  New Posts New Posts RSS Feed - Starter solenoid PN
Starter solenoid PN
Feyer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Feyer Quote  Post ReplyReply Direct Link To This Post Posted: Today at 10:00am
Good morning and Happy Monday. Set the popcorn aside ( for a moment ) please.
Starter Relay is confirmed to be wired correctly. Ignition key switch is verified to be wired correctly. Alternator has all the connections right and tight as well as the starter. Boat starts but will not turn off. For some history, I am not the original owner of this vessel so I do not know what has taken place over the years with it's wiring nor repairs completed. That said, I did come across something of interest. Previously I found (2) wires going to the key ignition switch going to the "I" terminal - a Purple one and a Light Purple (Lavender maybe Pink?) one. I traced the Light Purple one back to the Safety Kill Switch located at throttle area.
Now, this Light Purple wire is GIVING me 12v from the kill switch side. Is this normal? Where is it coming from?  So, I disconnected it from the other Purple wire and my dash lights are now working as they should. That wire is still sitting live wrapped in tape under my dash. Where is that wire supposed to go? and Where is it getting it's power from? Hmmmm
I'm ordering (2) new Fuel Relays today per your previous advice - that might be a solution and will check a box to eliminate any question there.
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: Today at 5:39pm
Shouldn't have 12 volts and right now that's the million dollar question.
The jump start was not nice to something
That purple wire is back feeding the ignition switch and powering the dash so with it disconnected from the other wire, it would seem logical that the dash behaves normally
If I was curious, I'd pull the ECM relay and fuel pump relay and hook the battery up and see if anything changes while you're waiting on your new ones.
Maybe you'll hear "the sounds of silence" Wink
