82 nautique floor repair |
Post Reply | Page 123> |
Author | ||
82erostypop
Newbie Joined: May-05-2008 Location: United States Status: Offline Points: 4 |
Posted: January-14-2010 at 7:48pm |
Im new to this and have a 1982 ski nautique 2001. I have decided the floor between the driver and passenger need to be replaced. I have never done anything like this and its eating my lunch. I was wondering if someone knows a thing or two about this and could help me out?
I have already cut out the floor to reveal a mess of foam rotted wood and cracked fiberglass.. |
James,
You've come to the correct spot for information but be prepared to find issues under the floor. There's really no such thing as just a floor problem! There are many threads on stringer replacement from start to finish. I suggest you sit down, do a search and start reading. Plenty of pictures too! If you start pulling up the floor, make sure you post some pictures so we can follow along and give you better advice when needed. Welcome to CCfan. |
82erostypop
this is where im at so far. i got a little too close to the edge when i was cutting out the floor and managed to cut right through the hull! i should have read some of these threads.. the primary stringers (in the pictures) are completely rotted out. can i just cut those out and replace that one section?
Grand Poobah Joined: June-29-2005 Location: NWCT Status: Offline Points: 21183 |
Like you said, theyre completely rotted out- so I wouldnt stop short of replacing all of the stringers with new. |
James,
Just as Tim mentioned, you need a complete stringer job. All the wood is wet and the cancer has spread. Don't feel bad as your not the only one who has thought they were only going after a soft spot in the floor! It's time to pull the engine and start getting to down to the bare hull. Were you surprised as to what you are finding? How long have you had the boat? |
WakeSlayer
This exact scenario happened to me October 2008. Once you see what is in there, you are pretty much committed. In your case, I would say you are long overdue. Neither of mine were nearly that bad.
While the idea of the job ahead of you is very intimidating, it really is not that bad. You basically get a new boat out of it for a couple thousand bucks and a couple hundred hours. The community here will walk you right through it. Best of luck in your project. |
Mike N
1968 Mustang |
James,
I do have a suggestion for future posting of pictures. Downsize them so they don't require scrolling left to right. It makes them easier to view. Thanks |
82erostypop
i bought the boat two years ago and have spent the past two summers trying to get the motor running right. I wasnt very surprised the wood was rotted out but i didnt think it would be such a mess under there.. the floor was spongy right there so i had to do something about it. what do you guys think about rhino lining the floor instead of using carpet?
WakeSlayer
I think you have a lot of stuff to consider before you get to the point of what you are going to cover the floor with.
Mike N
1968 Mustang |
JohnG
Newbie Joined: September-08-2007 Location: Dallas, TX Status: Offline Points: 19 |
You have definitely come to the right place; the collective knowledge on this site has saved a lot of boats and first timer headaches. I lurked here for a long time before tackling my stringer job. Good luck and do it all at once; anything less and you'll do it again!
I think you should continue this thread over to wakeboarder.com and see what they have to say. |
eric lavine
just for ***************s and giggles for you retro guy's, there is a company out there that makes non skid surfaces that stick, to the area you want to cover. I'll post the website later. its used alot on platforms and decks. im sure its available in flourescents too
Keeganino
Grand Poobah Joined: October-27-2009 Location: North Carolina Status: Offline Points: 2063 |
You guys
skicat2001
Platinum Member Joined: November-24-2008 Location: Ft. Worth TX Status: Offline Points: 1950 |
I have a curious question? I see you pros talk alot about stringers on here. How do you know when your stringers are bad? By the floor? Or by the engine mounts? I am confused.. My floor is solid as can be..
1985 CC 2001-SOLD
Lee Michael Johnson |
storm34
Skicat-This is a good sign they're rotten!
storm34
Seriously tho, Check the bolts on the engine mounts to see if they tighten or spin freely. Also check for any cracks under the removable floor section behind the motor.
Be careful, searching for rot will normally turn up positive and lead to projects! |
Keeganino
Mine were not obvious until I pulled up the carpet and plywood in the back of the boat. You can see pictures on my thread 1973 Stringer Questions that show obvious signs of rot. The real kicker is if your engine mounts will not tighten and just spin in place. A more invasive and sure way to check them is to use a small hole saw. Drill just through the glass so you can see the stringer. The pilot will go a bit deeper and give you a better indication of what is going on under the surface. If all is good CPES over the hole and them fill with epoxy. Good luck. There are not many dry stringers out there.
1973 Skier |
skicat2001
Hey guys thanks! I will check mine this weekend. I think mine are ok, I am putting all my new hoses on this weekend. I will check the screws on the engine mounts.
1985 CC 2001-SOLD
WakeSlayer
Ain't that the truth.... |
Mike N
1968 Mustang |
While you're under the dog house, you should check the trans/prop shaft alignment too. |
skicat2001
How do you know they are of line by just looking? |
1985 CC 2001-SOLD
WakeSlayer
Mike N
1968 Mustang |
skicat2001
AWSOME! THANKS WAKE.. :) |
1985 CC 2001-SOLD
Lee,
Maybe you should change your signature line until you start checking the boat out! Don't forget about the pictures and do check out the stringers. A 85 isn't immune to rot. |
82 Nautique 1
Senior Member Joined: January-06-2007 Location: Rock Island, IL Status: Offline Points: 265 |
Pete,
You are right. As long as Correct Craft built them the way they did the rot is there. Most people do not know it because there floor is not soft in front (the first clue to the ones who care) When you have a boat, wet people, dripping water, there is no keeping water out of or off of untreated or unglased wood. As much as I love my boats the most discouraging things to find to find is rotting wood. Dennis |
skicat2001
I sure will.. I can not change my name, my dads best friend called me "Skicat".(Long Story) When I was a kid a grew up on a 67 Cetury Resorter, and he was like my idle. I miss that man, I figure I better keep the name going. But what do you mean 85 2001's are not immune to rot. |
1985 CC 2001-SOLD
skicat2001
I sure will.. Thanks for the advice. I am not going do any hard core search, I will just check those screws on the egine mounts |
1985 CC 2001-SOLD
Keeganino
I think what they are saying about being immune to rot, is that there are very very few, if any boats from this era that do not have some signs of water intrusion, which eventually turns into a full blown stringer job.
The PO of my boat swore up and down that the floor was solid. There is not a dry piece of wood in my boat. Take pics of what you find and the group here will tell you what is going on. |
1973 Skier |
WakeSlayer
I can never figure out how people can claim that in for sale ads without ever having looked under there. You see it an awful lot. |
Mike N
1968 Mustang |
skicat2001
OK i sure will.. I will take some pics of the stringers and post them on here. Tell me what you exactly want me to take a pic of for you guys to give me a solid and for sure answer. I asked my mechanic about them, and he said they where good, but would like yalls advice as well..
1985 CC 2001-SOLD
