  New Posts New Posts RSS Feed - Banjo Fitting
Banjo Fitting
harriss28 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote harriss28 Quote  Post ReplyReply Direct Link To This Post Topic: Banjo Fitting
    Posted: November-03-2010 at 8:46pm
I installed a banjo fitting and bolt for an oil drain hose on my 97 SN. I used this instead of the standard oil drain kit because of the clearance issues.
Do you guys think this is ok? My only concern is that the bolt may work loose.
Shawn
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: November-03-2010 at 9:08pm
Shawn,
If you used the copper "crush" washers on it, I really don't feel it will loosen up. However, I am concerned about the flow you'll get through it. The fittings are typically used for pressure applications in tight areas and have some pretty small ports through the bolt.
Post Options Post Options   Thanks (0) Thanks(0)   Quote harriss28 Quote  Post ReplyReply Direct Link To This Post Posted: November-04-2010 at 2:03am
thanks pete, i may have to suck the oil out. Ill post reply in spring.
Shawn
