  New Posts New Posts RSS Feed - Distributor
Distributor
tommer12 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tommer12 Quote  Post ReplyReply Direct Link To This Post Topic: Distributor
    Posted: February-16-2004 at 3:10am
I want to change my old school weighted distributor on my 1984 2001 Ford 351 Commander. The distributor is the original and I had to replace a spring in it last year... I know there is way to change it out, but how? I am fairly mechanical, just have nevered done it. What would I need or would I want to bring it to someone to do it?
tc
tryan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tryan Quote  Post ReplyReply Direct Link To This Post Posted: February-16-2004 at 12:31pm
set you motor to top dead center by the marks on the front cover and the harmonic balancer.
make sure the rotor points to the #1 cylinder.
note the position of the rotor with a felt tip on the old housing.
remove the bolt for the hold down clamp.
raise the old dizzy up about 1/4 inch and tap on the shaft with a screwdriver handle.
as you slide the housing up, note which direction the rotor turns and mark this with a different color felt tip.
pray the oil pump drive stays in place.
oil the o-ring on the new housing.
insert the new dizzy with the rotor poining to your second mark. it should align with your first mark when it seats.
you will have to re-time the motor, but it will start with this method.
Post Options Post Options   Thanks (0) Thanks(0)   Quote tommer12 Quote  Post ReplyReply Direct Link To This Post Posted: February-16-2004 at 2:42pm
before anything.... you are a great help here on the posting board.. What type of distributor would I buy to replace it? I know I have to use Marine grade, but I think I have to use some sort electronic?
SS-201 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SS-201 Quote  Post ReplyReply Direct Link To This Post Posted: February-16-2004 at 3:25pm
Msd sells a marine version , magnetic pickup. Pestolite sells one. HOWEVER you have to replace the distributor gear for opposite rotation. If you are in fact runing that way.
SS 201
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79nautique Quote  Post ReplyReply Direct Link To This Post Posted: February-17-2004 at 2:33pm
I have a rev rotation 351w 1979 model yr. I'm going with a mallory electronic dist Part # YLU554DV it cost $310 through jegs or summit. You can get a prestolite version through skidim for the same money. One comment though on tryan's install, The way it is described would apply for removing and installing the same distributor which would keep the timing fairly close and make it easy to start. But if you are replacing with a new Distributor your referance marks are on the old housing.
here's my two cents line up the marks and get #1 on TDC like tryan states mark the rotor position relative to the block watch the rotation of the rotator as you remove it and mark this location on the block as well. This will get the gears line up and not be out of wak relative to the cam and crank. since every housing is a little different and the amount of advance will be different from one to another you can try and make a mark on the old housing and the block and transfer this to the new housing using the key for the cap as a reference and line up these marks on the block and you should have the timing close when you start it for the first time. Worst come to worst you may have to rotate the base of the distributor to get it to fire to retime the engine. So if the starter is draging when you crank it and the engine won't start rotate the distributor slowly until the starter runs normally if it gets worst while turning it change directions. Once the engine fires and stays running use the timing light and set the correct timing and lock it down. If your lucky you won't have to move it to get it started just don't crank the starter for a long time if the inital timing is off let it rest and give it another shot. You should only have to rotate the distributor from say one o'clock to two o'clock not a quarter of a turn or so.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79nautique Quote  Post ReplyReply Direct Link To This Post Posted: February-17-2004 at 3:24pm
Tryan, since we're talking dizzy's the new one I'm getting is a three wire job with what I assume is a tach lead for the third wire. Currently the tach is ran off of the alternator (factory set-up) correct? Will it be a pain rewiring things to use the existing tach or should I get a new tach? I can verify the current one's accuracy (sp) when I install the new motor while it's at the shop but if it isn't reading correctly I have to do something to correct it. What's your two cents?
Post Options Post Options   Thanks (0) Thanks(0)   Quote SS-201 Quote  Post ReplyReply Direct Link To This Post Posted: February-17-2004 at 4:31pm
Be sure you specify reverse rotation, automotive is right hand, marine left, in order to have the correct cam drive gear. Only PCM I believe built reverse rotation motors for CC up to 1989 after that with the transmisson change they are Automotive, right hand, all others prior turned left hand auto or marine right rotation. Automotive is as you stand in front and marine is when you are behind the engine. Tach leads are usually green wire, Dist have a + and -, color coded. If you hook up wrong wire usually the timing will be retarded, so if you know your timing you can check, no biggie.
SS 201
Post Options Post Options   Thanks (0) Thanks(0)   Quote tryan Quote  Post ReplyReply Direct Link To This Post Posted: February-17-2004 at 6:24pm
hot (+) for the coil comes off the ballast resistor at the bell housing. the points or pickup grounds the negative side of the primary (low voltage) section of the coil. (99% of the time it's a green wire.)
an electronic pickup will require a seperate power source and a ground. the third wire being the signal for the coil. colors will vary by what type unit.
the tach is generaly pulled from the negative lead at the coil.
odd stuff....
they make/sell surge suppressors for the pick-up.
some require an electronic coil.
spiral and stainless wires are a no-no.
some pick-ups require low voltage (ie powered through your existing ballast or by adding a voltage reducing wire.)
don't leave the key on without the engine running.
a conversion will work without this crap, but it will live LONGER with these additional changes.
i run a unilite, but i keep a set of points and a small puller on the boat just in case. they came in handy once.
i dislike pertronix stuff. i would go msd or mallory. that's 3 cents worth.
i would cross reference your existing dizzy # before you order. swapping out the whole thing is the best deal.
i dropped a itsy-bitsy spring inside a dist. on a saab one time and lost it. that got real expensive before it was all over with.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SS-201 Quote  Post ReplyReply Direct Link To This Post Posted: February-17-2004 at 7:14pm
Crane makes a XR1 electronic with a adjustable revlimiter built in. Green wire are tach leads to wearever you are going to connect it to. All the distubitors have advance springs no matter what you buy. The newer ones have the springs so you can get at them without removeing the distributor. Crane make great products, when you change dist or electronic be sure your coil is acceptable to the converson. Also some require you don't use the resistor, read the directons good and resist the BS.
SS 201
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79nautique Quote  Post ReplyReply Direct Link To This Post Posted: February-17-2004 at 8:23pm
I don't want to mess around with a CD system like the XR1 or MSD's version which basicly replaces the coil and doesn't run without a triggering device i.e. dist., I have choose a ready to run direct replacement drop in and go distributor and hot coil set-up. My main question is where does the tach get it's signal from the alt. or the coil from the factory wiring. I know that it can be done from either source. Colors of wires are meaningless because on mine green goes to one of the sensors, and you have a pruple and gray wire going to the coils from the factory for my year boat.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SS-201 Quote  Post ReplyReply Direct Link To This Post Posted: February-17-2004 at 9:13pm
The XR1 ia drop in to replace the points, the wires I am familiar with as I am a Nautique owner. To answer your question the tach runs off the wire that is connected to the coil.It gets its pulses from the dist.The wires are purple, gray and brown. The tach wire that is hooked to the coil goes up to the tach and the tach is then grounded. The green wire I was refering to is from other units such as CD etc. Sorry about that.
SS 201
Post Options Post Options   Thanks (0) Thanks(0)   Quote tryan Quote  Post ReplyReply Direct Link To This Post Posted: February-17-2004 at 9:27pm
the pdf file for the 1980 shows a gray wire for the tach in the reference section. i have never run a tach off the alt'nator. my original hot feed to the coil was/is purple.
i had a cd on a old car and it was wired assbackwards from logic. the negative side of the coil was grounded to the body and the control box was triggered by the points to send a signal to the hot side of the coil.
edit.......if the gray wire was hooked up to the negative post on the coil, that is the tach feed.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SS-201 Quote  Post ReplyReply Direct Link To This Post Posted: February-17-2004 at 10:48pm
Why do you make this such a project whatever existing wires go exactly where they did before. The tach wire whatever color tied up to the coil is the tach wire which goes to the tach then the tach is grounded in the system. It get its signal from the dist, magnetic,points or whatever you use for a trigger system. Oh there were units that had boxes attached Sun units etc, but this is not the case.
SS 201
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79nautique Quote  Post ReplyReply Direct Link To This Post Posted: February-18-2004 at 10:28am
My concern is that I'm putting in a new HP engine and I need for the tach to read correctly to re-size the prop so that I do not over rev the engine. I can verify the tach's accuracy with the engine analizer at the shop when I replace the engine. So if the tach isn't correct I have to use an aftermarket tach and shell out a ton for an original replacement. The wiring diagrams I've look at are completely different than what I recall the way my tach is wired. The diagrams show two wires plus two for the light. My has a atleast for or five wires going to it so I'm a little concerned. Hopefully it will read correctly and I won't have to jake with anything I guess I will have to wait and see in a couple of weeks when the motor is finished and I install it.
SS 201 View Drop Down
Guest
Guest
Post Options Post Options   Thanks (0) Thanks(0)   Quote SS 201 Quote  Post ReplyReply Direct Link To This Post Posted: February-18-2004 at 1:08pm
I have two tachs on mine they both read differently at low RPM about 300. However at top end they read the same. One is the orignal and the other is the best money can buy, go figure. Follow the directions and you can,t go wrong, and that's the problem with electronic tachs. The real way to get an accurate reading is with a mechanical tach. That's what high power race boats use, I know this cause I did it for 30 years. Good luck you will be fine. If you know the prop formula you will be ok if would like to know it let me know, it saves a ton of time and money.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79nautique Quote  Post ReplyReply Direct Link To This Post Posted: February-18-2004 at 3:21pm
I could use the prop info? someone listed some info on skiboathelp.com and I was going to refer to it but you seem like a better source with your background in racing. I'm increasing the HP by 60 to 100 more ponies I won't know exactly how much until I get the dyno sheet in a week or so.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SS 201 Quote  Post ReplyReply Direct Link To This Post Posted: February-18-2004 at 6:40pm
What boat do you have now, model year? was the engine stock when you got it, is it 1.1 transmission> 351 or 302 CU? what prop do you have, what RPM do you turn now? What are you looking for RPM VS prop. How fast do yoi intend to go. What's realistic?
To go fast you have to turn at least 15 or 16 pitch props at 5500 6000 RPM. You have to figure the hull and prop slippage for effecieny, such as 10,20 % loss. How much HP per mile per hour, ex. 10, 15, 20 etc. What cam are you putting in, what are the duration specs? ex 2500- 2500, 3000- 6000, Remember torque is always the larger number up to 5250, after that the HP crosses and overcomes it. Just a few things that have to considered.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79nautique Quote  Post ReplyReply Direct Link To This Post Posted: February-18-2004 at 8:00pm
I have a 79 ski nautique 13 x 13 prop it ran about 4200-4400 rpm. The engine was a 351W rev rotation 240hp, 1:1 velvet drive all stock as far as I knew with the exception of electron ign conv from the points style dist. But that was the old junk which has a busted water jacket somewhere.
What I am replacing it with is a balanced 351W rev rot. with increased compression, modified cam, edlebrock performer aluminum intake, Mallory YLU554DV electronic distributor with a MSD high vibration blaster II coil and a holley carb which I will have to re-jet most likely. I the engine will be live run on a dyno as well. I will be recieving a print out from the dyno for torque, HP (300+ is what I was told) and max RPM, I can find out what the lift and duration of the cam is but currently do not know any specs put I will have all this info in the future.
What I was planning on doing is installing the engine running it for a little bit to break it in then finding the max RPM then replacing the prop to get it back to the recommended RPM. As far as top end speed the more the better with out loosing to much on the hole shot. I really wasn't worried about top speed more RPM. I didn't think I had a lot of choices on the RH prop's dia due to haul clearence don't need to guoge the haul you know.
Post Options Post Options   Thanks (0) Thanks(0)   Quote tryan Quote  Post ReplyReply Direct Link To This Post Posted: February-18-2004 at 8:16pm
i would get a pile of jets when shes hooked up to the dyno and get the preliminary jetting dialed in. if you have time before it's done, you might buy one of those adjustable metering blocks. if it's raining money, somebody might slip a 650 or 750 cfm double pumper under your pillow.
if you cam it, they will come.
(vacumme activated secondary 4160 might piss you off if the cam is big. putting a screw in the secondary linkage will give you a flat spot.)
power vavle is suppose to be 2 inches or so below minimum vac at wot. i would say you have a 7 or 7.5. i would pick up a 5 for the dyno run.
cfm is diplacement x rpm x volumeteric efficiency.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SS 201 Quote  Post ReplyReply Direct Link To This Post Posted: February-18-2004 at 9:01pm
I wonder they got the cam from, no one makes reverse rotation anymore, especially high performance. I would be interested where it came from.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79nautique Quote  Post ReplyReply Direct Link To This Post Posted: February-19-2004 at 10:39am
Jasper is doing the engine and I won't have access to the dyno. I think I can find out what carb and jetting they use when they run it. All class II engines are ran on the dyno and I will ask if the grind their own or buy the cam from someone.
From what I've read and talking with jasper they use the same intake and stock carb for that year engine when they run it. I'll call and get the lift and dur. and see what I can found out about the carb and jetting. I left the carb work to my dad so I'll have him dial it in when it's all said and done. He's an ASE MASTER TECH for gas and desiel so I think he might be able to help. I know for sure he can put a rochester together in is sleep. I was a smart ass when I was younger and on my first car we rebuilt the motor and carb got it running didn't have a four gas analizer at the time, het got one a month later made him hook my car up to it and we could not adjust the carb to improve upon what he already had it set. I quite questioning him after that.
Post Options Post Options   Thanks (0) Thanks(0)   Quote tryan Quote  Post ReplyReply Direct Link To This Post Posted: February-19-2004 at 12:37pm
back to tommers question. a conversion kit is more complicated, so the extra expence of a 'drop in' is worth it, especially on an aged unit.
the thrust is opposite even though it turns the same direction. 'special' always cost a little more.
79 your dash gauge will have 5 wires. signal, 12 volts(switched), ground and the two wires for the light.
your new dizzy should just have 3 wires. dropped voltage power, gound and the signal. the signal wire will feed the tach and the coil ground.
i believe my mondo alt has a terminal marked aux.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79nautique Quote  Post ReplyReply Direct Link To This Post Posted: February-19-2004 at 1:57pm
I guess I will have to read the instructions for the distributor for proper install.
SS-102 & tryan here are the engine specs 305-315HP, 5500 max RPM, custom grind from comp cams at .050" tappet lift
duration
218 int
224 exhaust
lift
.476 int
.481 exhaust
112 lobe seperation
needs a 650 cfm carb and I'll have to play with the jets.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SS 201 Quote  Post ReplyReply Direct Link To This Post Posted: February-19-2004 at 3:21pm
A 600 will be just fine, that's one step up from stock cam will be in the 2000 rpm to 4500 rpm torque range, howvever can rev higher.Good choice, I am assumeing you are useing 1.6 rockers.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79nautique Quote  Post ReplyReply Direct Link To This Post Posted: February-19-2004 at 4:16pm
I really don't know it a long block from Jasper engines and transmission. I would assume it is stock rocker arms.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SS 201 Quote  Post ReplyReply Direct Link To This Post Posted: February-19-2004 at 7:13pm
They are 1.6.1 stock, you will be fine.
reidp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote reidp Quote  Post ReplyReply Direct Link To This Post Posted: February-20-2004 at 11:39am
BC,
I've got most of the same modifications on a 302 engine including moderate head work. From test and trial on mine, I picked up +/- 700-800 rpm spinning the original 12x14 prop on a 16 footer with the engine enhancements. This increase was from 4400 to 51-5200 rpm. Testing with a higher pitch prop (12x15) lowered the rpm slightly and resulted in the practically the same top speed, but slowed slightly out of the hole. Since you were only turning 42-4400 max before, I'd be willing to bet that you'll receive your best performance all around with that same original prop, and probably ending up in the 5-5200 rpm range which definitely isn't too high considering those engine modifications. Keep us posted.
ReidP
1973 Mustang
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79nautique Quote  Post ReplyReply Direct Link To This Post Posted: February-20-2004 at 2:18pm
Checking with what props are avalible for a RH it looks like I could get 12x15 , 13x14, 13x17 14x14 or 14x16 beside the 13x13 I currently have. 12x15 or 13x14 would be most likely the best choices but I will have to wait and see. Once I get my baseline then I will need to know what effect changing the pitch and also diameter will have on RPM. I'm increasing the HP by 70hp from what I had so I think I will have to change props to compensate.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SS 201 Quote  Post ReplyReply Direct Link To This Post Posted: February-20-2004 at 4:25pm
So what speed ReidP does that boat run? 52X14 or 15
Post Options Post Options   Thanks (0) Thanks(0)   Quote tryan Quote  Post ReplyReply Direct Link To This Post Posted: February-20-2004 at 8:26pm
alright, i can't keep my mouth shut. it sounds like a screamer but that's the minimum on the lobe seperation for a wet exhaust. don't let any friends start it until it's dialed in and keep the flappers lined up flush with the end of the tail pipe.
holley sell a complete kit that is much cheaper than buying individal jets. if you run at different altitudes the kits are great. i would still get a double pumper though and start with 64's. unleaded doesn't make reading the plugs easy but the last couple threads might give you a reading.
i wanna ride
