PCM transmission oil |
dlutz
Newbie Joined: July-26-2009 Location: colorado Status: Offline Points: 3 |
Posted: July-26-2009 at 6:28am |
Posted in wrong forum- I'm a newbie, what can I say.
92 Supra Sunsport- PCM 1:23:1 transmission-want to change trans oil. Plate on transmission says SG 20 20 W motor oil (same as manual). Car Quest carries SAE 20 but not SAE 20 20w. It looks like the boat shop I purchased it from has used tranny fluid (pink/red). What should I use? |
eric lavine
it was switched over to Dexron/Mercon which is what PCM recomended. stick with the Dex/Merc
mtguy
Senior Member Joined: August-04-2008 Location: Priest Lake, ID Status: Offline Points: 165 |
Eric,
I'm guessing same answer for my question -'95 SN w/ GT-40 motor. 1:23:1 tranny. Dex/Mercon 20w for mine as well? Thanks in advance. ~Peter |
'95 SN
'53 Hutchuck '56 Essaness Craft |
You want Dex/Merc (or Dex III) ATF. Eric and I like Valvoline. Dont use synthetic. Avoid high mileage formulations if you can. Only the very early production 1.23 boxes specified 20w oil. |
