  New Posts New Posts RSS Feed - Need restoration decals
cessnapilot77 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cessnapilot77 Quote  Post ReplyReply Direct Link To This Post Topic: Need restoration decals
    Posted: October-14-2009 at 5:26pm
   I am trying to locate a source, for the "Ski Nautique" decals. I also need the rear decal " Correct Craft competition ski boat" I am in the process of restoring a mid 70`s Nautique. Any help would be greatly appreciated.
cessnapilot_av8tor
harddock View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote harddock Quote  Post ReplyReply Direct Link To This Post Posted: October-14-2009 at 5:53pm
Some of those older boats have the SN painted You might want masks or stencils and have it repainted. Stay tuned someone with more knowledge will chime in soon. If inpatient search the posts here as there is plnty of information to be found on this subject.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: October-14-2009 at 10:17pm
Joe,
The graphics on the sides and transom are paint. Is there anything left of the originals? If so, the best way is to trace what's left and get it to a side shop. They will scan the tracing, clean it up and then cut you a Gerber mask. It's a stencil specifically designed for paint.
The three decals on the sides towards the aft end are available. pauly-banana has the flag and the AWSA and I have the larger size of "since 1925" which would be the correct size for a 70's.
Welcome to the site and how about some pictures of the project!
Post Options Post Options   Thanks (0) Thanks(0)   Quote harddock Quote  Post ReplyReply Direct Link To This Post Posted: October-14-2009 at 10:25pm
You put it much more eloquently as I knew you would
Tim D View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tim D Quote  Post ReplyReply Direct Link To This Post Posted: October-15-2009 at 2:25pm
I've got the decals and can make stencils for you if you want to repaint them.
Tim D
Post Options Post Options   Thanks (0) Thanks(0)   Quote cessnapilot77 Quote  Post ReplyReply Direct Link To This Post Posted: October-15-2009 at 8:28pm
Thanks guys for the input. The boat currently has a large decal on the back, and it looks OK, but it has that cheap look. It has a large area around it of clear decal material. This would have been a great decal if someone had taken some time to trim the excess off. I was hoping that someone had reproductions, but it looks like I`m going to have to get the masking tape out and paint the lettering. I have did this before, on some other stuff. I guess if it was easy everyone would do it. I might get this thing restored with some CCF friends. Thanks!!!
cessnapilot_av8tor
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tim D Quote  Post ReplyReply Direct Link To This Post Posted: October-16-2009 at 2:20pm
Masking tape will give you a nasty edge. Get 3M's tape called the "Edge", it works great.
Tim D
MartyMabe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MartyMabe Quote  Post ReplyReply Direct Link To This Post Posted: October-22-2009 at 11:18pm
93 SN Decals
Any files on these? Or the font name? The decal shops can't seem to replicate mine. Purple splash effect
66 Skylark
93 SN
If you're not living in NC, you're just camping out!
kapla View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kapla Quote  Post ReplyReply Direct Link To This Post Posted: October-23-2009 at 1:01pm
these are tricky ones..mine are in the same codition as yours....heve them duplicate is a difficult quest imo...
that splash effect is painted to the vynil or what ever material they are made off, In large quantities prices were ok, but if they are to do one set they will likely be very expensive...
<a href="">1992 ski nautique
Peter Gullen View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Peter Gullen Quote  Post ReplyReply Direct Link To This Post Posted: November-04-2009 at 9:37am
Im also after a set of these, mine are not not in quite as bad condition but i cant see me getting the faded gel back around them without removing them. Even being very carefull i slightly burnt one letter last year.
Are the new 'ski nautique' lettering available from correct craft? Ive never been a huge fan of the purple sprayed in the middle as it looks like the boat has badly rubbed on a dock.
93 Ski Nautique
Post Options Post Options   Thanks (0) Thanks(0)   Quote kapla Quote  Post ReplyReply Direct Link To This Post Posted: November-04-2009 at 10:00am
Originally posted by MartyMabe MartyMabe wrote:
93 SN Decals
FYI
Woody @ mastercraft of orlando (former nautique dealer) carry those @175 per side...
(407)851-1965
ripster92 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ripster92 Quote  Post ReplyReply Direct Link To This Post Posted: November-04-2009 at 2:05pm
Hey KapIa. I believe the "purple splash" effect is just clear vinyl that lets the underlying color show through.
Steve
1992 SN Black w/ Yellow
