  New Posts New Posts RSS Feed - Electric Paddle Wheel Speedometer
Watauga View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Watauga Quote  Post ReplyReply Direct Link To This Post Topic: Electric Paddle Wheel Speedometer
    Posted: July-02-2009 at 1:33pm
Does anyone know where to purchase the Electric Speedometer Parts.
The paddlewheel is broken and the axle hole is elongated, which may be what caused the failure.
I also need a pickup for the common type of speedometer.
HBnautique View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HBnautique Quote  Post ReplyReply Direct Link To This Post Posted: July-02-2009 at 3:28pm
My first call would be to the Great people @ Discount Inboard Marine, www.skidim.com (803) 345-0996
Livin' the Life
My 84' 2001
Post Options Post Options   Thanks (0) Thanks(0)   Quote Donald80SN Quote  Post ReplyReply Direct Link To This Post Posted: July-03-2009 at 12:32am
I have one on my 80SN and I have been advised to remove it and put on another Air Guide. I was told that these are not very accurate at all. One of my paddles is broken off the wheel and the needle does not work on the dash. Your 81 is the first one that I have seen with one. I have seen several 80's with them on some other boats on this site.
I am curious if I realy should take it off or try to fix it. It seems like Correct Craft only used them for a few years so I do not know if it may just be better to go with another Air Guide. I think two chrome Air Guides look better. JMO
Ski Dim does sell the pickup you need for your Air Guide. Also they are improved not to get cloged with weeds, or so I have been told.
I hope this helps,
Donald
Post Options Post Options   Thanks (0) Thanks(0)   Quote Watauga Quote  Post ReplyReply Direct Link To This Post Posted: July-03-2009 at 1:31am
Thanks Donald,
Here is picture of the dash. This is the way it came from the factory. The reason I like the paddle wheel model is that it seems to be more accurate at slower speeds. I will check out your link and see what they have to allow. But the dash always looked goofy, like one of the speedometers went bad and someone installed whatever they could get their hands on.
Lets see, 1300 hours over 28 years! That pretty good eh?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Donald80SN Quote  Post ReplyReply Direct Link To This Post Posted: July-05-2009 at 5:06pm
Yes, that is exactly what mine looks like. I like the two Chrome Air Guide look.
Donald
Lake555 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lake555 Quote  Post ReplyReply Direct Link To This Post Posted: July-29-2009 at 11:16am
Did you find a source for a replacement for your paddle wheel? I am looking for one also. I have a 80 SN and the dash is just like yours. My right speedo is not working and the one of the left is inaccurate. I would be very interested to know where you found your replacement. thanks.
