  New Posts New Posts RSS Feed - Water Test ends with overheating!
wakesurfer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wakesurfer Quote  Post ReplyReply Direct Link To This Post Topic: Water Test ends with overheating!
    Posted: May-05-2008 at 7:29pm
First off I have read every post about idles, and overheating issues.. this one is a mixture of all... I hope someone can help.
I have this senario:
This is the second water test on my newly purchased 1977 ski nautique.. engine ford 351 - holley carb.
So, I start it up and it warms up to 180 degrees within only 10 minutes of idle and a few minutes of running in nice clean cold water...
The Facts:
At 180 it hates to be shut off. And runs rough over 170... It loves 150 to 160!
The PO had the idle set at aprox 900 to 1000 rpms - seems very high.
I have been through the entire water coolant system - check impeller blades, intake hoses and trans pump - all working looking good. I have tightened all hose clamps hard. No Leaks are sighted... yet - here is something to consider regarding the coolant system.
From the intake to the Trans coolant filter pump the hose is not standard water intake... it is a retro fit hard orange hose then it goes from several fittings and other spliced houses to the impeller pump, which I have taken apart and is in good working order... The impeller is new, yet the pump looks old.
Also, the PO mentioned the belt drive that goes onto the RWP is from an unknown source and of unknown origin... could it be the belt is not turning fast enough?
COULD IT BE : I need a new RWP?
I need new hoses? They dont leak?
I need just a basic tune up?
Allot to consider I know.
BTW - My shifter and trans issues are NOW resolve due to the folks here on this forum!!!!
Thanks Guys.
Jamie
newbie
Post Options Post Options   Thanks (0) Thanks(0)   Quote wakesurfer Quote  Post ReplyReply Direct Link To This Post Posted: May-05-2008 at 7:30pm
Could it be the thermostat?
azeus17 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote azeus17 Quote  Post ReplyReply Direct Link To This Post Posted: May-05-2008 at 9:34pm
Have you tried the bucket test for the RWP? That would eliminate your question about the pump, belt, and half the hoses.
Do a search for "Bucket test" and you should find the details. There are two ways to do it, you can suck out of the bucket or fill it up. Either way should take about 20 seconds or less for 5 gallons, if I remember correctly.
Boats:
Current: 02 SANTE
Sold: 89 Sport Nautique
Post Options Post Options   Thanks (0) Thanks(0)   Quote wakesurfer Quote  Post ReplyReply Direct Link To This Post Posted: May-05-2008 at 9:38pm
I will try out the bucket test. GREAT TIP!
I did once put a 5 gal bucket under my boat and attached it w a piece of a garden hose stuck up in the intake --- my boat needs a strainer... I will try it.
No strainer equals no good!
maybe the strainer will help funnel the water in?
BuffaloBFN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BuffaloBFN Quote  Post ReplyReply Direct Link To This Post Posted: May-05-2008 at 10:52pm
I wonder how long it was run without the strainer; is there a cup strainer inline? If not you could have pieces of whatever lodged in somewhere. You probably checked, but the oil cooler will trap debris.
I had the same orange hose on my 79 but it didn't have any splices. It went straight to the cooler(around the tranny once).
1988 BFN-sold
Post Options Post Options   Thanks (0) Thanks(0)   Quote wakesurfer Quote  Post ReplyReply Direct Link To This Post Posted: May-05-2008 at 11:07pm
The PO said it he had no idea how long it has not had a strainer... several years i suppose. Clean lakes only I guesse? Inline strainer - No.
The splices are more severe on my oil cooler to my RWP.
I have checked and removed all the debris from the intake hoses to the RWP - the lake debris gathers in the transmission pump strainer. I check it before each drive. So, no trash in system as far as I can tell.
Speaking of through hull strainers: How do you measure the size of the strainer you need? Intake hose or hull hole?
Tune Up or Pump Up?
Jamie
Post Options Post Options   Thanks (0) Thanks(0)   Quote wakesurfer Quote  Post ReplyReply Direct Link To This Post Posted: May-06-2008 at 12:34am
I have searched the forum and cant find a visual - picture of a 5 gal bucket test.
I put a piece of a garden hose in a bucket - primed the water pump and hoses first... then put the hose inside another hose which ran to the RWP - the water hose diameter is smaller than the other intake hoses.
I started up the boat then inspected the water in the bucket.... It was now going down remotely fast in aprox 34 to 40 seconds it had only drained the bucket down a few inches with LOTS more to go, I felt the hose and it was very slight suchion....
could it be my set up is too restricting?
So, that said: Can someone send me some details on how to rule our your RWP?
Cheers... Learning ALLOt.
jamie
need more beer...
Post Options Post Options   Thanks (0) Thanks(0)   Quote wakesurfer Quote  Post ReplyReply Direct Link To This Post Posted: May-06-2008 at 1:19am
THIS JUST IN FROM THE PO:
I have never done a tune up on the boat so new plug, wires and a cap problem would not hurt. (3 YEARS) Also the boat has always ran at about 180 and I never had any problem.
The pulley that I put on the was the same size as the one that came off of it the only the I had to do was drill out the bolt holes a little.
ANY IDEAS?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: May-06-2008 at 9:58am
Jamie, You have mentioned "splices" in hoses. I think it may be time to replace the hoses back to original and then start over with trouble shooting. You state that they "don't leak" but they may be sucking air.
Greg (buffalo) mentioned a strainer. He is reffering to a inline basket type that was used on later year boats. I feel to are referring to the one on the bottom of the boat - correct? There isn't a tranmission strainer. You may be looking at the trans cooler.
Post Options Post Options   Thanks (0) Thanks(0)   Quote azeus17 Quote  Post ReplyReply Direct Link To This Post Posted: May-06-2008 at 4:57pm
When I did the bucket test, I disconnected the hose going from the through hull pick up to the inline strainer and put it in a bucket and sucked the water out. Just put the bucket right next to the engine. Water was all gone in less than 15 sec.
Sounds like you do not have a in line strainer, so you may want to disconnect the hose that runs from the trans cooler to the RWP and place that directly in the bucket and suck the water out.
There should be plenty of suction. Don't use the weak, restrictive garden hose.
Boats:
Current: 02 SANTE
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: May-06-2008 at 8:25pm
Why?? None of my boats have ever had strainers. Never had a issue but of coarse I don't boat in swamps ether!
Post Options Post Options   Thanks (0) Thanks(0)   Quote wakesurfer Quote  Post ReplyReply Direct Link To This Post Posted: May-06-2008 at 11:30pm
I am off to test the bucket !
Thanks!!
Jamie
Barracuda View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Barracuda Quote  Post ReplyReply Direct Link To This Post Posted: May-06-2008 at 11:33pm
Jamie, lots of good advice on here already.
I suggest you perform a basic tune up which includes setting the timing properly with a timing light. Then adjust your idle if it is still high.
As for the overheating: After replacing the splices go ahead and replace the thermostat with one that is recommended for your applications. Probably a 160 degree t-stat. the stat that is in there is probably of a higher operating temperature- too hot.
Good luck and be sure to report back with your progress so this can be used as a reference for others.
-Brad
Post Options Post Options   Thanks (0) Thanks(0)   Quote wakesurfer Quote  Post ReplyReply Direct Link To This Post Posted: May-07-2008 at 12:22am
Thanks again to all.
I performed a bucket test with large hose from bottom of RWP directly to Big tub of water and the thing had enormous suction. I could only use a storage tub container about 1/2 full (anyone know how much they hold?) it sucked that thing dry in less than 30 seconds. I put my hand over the hose and it had very strong suction.
SO, I think we are leaning to the thermostat. I cant seem to find it? Is it the small gizmo with a wire coming out of it near the circulating pump... on that note, could it be the circ pump?
Post Options Post Options   Thanks (0) Thanks(0)   Quote wakesurfer Quote  Post ReplyReply Direct Link To This Post Posted: May-07-2008 at 1:38am
I found the t stat, and it is a rusty one... and I am sure the original of over 1,000hrs.
just wondering which one to buy?
skidim has several for the PCM 351 engine.
Any ideas?
Thanks gents.,
jamie
Tim D View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tim D Quote  Post ReplyReply Direct Link To This Post Posted: May-07-2008 at 2:02am
You can get a 142 degree marine t stat at NAPA.
Tim D
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: May-07-2008 at 12:30pm
A 160 'stat will cause the same problem (and have him running at 180+). He needs a 142, which would keep the temp at 160.
Post Options Post Options   Thanks (0) Thanks(0)   Quote wakesurfer Quote  Post ReplyReply Direct Link To This Post Posted: May-07-2008 at 9:41pm
Well, I A160 in the boat. GOing to get the 142!
I have a basic question about my hoses.
from the thru hull intake the hose size is 1 and 1/4 to the Trans coller which is 1inch diam then out trans cooler to my raw water pump which is 1 inch and a 1/4 so my splices mentioned are to accomodate the different sizes.
Is this common or wrong?
It seems like it would be restricting the flow!
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: May-07-2008 at 11:28pm
Jamie,
Somethings not correct or I'm very confused! You have 1&1/4" ID hose somehow "spliced" to a trans cooler that has hose barbs (the male ends for the hose) made for 1" ID hose?? Post some pictures of these "splices" or try describing them again. Off hand, it sounds like potential spots to suck air.
Post Options Post Options   Thanks (0) Thanks(0)   Quote wakesurfer Quote  Post ReplyReply Direct Link To This Post Posted: May-08-2008 at 1:29am
Exactly!
My intake through hull ID is 1and1/4 ------ that hose is connected to the trans cooler ID 1inch. I have a hoses coupling reducer for the 4 inches of hose that come off the trans cooler.
I think I am just going to get a single piece of 1 and 1/4 and make it really tight on the 1 inch ID connections.
Any tips or similar set ups?
Is this common?
LAST GREAT COMMENT!
I was told by several marine mechanics to not even use a thermostat!
Any thoughts on running w out a s tat!
I am such a rookie.
Post Options Post Options   Thanks (0) Thanks(0)   Quote wakesurfer Quote  Post ReplyReply Direct Link To This Post Posted: May-08-2008 at 2:08am
I assume my coolant system should be intake to trans cooler to RWP.
Its just my ID's of my system are not the same.
Post Options Post Options   Thanks (0) Thanks(0)   Quote wakesurfer Quote  Post ReplyReply Direct Link To This Post Posted: May-08-2008 at 2:27am
Still thinking running with out t stat!
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: May-08-2008 at 8:34am
Exactly!
Is this common?
LAST GREAT COMMENT!
I am such a rookie.
Jamie, It sure sounds like a PO replaced the trans cooler with a 1" instead of the correct 1&1/4". This is putting a restriction on water flow and with the reducer couplings/connections it adds to the number of points that are potential leaks. When you ran the bucket test, you pulled the 1&1/4" off the RWP and put it in the bucket. This bypassed the problem area with the restrictions and the potential leaks (air). This should be the correct cooler: trans cooler
I suggest you get the new cooler. Your idea of trying to clamp a 1&1/4" hose on the 1" barb on the cooler won't work. You will never get it clamped down that far.
Running without a T stat is not a good idea. There is a complete thread on it that just popped up again. I'm sorry to here that you have heard from marine "mechanics" to run without one. If they said that, I personally wouldn't take a lawnmower to any of them!! At least you didn't refer to them as "technicians"!!!
"running without thermostats"
Post Options Post Options   Thanks (0) Thanks(0)   Quote Barracuda Quote  Post ReplyReply Direct Link To This Post Posted: May-08-2008 at 5:35pm
Thanks for the correction Tim. I've got a severe case of the DUH's going lately..
-Brad
Post Options Post Options   Thanks (0) Thanks(0)   Quote wakesurfer Quote  Post ReplyReply Direct Link To This Post Posted: May-11-2008 at 11:44am
Well here is the latest... It appears to be a combination of several things: Old cracked intake hoses reducing down to a 1 inch trans cooler then onto a old 160 t stat. I replaced the hoses and removed the t stat.
Got a 142 in the mail from Skidim. Still not sold on the reason why to use a t stat in an older 351 engine that needs all the water it can get to stay cool... in my case I have a smaller diameter trans cooler.
How many folks out there run w out t stats?
Did a dry garage test and it ran good.
Thanks again for all the wonderful input!!!
Off to lake test for the finally!   God Speed.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: May-11-2008 at 12:01pm
I think you have missed the whole point on the reason for the T stat. Think of it this way. It's not there to keep it COOL but rather to keep the engine HOT. More important is it regulates the temperature. You have a T stat in you house to keep the temp at one spot no matter what the outside temp is. Same thing.
In the late 50's, the marinizers of the marine engine started putting on the T stats. Yes, before that time there weren't any! Without the T stat, due to the extreme temp swings, tolerances of these engines needed to be quite loose. This isn't a ideal when looking for HP in a engine.
If the T stat wasn't needed, it wouldn't be on your engine.
Where are you getting the idea that your engine "needs all the water it can get to stay cool.."?
Jamie, You can do what you want but many here have given you the best advice possible. Go back and read the posts again. Did you bother to read this thread? "running without thermostats"
Post Options Post Options   Thanks (0) Thanks(0)   Quote wakesurfer Quote  Post ReplyReply Direct Link To This Post Posted: May-11-2008 at 12:12pm
Thanks for the insight.
What should a 351 commander engine temp be during normal operation?
Mine goes from 140 to 160 w out a t stat and 180 to 190 w 160 t stat.
What is the difference of the commander engine to others.. do they like it hot?
No worries... I have a 142 t stat in the mail.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: May-11-2008 at 3:23pm
Jamie,
Are you going to replace the 1" oil cooler with the 1&1/4"?
The "mechanic" that told you to run it without the T stat, is he the same guy who told you; "needs all the water it can get to stay cool.."
I'm trying to figure out where some of this mis information is coming from? Tell me more about him.
Go with Tim's figure of 160 with the 142 T stat.
adamt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote adamt Quote  Post ReplyReply Direct Link To This Post Posted: May-12-2008 at 3:30am
Pete,
Just wondering, why do some people refer to a 142 degree t-stat and others refer to a 143. Are these the same thing?
-Adam
1973 Skier
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: May-12-2008 at 12:21pm
Originally posted by adamt adamt wrote:
Pete,
Yup, same thing.
