  New Posts New Posts RSS Feed - Rule-o-matic float switch
oldcentury76 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote oldcentury76 Quote  Post ReplyReply Direct Link To This Post Topic: Rule-o-matic float switch
    Posted: June-27-2005 at 7:25pm
I wired my float switch for automatic use on the bilge pump. This weekend the switch crapped out on me. Has anyone had similar problems? Any recommendations? Are level switches only for use when the boat is stationary?
1976 Ski Nautique
Too many hobbies, not enough time!
David F View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David F Quote  Post ReplyReply Direct Link To This Post Posted: June-28-2005 at 12:46pm
Basically, yes.
Best to wire the switch so that you can bypass it with a switch on the dash. This way, you can operate the pump anytime you wish, regardless of the float switch.
The float switch is benefical when leaving the boat in the water unattended for long periods of time.
The best float switches are smart switches that have a built in delay of 30 seconds or so...this eliminates the movement of the boat from activating the pump if the float switch is activated while using the boat.
