Floor Removal |
Pgaboeing
Senior Member Joined: May-16-2007 Location: United States Status: Offline Points: 140 |
Posted: February-19-2009 at 6:22pm |
Ok I have almost the whole floor out with 6 bags of soggy foam.
What is everyone using to cut the flooring at the stern of the boat? I have a 92ski and with the sloping stern it makes it very tight in the area behind the gas tank. |
eric lavine
i cant believe you had wet foam, did it cause any rot?
Pgaboeing
Yes. Most of the rot was in the area of the drivers seat and observers seat. Both of the sub stringers a totally gone, the main stringers are rotted about half way through just in the area of the pylon. I will try and add some pictures.
Paul, What have you been using in other areas? A small (4&1/2") right angle grinder is handy to get into tight spots. In extream tight spots like corners, a die grinder (Dremel) will get in almost to the corner. You can put a friction cut off blade on ether. Several here have been using the diamond cut offs and are impressed. |
Pgaboeing
Pete,
I just found my die grinder in the back of my toolbox. This will work perfect. I have been using a 4 1/2 grinder with a metal cut-off blade. It seems to work really nice with very little dust. Paul |
eric lavine
lol, Pg, that was a foam or not to foam joke
Pgaboeing
AAAAH, Well lets open up a can of worms here,
Foam or NO Foam? That is the Question. |
Kristof
Grand Poobah Joined: October-08-2007 Location: Bree, Belgium Status: Offline Points: 3398 |
OOOHH NOOO not that dicussion again... LOL |
