  New Posts New Posts RSS Feed - Dewinterize Check-List
 Post Reply Post Reply Page   123>
jackkloepfer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jackkloepfer Quote  Post ReplyReply Direct Link To This Post Topic: Dewinterize Check-List
    Posted: March-09-2010 at 3:24pm
I'm getting ready to prep my boat for the spring, and I was hoping some of you might share a list of the things/checks you do when dewinterizing. Still a bit of a CC newby here, so any help would be greatly appreciated!
Thanks, this is an awesome site!
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: March-09-2010 at 3:35pm
I clean up the battery terminals, hook it up, start the engine and make sure I have oil pressure and cooling water. This of course is if all the drain plugs and hoses were reconnected after winterizing!
Post Options Post Options   Thanks (0) Thanks(0)   Quote jackkloepfer Quote  Post ReplyReply Direct Link To This Post Posted: March-09-2010 at 3:48pm
do you do an oil change even if you're still below 50 hrs from last season?
what about V-drive oil?
Status: Online
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: March-09-2010 at 4:06pm
Oil (both engine and transmission- probably v-drive too) should be changed in the fall, regardless of engine hours. You dont want it sitting in your engine all winter with acidic byproducts. Probably too late now, but worth thinking about for next year! For this year, yes, Id change it before the season.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jackkloepfer Quote  Post ReplyReply Direct Link To This Post Posted: March-09-2010 at 4:10pm
Also, and I'm embarassed to admit it, I did NOT pull the plugs before winterization. I was under the impression that I simply had to run an antifreeze/water mix into the engine.
Should I be concerned?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: March-09-2010 at 4:17pm
Yes, you should be concerned but also what part of the country are you in? How cold did it get and for how long? Was it stored inside?
Hopefully you'll be good. Next year plan on a drain and fill with antifreeze. There's some great threads on the process. It's pretty simple. We do not recommend the "pump through" method. Too big of a chance you won't get all the areas of the block protected properly.
You said you used a water/anti freeze mix. What was it and what type?
Post Options Post Options   Thanks (0) Thanks(0)   Quote jackkloepfer Quote  Post ReplyReply Direct Link To This Post Posted: March-09-2010 at 4:35pm
Brainard,
It did hit some pretty cold temps here over the winter. I'm out of Indianapolis, and the boat was kept with the cover on, and wrapped in a tarp outside.
I did 50/50 water and antifreeze. I'm not sure what type it was, but I asked around for what to look for, and autozone pointed me to some. It was red in color, if that helps.
skicat2001 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote skicat2001 Quote  Post ReplyReply Direct Link To This Post Posted: March-09-2010 at 4:37pm
Yea I be worried, if you did not pull them plugs.. You could have cracked the block, or manifolds.. Hell, if I dont winter my boat in Houston, I get worried.. We got global warming going on down here!!
1985 CC 2001-SOLD
Lee Michael Johnson
Post Options Post Options   Thanks (0) Thanks(0)   Quote skicat2001 Quote  Post ReplyReply Direct Link To This Post Posted: March-09-2010 at 4:40pm
Matter of fact, do you guys like the drop light in the canopy.. I dont! What if you a breaker blow or something?
1985 CC 2001-SOLD
Lee Michael Johnson
tullfooter View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tullfooter Quote  Post ReplyReply Direct Link To This Post Posted: March-09-2010 at 4:45pm
Not to be a "glass half empty" guy, but you might want to start praying.
There are many threads about the winterizing process. I won't give my opinion, but even with a pure antifreeze going into the engine, there is still the chance of having an issue. Hopefully you ran about 40 gallons of the 50/50 mix through, and the antifreeze that you mixed with water was a gel consistency.
Then again, with a little luck, and clean living, you might be OK.
Play hard, life's not a trial run.
'85 BFN
'90 BFN
White Lake, Michigan
Post Options Post Options   Thanks (0) Thanks(0)   Quote jackkloepfer Quote  Post ReplyReply Direct Link To This Post Posted: March-09-2010 at 4:47pm
(gulp)
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: March-09-2010 at 4:49pm
Brainard,
The first mistake you made was going into Autozone and asking them what to use!! They don't even know anything about cars/trucks let alone boat winterizing!! Did the instructions on the container tell you to mix it with 50% water? Was it red or a pink color? The red color does tell me it was a propylene glycol (RV-non toxic) which is proper for not killing anything in your neighborhood or lake when it comes out. Red and mixing with water may be of IF the container stated to do it. Pink means no water and you need to be REALLY concerned. It needs to be used full strength.
Keep your fingers crossed and a close eye on the engine when you start it up. Monitor the oil for signs of water.
79nautique View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79nautique Quote  Post ReplyReply Direct Link To This Post Posted: March-09-2010 at 5:01pm
what part of town are you on? I work over at Rolls by the airport.
First thing I would look at is the oil's dip stick if you see any of the red stuff or a chocolate milk shake or signs of water. If there are signs of water in the oil there's no need to go any further untill you fix the block that's cracked.
Are you new to boating or just CC? I would be willing to lend a hand and walk you through it the first time and see if you got lucky or not using the watered down RV stuff if you would like the help, free of charge too just let me know and we can arange a time and place to meet.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jackkloepfer Quote  Post ReplyReply Direct Link To This Post Posted: March-09-2010 at 5:35pm
79, I will check the dipstick tonight.
Your offer to meet up is really, really generous. I might take you up on it. How would you like me to follow up? you can email me at jackkloepfer2@hotmail.com or I can contact you.
Thanks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jackkloepfer Quote  Post ReplyReply Direct Link To This Post Posted: March-09-2010 at 10:31pm
Just checked the oil (twice). Everything looks normal. Charging the battery now, here's hoping.
Randy_in_Ohio View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Randy_in_Ohio Quote  Post ReplyReply Direct Link To This Post Posted: March-10-2010 at 12:20am
So was the antifreeze the RV/marine stuff or auto antifreeze? I hope you are OK.
I don't know if you would notice the water in the oil on the dipstick if there was only a small amount of water wouldn't the water sit on the bottom of the pan and the oil would sit on top?
I say this because I remember when I got my boat and I had water in the transmission from the PO leaving it in the water I didn't notice it on the dipstick until after I had run it, then it looked like a strawberry milkshake but before I ran it, it looked fine.
Welcome aboard. Stick around, you will learn a lot.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jackkloepfer Quote  Post ReplyReply Direct Link To This Post Posted: March-10-2010 at 1:02am
god, honestly, It's been so long I don't remember. I just recall asking my dealer what to look for, and relaying the info to the guy at autozone, and him giving me the red stuff.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Randy_in_Ohio Quote  Post ReplyReply Direct Link To This Post Posted: March-10-2010 at 1:22am
Relying on the guy at Autozone was your first mistake!
Was it in a round jug or one of those rectangular jugs???
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: March-10-2010 at 9:29am
Randy's correct on this one. I just double checked by looking at the SG of lubricating oil. It's .90 so it will sit on top of the water.
Running the engine is the next step!!
Don't forget the trans oil cooler. It's out in the open and will get cold quick. You'll want to do the same check looking for water in it's oil too.
eric lavine View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote eric lavine Quote  Post ReplyReply Direct Link To This Post Posted: March-10-2010 at 9:58am
im partners on some BBC stuff,exhaust manifolds, blocks and to the likes and my other partner on these keeps pressuring me to sell on e-bay. I keep telling him im holding off because you have to wait until boat owners pull thier covers back and notice all the cracks from not winterizing, I know i at least do 3 a year on average (engine swaps)
one side note, drain and catch your GREEN anti-freeze before you head to the lake
quinner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote quinner Quote  Post ReplyReply Direct Link To This Post Posted: March-10-2010 at 10:41am
Jack,
I would be more concerned about Chris coming over to my house then a cracked block, LOL. Kidding of course, definitely take him up on his offer, he is a good guy.
Don't panic yet, although I now drain and would recommend the drain first method, for many years I winterized using the suck thru/no drain method, did use real anti-freeze and ran until I saw green coming out the exhaust, never had a problem.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79nautique Quote  Post ReplyReply Direct Link To This Post Posted: March-10-2010 at 11:58am
You have mail,
But Randy makes a good point oil sitting on top of the water another possibility is that the crack hasn't opened up to allow the water to get to the oil and is just waiting for some heat to expand the crack and then let the water mix with the oil so you'll want to keep a close eye on the oil and check it as it's running for any signs of water.
You don't want to damage the bearings you might get lucky even if it is cracked if the crack is in the intake or head, then it's just a top end rebuild and the rest of the parts will be fine provided they don't get damaged.
storm34 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote storm34 Quote  Post ReplyReply Direct Link To This Post Posted: March-10-2010 at 2:12pm
damn, reading this thread is like watchin a horror film.
I have some of the pink stuff in my Ski Tique this fall and ended up running it out and pouring in green. I caught all the pink stuff and let it sit in a bucket all winter and sure enough...it froze. It wasn't solid, more like a strawberry Icee. But I'm still glad I got all that out!
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: March-10-2010 at 2:35pm
Chris,
Did you drain and then put the RV pink in? Asking to determine if it was watered down when you purged the pink out. The pink will freeze but not solid to the point of breaking anything. Full strength the stuff is fine.
I switched years ago to the non toxic RV because my boats are stored in the boat house. It's difficult to catch all of the antifreeze so the change was made so I wouldn't be accused of killing any fish!
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79nautique Quote  Post ReplyReply Direct Link To This Post Posted: March-10-2010 at 3:23pm
Chris,
you really should read the fine print on the back of the pink stuff, I would never use the pink stuff unless the boat was garage kept as you saw it does freeze and Pete in your area at the lake I bet it's solid and not a slushy if left outside.
Use the purple or green non-toxic anti-freeze from west marine or boaters world much better and twice the freeze protection.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: March-10-2010 at 3:57pm
Chris, I do read the fine print! BTW, -50 degree does come in the pink color too!! I use the same stuff when I drain and winterize my house. I've always used it due to the septic system. I buy several gals, keep it outside in the "instant" vinyl garage with the door wide open until I'm ready to use it. There have been some overnight temps of -20 and out of curiosity I have checked it. Guess what, it doesn't freeze solid!!! You need to get out of Indiana and visit the northwoods sometime!!!
Okie Boarder View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Okie Boarder Quote  Post ReplyReply Direct Link To This Post Posted: March-10-2010 at 3:57pm
I sure hope everything turns out ok. I had drained my boat as good as possible before I pulled the engine. Then I poured the RV antifreeze, full strength in all the areas I could get it. It's been sitting on the crate, wrapped in a light blanket, in the garage since then. I don't recall the garage getting below freezing this year, so should be fine. But, you always wonder, you know?
WakeSlayer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WakeSlayer Quote  Post ReplyReply Direct Link To This Post Posted: March-10-2010 at 4:13pm
I used the -80 stuff the last winter. It is stupid expensive, but probably worth the extra sleep you get. I used the pink stuff this year and feel comfortable as we only hit -20 a couple times as Pete stated. Always drain first. Always.
Of course, if you have the special -100* stuff...... wait. Never mind.
Mike N
1968 Mustang
Air206 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Air206 Quote  Post ReplyReply Direct Link To This Post Posted: March-10-2010 at 4:21pm
In my job, I have seen too many animals killed by Anti-freeze. Use the non-toxic stuff !!!! especially around the water......... it has gotten much better since it first was released years ago.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79nautique Quote  Post ReplyReply Direct Link To This Post Posted: March-10-2010 at 4:28pm
Pete the pink stuff that is availible around here might be a little different maybe not but I was looking at the burst temps ratings mainly and after reading it I decided I didn't want to take the chance but it was no where near -50F rating.
