What kind of glue do I need? |
karthur ![]() Senior Member ![]() Joined: July-11-2011 Location: SE USA Status: Offline Points: 102 |
![]() ![]() ![]() ![]() ![]() Posted: July-11-2011 at 11:59pm |
Got a pair of skis out of storage and this one is busted. Looks like the glue can apart at the joint.
What glue would ya'll recommend to fix this with. Will Tightbond III work, or would it be better to use something else? Thanks ![]() |
Jllogan ![]() Platinum Member ![]() ![]() Joined: May-18-2011 Location: canton, OH Status: Offline Points: 1728 |
I bet some 3M 5200 would work, its like the duct tape of the boating world.
81nautique ![]() Grand Poobah ![]() ![]() Joined: September-03-2005 Location: Big Rock, Il Status: Offline Points: 5776 |
To fix that permanently I would put a few bisquits along the joint and then use a waterproof polyurethane glue like gorilla grip. Clamp it up good and give it day to set. Sand and put a fresh coat of polyurethane finish on it.
I thought about sanding and refinishing the polyurethane. Problem being the decals.... would hate to lose those. The cypress gardens emblem on the back does not cross the joint, but there is a large one on the tip of the ski that does (you can just barely see it in the pic).
Thanks for the recommendation on the glue. Looks like this is probably the best choice. hopefully I can borrow a biscuit cutter from a friend. |
Well, thought I could get a biscuit cutter from a friend, but it didnt work. I just glued it back with Gorilla glue and clamped it up good. Left it over night and took off the clamps. Filed the glue. It looks pretty good. We'll see how it does this w/e.
Hopefully it will stay together. |
OverMyHead ![]() Grand Poobah ![]() ![]() Joined: March-14-2008 Location: MN Status: Offline Points: 4861 |
I am not sure what they used for finish or compatability but it would be nice if you could get an extra coat on it.
1987 Ski Nautique |
