I just did this conversion on my 92 ski
Same boat as JPAss
Everything installed easy and my distributor is positioned just like the photos
TDC has been checked twice. Wires installed properly.
Only issue is motor and starter are turning but no fire to plug wires
Checked power to the HEI and it’s moves between 11 and 12 volts when cranking
Checked my grounds seem okay
Haven’t run new the power and ground wires to dash yet
DEI said it sounded like the unit needed to be grounded and offered a suggestion on how to test it
It didn’t change anything
Any suggestions ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: June-30-2024 at 1:36pm
Where are you checking power to the distributor? At the (+) terminal on the cap
Is the tach terminal hooked to the boat's gray tach wire? Nothing else hooked to the tach terminal
Silly question, but is the 3 wire plug from the distributor plugged into the cap firmly?
All 4 connections on the ignition module under the cap connected?
rosconole View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rosconole Quote  Post ReplyReply Direct Link To This Post Posted: June-30-2024 at 4:01pm
Just hold the wires together put your foot in a bucket of water and crank it. Let me know if you feel anything.
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: July-03-2024 at 11:23am
Originally posted by 1993R 1993R wrote:
I
You got this thing making noises like a running engine yet?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1993R Quote  Post ReplyReply Direct Link To This Post Posted: July-03-2024 at 1:44pm
Keno
I will be jumping in it tonight
Got tied up at work but have next 5 days off
You may have solved it via the tach wire
I don’t have it going directly to the HEI
Will route it properly and hopefully she fires up
It’s been pretty hot in FL so early morning late nights are only times to work on stuff and feel comfortable
Would like to get back to skiing again
Will keep you posted
Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: July-03-2024 at 7:22pm
Hope you get going in time for the long weekend Wink
The Red wire in the picture is the only one that needs to be hooked up.
The connection next to it is for the tach and if it's grounded, the coil won't spark.
It's normally hooked to nothing at all or to the tach wire that runs up to the dash.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1993R Quote  Post ReplyReply Direct Link To This Post Posted: January-06-2025 at 2:34pm
Update
Sorry for the long delay
My boat is up and running strong and starts like it’s brand new again
I did some extra work to get there
I did replace the starter solenoid and both push button fuses
I rewired everything in 10 ga including the tack wire and the power wire to the HEI
Removed all non essential wires from harnes
Refinished the old protect mount in black crinkle finish and loomed all the wires
Install looks clean and factory
Boat fired right up
Only two questions
1) the electrical connections had a black silicon applied at factory to help water proof
Anybody know if it’s a specific brand and type. I would like to reapply .
2) The timing is currently set at 10 BTC and 800 rpm. I want to adjust it .
From what I’m reading it should be 12 BTC at 600 rpm at idle correct ?
I plan on retiming the boat but will be sending the carb out for a complete refresh and want everything to be spot on
Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: January-07-2025 at 8:48am
I'd check the total advance at about 3500 RPM before doing anything, so you know what you have.
DUI likes to say that there's 24 degrees of advance at 3000 RPM the way it's shipped to you.
Add that 24 to 10 degrees of initial and you get 34.
It seems like numerous people around here get anywhere from 20 to 24 degrees added to their initial when they check, with a lot in the 22ish area.
34 plus or minus 2 would be a good total number to have depending on what octane gas you're using.
So setting it for whatever initial gives 34 total would be a good start.
You might be there now or have to advance it a little
600 ish RPM in gear sounds good for idle RPM
Not knowing what connections you want to cover in black goop, I guess I don't really see the need
I'd wait till the carburetor comes back before doing the timing and idle adjustments unless you just want to practice doing it Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote rosconole Quote  Post ReplyReply Direct Link To This Post Posted: January-07-2025 at 8:53am
40 degrees of timing ??? are you trying to sell an engine as well?? A GT 40 perhaps .
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: January-07-2025 at 9:17am
Umm, Roscoe, maybe you need to clean your glasses or go brush up on  your math skills or something.
