Electric Ski Boat |
Post Reply | Page <123 |
eric lavine
Pete, would nuclear reaction be considered green? a golfball size piece powers a nuc sub for 6 months
TX Foilhead
Sail boat, that would be green. I don't think you can make a trulry green boat, just one that uses less fuel, and even that would be quite a challenge. I wonder what plugging in these cars and boats does to your electric bill, nobody ever says much about that part.
C-Bass
Platinum Member Joined: November-18-2008 Location: Columbus, IN Status: Offline Points: 1248 |
Pete hits the nail on the head here. The electric used to power the motors (typical motor = 90% efficient) comes from the batteries. The batteries get their juice from a power plant (typical = 33% efficient) or the onboard internal combustion engine (typical = 25-30%) powering a generator (typical = 95%.)
Quick and dirty efficiency here... if you're using the juice from the grid to charge the batteries, to then power the motors & turn the prop, you're at around 29% efficiency. Say you run it out of juice, and need to use the onboard engine to get a charge...so now you're at 25% efficiency. How is that any better than using just the regular old engine in the first place(25-30% efficient)??? Robbing Peter to pay Paul, and calling it green....I don't think so. I'm with J-Bear...I wanna hear the V8 make some noise, especially when it's not affecting the environment any more than a "green" engine. ***This is not to say that there will not be a greener solution in the future. |
79nautique
If the APU (Auxilery Power Unit) was gas then you might be in the efficency range you state but the APU's are typically high effeciency Diesel units. Using a gas ICE as the APU is not very common and gennerally frowned upon in the industry. We used a three cylinder Diesel APU in the Class 6 Hybrid Buses running in NYC, a singal or twin cylinder diesel APU is all would be needed to run the motors in a car or boat application. Also Regen braking doesn't really add much to the range in a car's application either, might get you another 5 minutues of run time over the course of packs charge. Typically the APU doesn't charge the battery pack but feeds the motors and does little charging of the pack and while under heavy load in electric mode the APU kicks in to add more Current to the system. Most applications the pack is used to get the vehicle started and the APU is turned off when not in motion, like at a stop sign, you start from a dead stop on 100% of the pack then the APU fires and drives the motors, less polution is the end result. |
C-Bass
Good point Chris, the APU's definitely are more efficient ICE's than a normal 351w or similar.
On that same subject, there is definitely some grid power that is produced above the 33% efficient I used, but I was just aiming for an typical fossil fuel powered plant. There definitely are some neat things going on in the alternative power industries. |
FUN-9C1
Senior Member Joined: January-29-2004 Location: Lakes Region NH Status: Offline Points: 206 |
LOL!! My sentiments exactly! I've never bothered to put a radio in mine because I have yet to hear a song that I like better than the unmuffled sound of my 351. In fact, as I'm typing this, I've got the headphones on listenting to a recording I made of my SN running in the driveway the other day. :) (in case you're wondering, no, I'm not joking) Enjoy it while you can. It ain't gonna last forever. |
'86 2001
'50 Century Imperial Sportsman |
horkn
The gas generator would work like the generator on the soon to be released chevy volt.
That little generator motor burns a lot less gas than the 5.8 liter v8. Now as to my grid energy, we got rid of coal power a long time ago. I am a lot closer to Milwaukee than Green Bay. Like 15 minutes north of Milwaukee close;) Actually we pull electricity from Port Washington, like 8 minutes away. That Port Washington facility went from coal to natural gas in like 2004. |
Tom, It is quite obvious you have absolutely no idea how a hybrid on the road works. So, no electricity in the house up north. Very quaint. You like "roughing" it!! |
eric lavine
www.frauscherboats.com www.boesch-boats.ch www. colomboboats.com
www.superioryachts.com www.felleryachting.com www.farmontyachts.com www.aequusboats.com www.finelineryyachting.com www.scalaryyachten.de www.gasti-boote.de |
eric lavine
better wake up, cruising at cruise speed, 5 hours then charge
hydrogen over electric, not much trade off, but finding the hydrogen is the problem |
81nautique
Grand Poobah Joined: September-03-2005 Location: Big Rock, Il Status: Offline Points: 5779 |
Quite honestly I could care less what I drive so bring on the hybrids or whatever else there is to relieve the oil dependency BUT you're not taking away my american v-8 dino juice burning noise maker. You can't stop progress so let them make whatever fits the purpose but you'll definately hear me coming. |
JoeinNY
Yeah the gas burners sound good, but I am young yet and I can adapt.
Some day I will be able the tell the difference in sound between the mushy clicky brushless dc electric motors in the stock boats and the high intensity whine of of the inverter driven internal permanent magnet synchronous motors in those that have been hot-rodded. The guys who are real good can tell you if those internal magnets have been staggered or not.. Seriously someday we will be talking about overclocking the processor in your inverter so you get a quicker throttle response, or how far we can safely laser cut a stator stack to get in a bigger neodymium magnet to increase bottom end torque. Sure it might take a hundred years but with advances in medical science we might live to see it. Right now it is is expensive but there are some fun things going on with electric motors, efficienies in the low to mid 90's are out there now in mass production.. |
81nautique
ha, I'm old and cranky so I limit my adaptabilty to daily transportation not my toys! |
79nautique
Well we rulled out the syn type rotors in the AC induction motors has not being a viable option to use in a Hybrid, Not sure any one uses magnets or DC motors in an electric or Hybrid application either all of our products where A/C 3 phase motors running off of an inverter. The Copper bar and endrings for the rotor was the hot ticket but costly when comparing it to a cast aluminum rotor set-up. |
bkhallpass
My $.02.
Right now it is not really about efficiency. It's about long term renewable and clean energy. Use those terms and be labeled "liberal," "treehugger," or "environmental wacko." Not the way to win votes if you are a politician, and not the way to make money if you are in the business. Particularly not when people are struggling to pay for things as they already exist. As Joe said, eventually the efficiencies will be there, but those with vested interests must find a way to sell ideas and make money in the short term. Short term for politicians, and those in business to make money, it's about what it takes to sell the ideas and products. Whether true or false, electrics and hybrids are labeled in the manner that sells. A 50 mpg Prius is labeled as fuel efficient, and economical, whether the actual numbers are there or not. They talk about "green" and "saving the earth," but these are arguments which don't appeal to the masses. I think you see much more marketing emphasis on creating jobs in a new marketplace, and on saving money, which, again, true or false, are the messages which people want to hear. BKH |
Livin' the Dream
horkn
Oh come on, Pete.
That's a big assumption you are making. Maybe you should read more about the volt and how it works:) Ok, yes, I have electricity at the cottage. But we get most, if not all the electricity up there from the hydro electric dams on the Wisconsin river. |
eric lavine
i would bet my life in the early years, 1900 ish, there were the steam engines and the the masses having discussions of....how could that petrol burning thing ever replace a steam engine??? its not possible.
there were guys that said it was impossible to fly... |
