  New Posts New Posts RSS Feed - My 71 Skier Progress
67nautique312 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 67nautique312 Quote  Post ReplyReply Direct Link To This Post Posted: April-21-2008 at 5:04pm
Greg,
Looks great!!!!
Paul,
67 Riviera
68 barracuda
1971 Ski Nautique Promo
86 Silver Nautique
1995 Ski Nautique
skicat View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote skicat Quote  Post ReplyReply Direct Link To This Post Posted: April-19-2008 at 1:03pm
Tim,
My rope bar is round alum. tubing. I will have to look if it tilts back, but there is not much room between it & the stern light pole. I did have to work on the flat ends where it mounts to the boat since they were bent a little. I don't know if it is the original or not, but it looks it to me. No metal emblems for this one. They are pretty hard to come by. It had the plastic ones when I got it, so I just got some new ones from Whitelake.
Greg
86 BFN
p/allen View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote p/allen Quote  Post ReplyReply Direct Link To This Post Posted: April-19-2008 at 2:44am
My bar is half round flat stock .
Pat
My 72 Skier
Rock River
Dixon,ILL.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: April-19-2008 at 2:34am
Originally posted by p/allen p/allen wrote:
Tim , My boat didnt have metalemblems on the side . They were black with white letters . My rope bar is also tilted to the back .
Pat, good to know about the rope bar- thanks! I assume yours is tubular just like Skicat's? Mine is and I was worried it wasnt original- I remember our '68 being rounded flat stock.
If Im not mistaken, the metal emblems were used on at least some (if not all) '71's. Thats what we're putting on the yellow/red Skier eventually since I have a set. My green '72 has the white and black plastic emblems.
Post Options Post Options   Thanks (0) Thanks(0)   Quote p/allen Quote  Post ReplyReply Direct Link To This Post Posted: April-19-2008 at 2:23am
Pat
My 72 Skier
Rock River
Dixon,ILL.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: April-19-2008 at 1:52am
Greg, the boat looks great! I love the white scoops- I have the same look going on my green Skier (which Ive found is a '72). You dont have metal emblems to put on the side? Any plans for a white water line stripe? You gotta take those rubber flappers off!
Question- is your rope clearance bar (the triangle piece) stright up and down when viewed from the side? Mine has a backward cant to it- Im not sure if its supposed to be like that or if its bent.
MaddMarxx View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MaddMarxx Quote  Post ReplyReply Direct Link To This Post Posted: April-19-2008 at 12:49am
Yeah...That Boat is Red Hot, I think red and yellow are the two colors that stand out the best on the water...great job, skicat!
adamt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote adamt Quote  Post ReplyReply Direct Link To This Post Posted: April-19-2008 at 12:34am
WOW...that boat looks great...that red is really going to stand out in a crowd...I hope you're ready for A LOT of attention when you take that baby out in the lake...cause you're sure gonna get it...great job!!!
-Adam
1973 Skier
Post Options Post Options   Thanks (0) Thanks(0)   Quote MaddMarxx Quote  Post ReplyReply Direct Link To This Post Posted: April-18-2008 at 5:21pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote MaddMarxx Quote  Post ReplyReply Direct Link To This Post Posted: April-18-2008 at 5:19pm
I think this is the one, 79 was talking about!
kytom2 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kytom2 Quote  Post ReplyReply Direct Link To This Post Posted: April-18-2008 at 4:19pm
Looking good Cat!
Post Options Post Options   Thanks (0) Thanks(0)   Quote skicat Quote  Post ReplyReply Direct Link To This Post Posted: April-18-2008 at 1:21am
Here are a few updates on the skier. I hope to get it out of the garage this weekend & I can take some better pics then. Not much room with all the junk around it. The front scoop is a little crooked, but it is just sitting up there. It was still a little sticky with the fresh paint. I added the rear decals in hopes of getting some color to it. (I know Pete, not original like the white scoops) The scoops were in bad shape, so I had to rebuild them. I didn't figure I could match the red as well as just doing the white. There will be a lot of red when it is done. At least now it is putting stuff back on instead of tearing up. Maybe someday I will finish!
Trailer is not too long, boat is just moved forward. Makes it easier getting aroud the boat in the tight garage.
http://i79.photobucket.com/albums/j148/skicat1/IMG_4085.jpg">
Greg
86 BFN
Post Options Post Options   Thanks (0) Thanks(0)   Quote skicat Quote  Post ReplyReply Direct Link To This Post Posted: February-19-2008 at 12:51am
The stringers had some cloth added to them. As bad a job as it was, I think it might have been enough to keep off the water. The foam might have been removed at that time? Up under the bow it does have foam, but that is all. Not a lot of room for foam under the floor in these little boats so I am leaving it out.
Greg
86 BFN
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: February-18-2008 at 11:02am
Originally posted by skicat skicat wrote:
There was no foam when I took out the floor. It was all in pretty good shape, so I am going back the same way.
Thats surprising- any idea if the stringers had ever been redone? I thought CC put foam in all their boats starting in the mid-60's.
Sounds like you have a good plan- I cant wait to see the final results. Id go with white on the vents, by the way.
Post Options Post Options   Thanks (0) Thanks(0)   Quote skicat Quote  Post ReplyReply Direct Link To This Post Posted: February-18-2008 at 1:00am
There was no foam when I took out the floor. It was all in pretty good shape, so I am going back the same way. No foam & plywood floor coated with resin & glassed to the hull. As of now I am going with red carpet, White seats with red piping. The vents were red before, but I can't save them without repainting, so I am between red & white on those. Mine has the same steering wheel as the one in the picture, but I don't know where there would be one. If I see one, I will let you know.
Greg
86 BFN
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: February-18-2008 at 12:35am
Fill us in Greg- are you refoaming? What kind of floor?
I assume carpet will be going in- are you sticking with the red theme? How about the vents?
Off topic, but you dont happen to know where I can find a period-correct steering wheel like this one, do you?
Post Options Post Options   Thanks (0) Thanks(0)   Quote skicat Quote  Post ReplyReply Direct Link To This Post Posted: February-17-2008 at 11:35pm
Well finally getting around to some work on the skier. Here it is ready to put back together. Today I went to West marine & purchased new wiring, hoses, vent hose, etc to start putting it back together. TIP-don't make the mistake of taking your wife with you to buy this stuff. It adds up really fast & she knows how much you are actually spending on the boat! I didn't have to replace the stringers, but I did clean up the glass & reglass them over good. They are not up to Skibums standards for looks, but they should do the job. Still on a bilgekote high. Man that stuff is mighty strong!
Greg
86 BFN
KyTom View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KyTom Quote  Post ReplyReply Direct Link To This Post Posted: November-13-2006 at 3:48pm
Skicat - "Odd color, but looked great!"..It was in great shape but the color was something other than odd.
Wonder wher it is today?
KyTom
reidp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote reidp Quote  Post ReplyReply Direct Link To This Post Posted: November-13-2006 at 1:12pm
Greg,
If you come on up soon, we can take a ride, as otherwise I'll be winterizing before it freezes. The 63 Cla$$ic is still hanging, but several others are close by the ramp in the yard and easy to launch. If you can break away during the week I can sneak out, or come on up on a weekend. I'm not going anywhere the next few weeks. We can take a ride in a sweet running 273.
ReidP
1973 Mustang
Post Options Post Options   Thanks (0) Thanks(0)   Quote skicat Quote  Post ReplyReply Direct Link To This Post Posted: November-13-2006 at 11:44am
Thanks Reid- I had that site but I was not sure of the exact rail that was used. Your model # answered that. Yours is yellow & not the green color mine was. The pics in the diaries looked greener. Sorry you had to go the paint rout, but you are right sometimes you just have to give in. How many of yours are restored & in the water running? I need to run up 85 & check out your stables!
Greg
86 BFN
Post Options Post Options   Thanks (0) Thanks(0)   Quote reidp Quote  Post ReplyReply Direct Link To This Post Posted: November-13-2006 at 10:44am
Greg, I know what you're saying about the color. I thought it was a completely different color as well until we pulled off hdwe from the decks and esp the speedo mounting plate. It was as bright a yellow as you could imagine (see picts). Along the gunnel/top deck I was able to bring some of it back nicely but once I found there was no hope for the transom I pa$$ed and we decided to have it painted, plus it had lots of nicks and gouges.
As for the rub rail, try this site and page. http://www.tacomarine.com/cat--Aluminum-Rub-Rail--cat2_aluminum_rr.html
This is the exact replacement if you're looking for the anodized alum. The model you want is A11-0152. You can buy this thru West Marine, but you'll need to give them this part number as I don't think you'll find it in their catalog. It comes in 12' and 6' strips, and I think I normally used 3-12s and a 6, with about 3 feet left over. Or if you're gonna be up in Charlotte some time soon, I bought a bunch of it and can sell you some. It's a pain to try and ship.
ReidP
1973 Mustang
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: November-13-2006 at 8:53am
Skicat, I know the color you're talking about. I know of 2 1971 Skiers that are "pea" green, and youre right- its not far from mustard yellow. My guess is that Reid's familiar with that color too- this is an awful pic of one of those Skiers from NC.
Post Options Post Options   Thanks (0) Thanks(0)   Quote skicat Quote  Post ReplyReply Direct Link To This Post Posted: November-13-2006 at 7:43am
Reidp,
Are you sure that 71 is supposed to be yellow? I had a 71 that everyone called pee green. I have not seen very may of those, but yours looks just like it. I sold it to a friend of mine & he said yours was the same color. Odd color, but looked great!
Yes I do need the rub rail. Someone put a newer style on it. All I know about the original is it was the flat rounded face aluminum style. What size was it, did it have a small return on the bottom? Any help is appreciated!
Thanks for all of the other encouragement. Sometimes you need that to keep all of the projects going.
Greg
86 BFN
Post Options Post Options   Thanks (0) Thanks(0)   Quote Riley Quote  Post ReplyReply Direct Link To This Post Posted: November-12-2006 at 9:10pm
Nice job. That is a beautiful boat.
Post Options Post Options   Thanks (0) Thanks(0)   Quote reidp Quote  Post ReplyReply Direct Link To This Post Posted: November-12-2006 at 11:50am
Skicat's revived finish still has me reelin'. When completed it might be the hottest boat on this site.
I attach similar type photos of Marshall Morgan's 70 Mustang (see diaries), which when purchased, looked just like 'cats. We drove from NC to Mich after he bought it off ebay, and after he pursuaded the guy to pull it from auction by paying him 90% up front thru PayPal. Turns out the posted pict was about 10 yrs old and the boat had faded/oxidized terribly since. Well Marshall wanted to back out, but I reminded him he already paid the guy, and deal was a deal, although there was a little misrep here. So we explained to the guy that the picts really didn't reflect this deterioration; he agreed and settled on a lower price. I figured we might be able to bring the finish back a bit, and if not Marshall could sell it and recoup his money. "I" ended up doing the several days of sanding and heavy 3M compounding and it was like magic before my eyes. Once I started I couldn't stop. It was the nicest 36 year-old finish I'd ever seen perhaps until now.   So, Marshall got back to my place and wet his pants when he saw it. I left the port-side transom for him to do so he'd further appreciate the transformation. Guess who ended up doing it?
I've only seen a couple of old hulls that couldn't be brought back finish-wise. You can make any of them shine again, no question about it. But the original color may not come thru. On the old yellow 71 SN that I've partnered with a friend to restore, I sanded/compounded all the way thru the gelcoat in an inconspicuous area without getting the original bright yellow back. I've seen several other of those yellows that turned to a shiny Guldens. And then there's the question of whether it's not just cheaper and better looking just to paint them when they're really bad, and esp if there's body work to do.
Anyway, great job Skicat! I've got a source for the original style rub rail if you need it. <$200 total.
ReidP
1973 Mustang
Post Options Post Options   Thanks (0) Thanks(0)   Quote p/allen Quote  Post ReplyReply Direct Link To This Post Posted: November-02-2006 at 11:01pm
You guys finaly got it narrowed down . That is my 72 skier with a 220 conqerer crusader 302. The stripe on the side is still original it is actualy 2 in. vinyl tape . It does have the original wind shield. Kieth told me that it was the last boat style to use that kind of wind shield. These boats are bare bones made for the recreational skier. They dont have a speedo or horn and they also didnt come with carpet.
Thanks Pat
Pat
My 72 Skier
Rock River
Dixon,ILL.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hollywood Quote  Post ReplyReply Direct Link To This Post Posted: November-02-2006 at 9:02pm
That is Pat's boat, in the GL thread with the pics Brian's boat is labeled as "p/allen" which is wrong. Pat's is the "?" boat underneath.
Sidenote: Who was the blonde at the transom of Pat's boat in the above GL pic?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79nautique Quote  Post ReplyReply Direct Link To This Post Posted: November-02-2006 at 7:43pm
I think allen has it right it was pat's boat.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 67nautique312 Quote  Post ReplyReply Direct Link To This Post Posted: November-02-2006 at 4:26pm
skicat,
Many thanks again for the trailer!
it was lots of work but man it turned out good for me!!! I owe you big old buddy!
Man the old Ski is gonna be kick a$$ when your done!!! Keep the pics. comming
thanks again,
sorry i havent been on CC fan site much.....Very busy at work and home....
paul,
67 Riviera
68 barracuda
86 Silver Nautique
1995 Ski Nautique
Mojoman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mojoman Quote  Post ReplyReply Direct Link To This Post Posted: November-02-2006 at 12:16pm
LOL.. Gee Brian, I wonder who came up with that "Mayor" thing ??? Anyway, that's right you could have had all kinds of fun out there if the Vicodin(sp) wasn't in full tilt.. Or maybe that was just an act hahaha??? Anytime Brian, glad it worked ou the way it did !!.. in 07' (when you return to GL) you'll be driv'n my SN, or wake boarding behind it??.....
Moj'
