  New Posts New Posts RSS Feed - PSI on Carter fuelpump to GT40
MBO090 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MBO090 Quote  Post ReplyReply Direct Link To This Post Topic: PSI on Carter fuelpump to GT40
    Posted: May-24-2009 at 12:39pm
Hello.
I`ve just asked this question on another tread but I need a quick answer:
How many PSI does the Carter fuelpump on my GT40 EFI (1998) deliver?
The company can offer three models:
15 PSI 379 liters/min
7 PSI 379 liters/min
5,7 PSI 272 liters/min (called marine modell)
Thanks from Sweden!
Livet går i direktsändning!
eric lavine View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote eric lavine Quote  Post ReplyReply Direct Link To This Post Posted: May-24-2009 at 1:28pm
EFI? isnt there 2 pumps...low pressure and high pressure?
Post Options Post Options   Thanks (0) Thanks(0)   Quote MBO090 Quote  Post ReplyReply Direct Link To This Post Posted: May-24-2009 at 4:50pm
Yes, there is a low pressure in front of the engine and a high pressure in the FCC-canister. The low-pressure pump seems to be broken...
