Trailer Maintenance |
joelhern2
Newbie Joined: February-23-2006 Location: United States Status: Offline Points: 22 |
Posted: July-11-2007 at 3:55pm |
I pump my trailer hubs with grease when needed and especially before long trips. However, recently the grease slings itself all over the outside of the tires and wheels....whats this all about?
I know that Im not over greasing them, because I cut off the grease right when I see water emerge (just like the directions read). Any other routine maintenance advice for a 1991 trailer? Thanks in advance... |
bmiller
Senior Member Joined: June-05-2006 Location: United States Status: Offline Points: 234 |
Your grease seals on the back of the hub are bad.Also when you take the hub off,look at the axle for any groove marks on the shaft.This will also cause the grease seals not to mate properly to the axle,causing your grease slinging.Some bearing places will sell a sleave to put over the section of bad axle if you do have a groove in it.Really you should only have to put grease in your hub once a year as long as you have your bearing packed properly from the start.My advise is to replace the seals and repack the bearings properly.Your bubby bearings are spring loaded so once you replace the seals and pack the bearing,just add enough grease till the front of the bubby bearing bottoms out the front.Also make sure you use marine grade bearing grease.
87BFN owner
Grand Poobah Joined: August-25-2006 Location: Saline, MI Status: Offline Points: 2194 |
I use molloy grease seems to work better then regular hi-temp grease.
SkiBum
Gold Member Joined: November-17-2006 Location: United States Status: Offline Points: 587 |
Used to have the same problem. Replaced the seals in the back and repacked the bearings with that red colored grease. Now I just pump enough grease in to make the bearing buddy start to float. I have hose clamps on the rubber outer caps to help keep out water.
David F
Hose clamps on the rubber caps...I like it! Kind of gheto, but good idea. I tend to loose them most of all, so that might help them stay put. I suppose that out of balance hose clamp is too close to the center of the wheel to make any difference.
I like Bills idea that he only pumps enough to just start the sping loaded plunger to float. If you fill them then I think with the heat and pressure, is blows past the inside seal. I just washed off the splattered grease from the inside of the wheel on one side of my Atom trailer. It did it with less than 200 miles and that was with brand new spindles and hubs!!
David F
Well, it is not Bill's idea, but the correct way to do it. The instructions on new bearing buddies tell you to do it just that way. Just enough grease to unseat the spring loaded cap.
Darrel
Senior Member Joined: June-16-2004 Location: United States Status: Offline Points: 340 |
Back in the day when we lost a rubber cap we would cut a Coors Light can in half and duct tape it on. That was pretty ghetto. Disclaimer: it was not a Nautique, it was 73 Thunderbird Tri hull with a Johnson 135 OB. My brother and I installed a center pull pylon on it and painted "Nontique 2002" on the side.
BuffaloBFN
LMAO
JAG459
Groupie Joined: August-12-2005 Location: United States Status: Offline Points: 61 |
I agree with bmiller When I replace the seals on my trailer I installed the seal savers available from Bearing Buddie www.bearingbuddy.com. and I haven't had a problem since.
I took a look at the seal savers and will need to put some on my trailers. Looks like a nice upgrade on the seal plus has a O ring backup. Like I said, I had less than 200 miles on new spindles and seals when one of them started throwing grease. Of coarse the spindles are probably made in China and they have no idea of the RMS surface finish requirements for a seal and any tolerence you put on a print they ignore anyway!! David, While I was at the bearing buddy site I took a look at the greasing instructions. It's funny because under the frequently asked questions they tell you to compleatly fill them up but in the install section they tell you to put in enough grease to only float the spring loaded piston a 1/8" !! |
jdkenyon
Senior Member Joined: March-16-2007 Location: Twin Falls, ID Status: Offline Points: 111 |
When I replaced the seals on my trailer I took the old ones to a local bearing place and asked for a double lip seal. My dad swears by these and they definitely look much more substantial for holding up. They were a little more money but if it saves a mess of grease on the brakes I am all for it.
David F
Excellent point and reminder. Double lip seals are crucial with boat trailers. Standard seals are designed to keep the grease in, not the water out. Double lip seals do both. |
