  New Posts New Posts RSS Feed - whining noise
  FAQ FAQ  Forum Search Search  Register Register  Login Login
whining noise
hyper1685 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote hyper1685 Quote  Post ReplyReply Direct Link To This Post Topic: whining noise
    Posted: April-12-2005 at 7:40pm
i have a whining noise coming from the boat usually when i turn, but not always when i trun. i ran aground the other day. had to replace the prop because of it. could it be the driveshaft? shaft bearings? trany? trans fluid is on the low side; could the low fluid be the problem?
Thanks,
Chris
mackwrench View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mackwrench Quote  Post ReplyReply Direct Link To This Post Posted: April-12-2005 at 8:26pm
yes
NO LONGER A MEMBER
kenny g View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kenny g Quote  Post ReplyReply Direct Link To This Post Posted: April-12-2005 at 8:40pm
did you have a woman on board ?
kenny g
Post Options Post Options   Thanks (0) Thanks(0)   Quote hyper1685 Quote  Post ReplyReply Direct Link To This Post Posted: April-12-2005 at 9:42pm
yes but she was making a different noise. anymore suggestions?
Post Options Post Options   Thanks (0) Thanks(0)   Quote kenny g Quote  Post ReplyReply Direct Link To This Post Posted: April-13-2005 at 11:27am
are you getting the same noise with the new prop ? it could be a cavitation noise in a hard turn.
kenny g
Post Options Post Options   Thanks (0) Thanks(0)   Quote hyper1685 Quote  Post ReplyReply Direct Link To This Post Posted: April-13-2005 at 3:30pm
yes the noise is there with the new prop. the prop is an ACME 540. i don't think the prop is the problem. let me know if im wrong
thanks,
chris
Post Options Post Options   Thanks (0) Thanks(0)   Quote hyper1685 Quote  Post ReplyReply Direct Link To This Post Posted: April-14-2005 at 6:11pm
anyone else have any suggestions?
Thanks,
Chris
