Rudder wear |
phospher
Gold Member Joined: July-19-2007 Location: United States Status: Offline Points: 557 |
Posted: July-20-2007 at 3:26pm |
I'm wondering how much my rudder can be worn out before it should be replaced. The boat seems to drive just fine but when I inspect the rudder it looks like it's corroded near the top on the front and sides. The corosion looks like little craters all over. The boat is an 1982 American Skier. I'll probably replace the rudder next summer but I just wanted peoples advice. I'll post some pics later tonight.
There is no corrosion on the prop only the rudder. thanks gents, -phil |
phospher
Here's the pictures I was speaking of.
Also, do you think I need to wet sand to rid the oxidation or can I get by with a rubbing compound? Let me know what you think. Thanks! -phil |
phospher
sorry for the HUGE pictures.
The Lake
Platinum Member Joined: May-13-2005 Location: Lk Winnebago MO Status: Offline Points: 1157 |
Hey Phospher,
I'll jump in here without knowing anything at all; but it makes me wonder, has the boat been a salt water boat? Any damage to the rudder shaft, or around the rudder port inside or out? I guess if it were mine I'd look for a new one for no other reason than peace of mind. Good to have you on the site. Chuck |
Phospher, You haven't mentioned how old the boat is and if it has been in salt water. It looks like zincification to me. It is the process where the zinc in brass will eventually erode out of the base of copper. I have seen it in old brass marine hardware. Without the zinc, it becomes very brittle. It also appears that it has been aggravated by the prop wash / cavitation. Zinc in salt water will be eroded very quickly and the reason it is used as a sacraficial anode on metal hulls in salt waters.
Your gel coat picture is tough to tell if you will need to wet sand or not. Start with some HD compound and buff first and see what happens. I've seen some pretty bad gel just buffed out. When you post pictures, post them from top to bottom by using the "enter key between the pictures. When yo don't, they end up left to right and that makes the post wide. You can go back in to your own post and edit it. Oh, your rudder! I would take it to a prop shop and see if they can grind out most of the erosion but then keep a eye on it. Start looking for a new one because they will need to do a lot of grinding! |
The Dude
Platinum Member Joined: October-19-2004 Location: Houston Status: Offline Points: 1335 |
Phos, first of all, welcome here! It's a great place.
That's really something! You can do what Pete says and have it grinded, but man, you're going to want to replace that as soon as you can. I'm surprised at that, but an 82 is 25 yrs old now! Pete's right on it for the buffing. Give it a try with the rubbing compound first. It may come out nicely. Good luck! |
phospher
The boat is an 1982 American Skier. It has never been used in salt per the previous owner who lives in Wisconsin. There isn't any damage to the prop or drive shaft from what I can tell. The tranny is smooth as butter and there are no vibrations. The engine has 620hrs.
I'm sure this is the original rudder... Just got in from a LONG day on the boat. 9:0AM until 11:00PM. thanks, |
Phospher, Sorry I didn't catch that it was a 82 because I didn't scroll all the way to the right!! Was the boat on a lift or hanging in a boat house at the height were the rudder erosion would be at the waters surface? The wet and dry cycle will come in to play too. I really don't think it's the age because I see plenty of old boats and have never seen that amount of erosion on a rudder.
backfoot100
Phos, I'm surprised that you aren't having any steering issues like pulling to the right or left. I would be a little hesitant to start filing or grinding that. I have read (but I certainly don't know for sure) that grinding rudders can cause pretty significant drivability issues when not done right. I think there are rudders out there that are "tunable" but I haven't had any experience with them nor know anybody that has really played with them. It's kinda like tuning the fin on a slalom ski. Can make the ski perform completely different with very little movement. I agree with Pete that I've never seen erosion like that before. I would get that replaced.
Eddie |
phospher
weird. yeah, i'm not sure. i think it might have been kept on a boat lift at one point. i think i'll just replace. how much can i expect to pay for the rudder to be replaced and installed? perhaps i can handle the install myself. however, i am new to boats.
thanks fellas. -phil |
backfoot100
For you to do it, would be a couple hundred bucks I'm guessing maybe even less depending where you get the rudder from. If you're even the slightest bit mechanically inclined and have some pretty basic tools, you should be able to do that easy. For a shop to replace it I would think it would run into about 500-600 bucks or better.
Eddie |
phospher
thanks backfoot100. i am mechanically inclined a bit. i'll just have to search these forums for some "rudder replacement procedures"
i THINK it's like 4 screws, something like 3m marine adhesive sealant 5200?? and the part that connects to the steering cable right? Maybe some water proof grease in there somewhere? am i over simplifying this? |
phospher
actually, i just found this post:::
1. Get a six pack of beer and start drinking. What else matters? 2. Remove rear seat. 3. Remove rear panel. 4. Remove rear floor board (might require removal of doghouse. 5. Remove saftey wire at top of rudder post/tiller arm. 5a. Support rudder from below (do not let it drop). 6. Remove bolt from top of rudder post. 7. Loosen clamping bolt on tiller arm. 8. Lift tiller arm up off of rudder post. 9. Remove rudder from below. may require jacking boat off of trailer bunks so rudder clears prop gaurd, if so equiped. If replacing/removing rudder port, simply remove nuts from bilge side (4 ea.) and work rudder out from below...it will be stuck with sealant. If PO used 3M 5200, you can cuss him now and go get the twelve pack....you will need it. ------------------------------------------------ I don't think I need to remove the port? just drop the rudder out right? curious to see how that seals in there and how to put it back in so that it doesn't leak. -phil |
The Dude
go for it phos. I've had the rudder out on mine and I'm not a mechanic. You can do it!
phospher
so, i might as well post all my concerns on this thread....
i have been reading about crankcase pressure and dipsticks popping out. after being on the lake and then checking the oil afterwards my dipstick is always just popped out a tad bit. i've never seen any oil around the dipstick area so i don't think it's blowing oil. also, the oil always looks good and not milky. should i have concerns? when i say it pops up, it pop's up about a quarter inch, if that. it's a 351 commander. ps: i'm already addicted to this site. |
Have you got a working pcv valve connected to a vacuum port? Have you got a breather piped to your flame arrestor. If you have both of these devices and your pushing out the dip stick you might have a problem.
phospher
not sure about the pcv valve. i will have to check. where is that located? but i do have a breather piped to the flame arrestor.
behindpropeller
Looks like previous owner of boat hit something that made the prop eat the rudder.
phospher
maybe that's it....
hmm. |
That was a thought that I had as well but discounted it because if the prop blades were bent backwards then it would have chewed into the rudder at a lower point. It is definitly corrosion, erosion or electrolitic. We may never figure it out!! Beavers that like brass? Phil, Follow the post with the instructions. The brass piece that is bolted to the hull with the 4 bolts is the "port". It does not need to be removed from the boat to remove the rudder. I think you will be surprise at how easy a job it is. |
boat dr
Pete what kinda beaver eats brass?The guy does not say where the damage occured, but if them beavers up there eat rudders and props, this redneck ain't gonna jump into that water again.
Down here we have alligators,cotton mouths and all kinda critters that will bite or suck your blood,we even have a little critter that will bite and crawl thru a tent mesh screen, the are called NO SEE UM'S,for real. But we don't have nuttin' that will eat the balls off a brass monkey.......boat dr |
behindpropeller
If it pulled the shaft back it would have eaten the rudder with the prop. Why would it only be in that one place if it was corrosion? Had to be some kind of mechanical damage. |
GrandSlam
Groupie Joined: May-15-2006 Location: United States Status: Offline Points: 63 |
Phospher, it looks like electrolysis to me. I know some of the CC do not have a common bonding system. Also I do not see a zinc on your rudder. How is the zinc on your shaft? If it was me I would replace the rudder and try to determine the cause of the erosion. Good luck, Jerry
Jerry Troy
USCG Master, 100GT 1989 23' Fish Nautique 1992 47' Jersey SF |
phospher
shaft looks fine. no wear at all. the tranny was rebuilt a few years ago not sure if they replaced the shaft then too.
GrandSlam
Phosher, I am not asking about the condition of the shaft, I am asking about the condition of the zinc that is on the shaft. Do you have a sacrificial zinc on the shaft? We do on ours; the idea is that if there is any electrolysis the zinc will erode first before the shaft, prop or rudder. Jerry
Jerry Troy
backfoot100
Phos; The PCV valve is on one of the valve covers. It would have a hose attached to a vaccuum port off the base of the carb (at least that's where mine is coming from). If you pull it out of the valve cover and shake it, it should rattle. If it doesn't, replace it. I would assume that the engine is also an Indmar and not a PCM (you have said that it's a 351W but I don't recall if you said who the manufacturer is). Mine is an Indmar but its also a special production chevy engine. Not sure if American Skier used PCM motors or not. Don't confuse a breather on the flame arrestor for the fuel pump overflow tube either. The fuel pump overflow should be a clear plastic tube that runs from the fuel pump to the arrestor. Depending on the manufacturer, it may or may not have a breather on the arrestor. Hope this helps. |
Eddie |
phospher
got it. i'll check the pcv valve. i figured that it was the elbow piece attached via a gromet. the engine is a 351w ford commander marine.
phospher
How would I tell if there is sacrificial zinc on the shaft? thanks! |
behindpropeller
Those are more common in salt water, and for Aluminum, not brass/nibral. If corrosion was that bad on brass/nibral everybody would have problems with their props, rudders, and fins. I still think it is mechanical damage that has been smoothed out by the abrasive qualities of water over time. Why would you have corrosion in JUST that ONE spot??? Tim |
GrandSlam
Phospher and Tim, my boats have always had zincs on them, we boat on the bay (brackish water) and ocean (salt water), I wasn’t sure if electrolysis is specific to just salt water, isn’t an issue in fresh water? If you look closely at the pic of the rudder you will see erosion all along the back edge, maybe a prop shop can weld the rudder. Electrolysis will cause bronze to turn a reddish/orange color. The zinc clamps around the shaft between the stuffing box and the strut and is designed to erode in the event of electrolysis. A common cause of electrolysis is a battery charger. Have you had any prolong used of a battery charger? Jerry
Jerry Troy
