  New Posts New Posts RSS Feed - 79 Nautique rebuild?
 Post Reply Post Reply Page    <1 456
79TiqueRebuild View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79TiqueRebuild Quote  Post ReplyReply Direct Link To This Post Posted: April-20-2011 at 1:37am
Originally posted by WOFTAM WOFTAM wrote:
Hey Monty-
Thanks for the reply. Do you have any pics of the layout of the plywood in the boat. I am really leaning to the plywood instead of the glass, but do plan on re-foaming. I am specifically interested to see how you tabbed the ply in and how you did the port and starboard aft sides .
Thanks again. I started laying biax last night over the primaries and around the secondaries tonight.
Mike Glad to hear you are coming along on your stringers That biax can be trying to form on on the corners and rise and dips.
I used large cardboard (like appliance boxes) to make templates for the floor. They also work well to put down after you carpet to protect it while reinstalling your engine. Anyway after fitting floor pieces I glassed the pieces both sides with mat and wrapped the edges with tape. Epoxied down then double taped 2-2", 2-4" 1-6" on all seams and edges. One thing I also did is stopped the floor approx 6" from the transom in case I ever need to thou bolt the swim platform. Here are some pictures Hope this helps. Monty
Roger Thanks I hope to finish this stereo install and get that new dizzy in and finsi up the the shake down runs and get a picture or two.
Okie Boarder View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Okie Boarder Quote  Post ReplyReply Direct Link To This Post Posted: April-20-2011 at 3:48pm
WOFTAM,
Got your email but I can't reply since you don't have one set up in your profile. Send me another one with your email address in the body of the message and I can work with getting you some pictures and information you asked about.
WOFTAM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WOFTAM Quote  Post ReplyReply Direct Link To This Post Posted: April-22-2011 at 12:25am
Thanks Monty-
Those pics were just what I was looking for. 1 Question:What is in between the primaries and secondaries? It looks like foam capped with plywood. What does it do?
Just because you can does not mean you should.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79TiqueRebuild Quote  Post ReplyReply Direct Link To This Post Posted: April-22-2011 at 12:51am
That was an area i struggled with. My boat had what appeared to be two stringer jobs previously. I just kind of winged it for that area by the front motor mounts.I just built it up with wood cpes and epoxy.
Looking at Lakedog55 foam thread it appears to be just foam in that area. Monty
foam
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79TiqueRebuild Quote  Post ReplyReply Direct Link To This Post Posted: June-04-2011 at 2:40am
I finally got some time in on the boat. After lots of contemplation and some liquid courage I decided there was only one way I could make the radio fit with a splash guard. So I got the jig saw and cut a piece off the bottom of the existing hole and epoxied it to the top of the hole. That gave me enough room for the splash guard.
Also got front storage area/speaker board finished.
Rear seatbox/speakers and storage. I think I will use throw cushions on base for this year.
Last I worked on my timing and idle issue. I got distributor installed and worked on timing and idle.I couldn't get it to idle right. While looking at the linkage I realized that the throttle stop was rotating on the throttle shaft. Is there any way to fix this? I took it apart and squeezed it in the vise for a temporary fix Not much faith in it though.Hope to give it the lake test this weekend. Monty
uk1979 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote uk1979 Quote  Post ReplyReply Direct Link To This Post Posted: June-04-2011 at 7:00am
Monty,Good luck with the shake down she looks great,like the I-pod/phone touch,who would of thought back in 79 we would have kit like this,I'm still trying to find a splash guard for my 8 track
Lets have a go
56 Starflite
77 SN
78 SN
80 BFN
