  New Posts New Posts RSS Feed - Boat position on Trailer - again
Tom_Madison View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom_Madison Quote  Post ReplyReply Direct Link To This Post Topic: Boat position on Trailer - again
    Posted: May-23-2009 at 1:52am
I see that there was a similar discussion earlier, but I have different issue. My tongue weight was around 400 Lbs., and by moving the boat back about 3" I reduced it to maybe 375. This seems to be more than necessary, but my concern is that there is now an overhang of 20". Is that OK, especially with the gas tank so far back?
p/allen View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote p/allen Quote  Post ReplyReply Direct Link To This Post Posted: May-23-2009 at 3:43am
That shouldnt be any problem . But you do want to keep in mind the weight of the gas while traveling . When I travel a distance I keep my tank as empty as possible .
Pat
My 72 Skier
Rock River
Dixon,ILL.
81nautique View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 81nautique Quote  Post ReplyReply Direct Link To This Post Posted: May-23-2009 at 12:12pm
Tom, The 18' boat on a number 2 trailer will look just like that. 375 on the tongue is close but maybe still a tick high, just needs to be 10%. Your close enough where I'd say if it tows fine and doesn't wag then leave it alone.
Will you be heading to Green lake this July?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: May-24-2009 at 12:27pm
Even a Mustang hangs over on a #2,I do the same as Pat
Post Options Post Options   Thanks (0) Thanks(0)   Quote p/allen Quote  Post ReplyReply Direct Link To This Post Posted: May-24-2009 at 3:50pm
Gary , someone took your prop .
Pat
My 72 Skier
Rock River
Dixon,ILL.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: May-25-2009 at 1:46am
Long story Pat.I'll confess at GL. We still on for that front glass? Didn't want to bug you.
Post Options Post Options   Thanks (0) Thanks(0)   Quote p/allen Quote  Post ReplyReply Direct Link To This Post Posted: May-25-2009 at 4:52am
Sure I think I will bring it to GL. if that will be ok. I havnt had time to make it over to your area over the winter .
Pat
My 72 Skier
Rock River
Dixon,ILL.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: May-25-2009 at 12:55pm
Spent too much time shoveling and fixxing your sledI'll bet . I don't think I'll have the room in the car Pat.We can figure out something when we get to GL,like me just driving over. You arn't that far. Sorry for the thread jack Tom.
