  New Posts New Posts RSS Feed - overheating
overheating
stymie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote stymie Quote  Post ReplyReply Direct Link To This Post Topic: overheating
    Posted: July-22-2009 at 9:16am
i seem to be having a problem with my 87 cc with a 351 pcm. it started running hot over the weekend. i channged the impeller, witch was chuded up. it still running up to 200 degrese at an idle.so i took out the thermostat and it runs at 140. is it ok not to run a thermostat? im going to put in a new 140 stat in it today.also it allways ran at 180 with a 140 stat in it. could it be the cuculator pump. thanks.
SNobsessed View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SNobsessed Quote  Post ReplyReply Direct Link To This Post Posted: July-22-2009 at 10:22am
Stymie - You might hsve air leaks in the water lines or strainer. Search for 'Bucket test' on this site & see if the raw water pump sucks down a 5 gallon bucket. You also may have chunks of impeller in your thermostat housing. It is not good to run without a t'stat. The manufacturer would have left them out (if it wasn't needed) as a cost reduction!
