Proper Transmission Shifting |
Tim D ![]() Grand Poobah ![]() Joined: August-23-2004 Location: United States Status: Offline Points: 2641 |
![]() ![]() ![]() ![]() ![]() Posted: June-27-2009 at 1:40am |
The damper plate will not last long with quick shifting.
Tim D
eric lavine ![]() Grand Poobah ![]() Joined: August-13-2006 Location: United States Status: Offline Points: 13413 |
good practice to stop momentum except for emergency, and some guys go from dead neutral to full power, that really puts a hurting on the trans
nautiless ![]() Senior Member ![]() ![]() Joined: June-30-2008 Location: South Africa Status: Offline Points: 186 |
Lol@Buff! Transmissions can be replaced and be repaired. The human body and life often not.
BuffaloBFN ![]() Grand Poobah ![]() ![]() Joined: June-24-2007 Location: Gainesville,GA Status: Offline Points: 6094 |
Don't create the emergency!
phospher ![]() Gold Member ![]() Joined: July-19-2007 Location: United States Status: Offline Points: 557 |
Could someone please clarify on how to correctly shift an inboard boat.
before someone drives my boat i always preach that when shifting from forward to reverse ( or vice versa ) that you should let the boat sit in nuetral for a few seconds before shifting into reverse. that way it's not so hard on the tranny and the prop has time to stop spinning or at least slow down. now, in an emergency do what you have to do cause we all know safety comes first. what do you think? |
