  New Posts New Posts RSS Feed - Quick Question
Quick Question
00cls1camaross View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 00cls1camaross Quote  Post ReplyReply Direct Link To This Post Topic: Quick Question
    Posted: August-12-2011 at 3:36am
First off I wanted to say this site is great. I have gotten a lot of useful information from it.
I have a quick question,
I am looking at buying a Nautique 2001, were all of the 1989 Ski Nautiques the 2001 hull or just some of them?
Thanks,
Dakota
2002 Chevrolet Silverado Z71
33 x 12.50s, BBK, Cranked
2000 Camaro SS
Cam, Slicks, Boltons, Stall
1985 Ski Nautique
MT1, Board Rack, ACME 542
Future:Stereo, Wrap, Girls
sweet77 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote sweet77 Quote  Post ReplyReply Direct Link To This Post Posted: August-12-2011 at 10:23am
Check out the reference section Here
76 Nautique
"If you do what you always did,You'll get what you always got!"
"An empty wagon makes t
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeinNY Quote  Post ReplyReply Direct Link To This Post Posted: August-12-2011 at 11:55am
The answer is yes if it is an 89 model year boat with an 89 model year serial number then it is a 2001 series hull.
Bri892001 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bri892001 Quote  Post ReplyReply Direct Link To This Post Posted: August-12-2011 at 12:03pm
89 is also the first year of the Power Plus 1.23:1 transmission as well as the single exhaust outlet and muffler. By then, it also had the pylon going into the metal engine cradle set up, although I believe other years had that too.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: August-12-2011 at 12:15pm
The cradle was introduced on the Ski Nautique in 1980, so all 2001's have them.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hollywood Quote  Post ReplyReply Direct Link To This Post Posted: August-12-2011 at 12:24pm
A 454 optioned 89 Ski Nautique will be tilted and bolted to a 1:1 velvet drive along with the loud dual exhaust.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 00cls1camaross Quote  Post ReplyReply Direct Link To This Post Posted: August-12-2011 at 1:08pm
Thank you. I read that the 1989 was the best year of ski nautique because of the transmission, the way the motor was set flat,direction the motor turned, and the epoxy.
Is this all true?
2000 Camaro SS
1985 Ski Nautique
Dreaming View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dreaming Quote  Post ReplyReply Direct Link To This Post Posted: August-12-2011 at 2:32pm
Is this all true?
It all depends on your use of the boat. There are better (flatter) ski wakes from some of the newer boats, and you can get a better wake with the newer V- Drives.   If you're looking for a great old budget wakeboard boat, 2001's are hard to beat.   89 does have the 1.23 transmission, which is said to be a good thing, but the single exhasut is a downside for some.   All of the pre 1993 boats have wood stringers and will at some time need a full replacement job (read big $ and lots of man hours).   2001 hull design was the same from 1982-1989... limiting yourself to an 1989 may have you waiting a while to find the right boat, where expanding your year selection would broaden your options.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hollywood Quote  Post ReplyReply Direct Link To This Post Posted: August-12-2011 at 3:20pm
I think he meant 89 was the best of the 2001 era Ski Nautique. It has been proven the 82-86s are 2-3 mph faster on top than 87-88s because of the rearward weight distribution. Everything else you mentioned is true.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bri892001 Quote  Post ReplyReply Direct Link To This Post Posted: August-12-2011 at 4:04pm
What was the story on the epoxy? Something different on the layup of the hull?
kapla View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kapla Quote  Post ReplyReply Direct Link To This Post Posted: August-12-2011 at 4:22pm
what year they started using the ame4000 resin? anyway i think is a vynil based resin....
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: August-12-2011 at 5:06pm
Seb,
Yes, it's a vinylester resin. The switch was made due to all the problems the water absorption of the old polyester creates.
Swatkinz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Swatkinz Quote  Post ReplyReply Direct Link To This Post Posted: August-12-2011 at 9:35pm
Hwood, are you referring to the fact that 87 and up had a more cockpit forward deck than the previous 2001 boats? That would've been the only weight distribution differences, right? I don't question your fact just curious as to the rearward weight you refer to.
Steve
2011 Sport/Air 200
Excalibur 343
Former Malibu owner (07, 09)
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bri892001 Quote  Post ReplyReply Direct Link To This Post Posted: August-12-2011 at 11:27pm
The later ones had bigger cockpits and slightly smaller area in front of the windshield. This had the effect of pushing weight forward. At least passenger weight. Not sure what else?
P71_CrownVic View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote P71_CrownVic Quote  Post ReplyReply Direct Link To This Post Posted: August-15-2011 at 2:29am
Not the "loud dual exhaust"....the PROPER dual exhaust.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 00cls1camaross Quote  Post ReplyReply Direct Link To This Post Posted: August-15-2011 at 3:34am
I am looking to buy this boat for wakeboarding. I am on a tight budget and I will wait around until I find the boat I want.
I would like to remove the old Ski Nautique striping and lettering, is this difficult to do?
2000 Camaro SS
1985 Ski Nautique
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: August-15-2011 at 10:16am
Not given,
Yes, it will be difficult since the stripe is gel coat. You would need to re gel both hull sides.
BTW, most of our members here are better at restoration rather than modifying to non original! The gang over at PN or WW may have some ideas!!
Any pictures of the boat you're looking at? How are the stringers?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hollywood Quote  Post ReplyReply Direct Link To This Post Posted: August-15-2011 at 12:07pm
Exactly.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 00cls1camaross Quote  Post ReplyReply Direct Link To This Post Posted: August-15-2011 at 1:28pm
Not given,
I want to build something like this:
http://www.the2001.com/modules/gallery/albums2/album01/2001_G.jpg
I have not found a boat that I want. I am going to wait until the winter because I figured prices would go down.
I never grew up around water (from the desert) and I have not a clue how to check stringers. I would imagine you can see a piece of them if you open up the engine compartment? How else do you check them when looking at a used boat.
2000 Camaro SS
1985 Ski Nautique
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dreaming Quote  Post ReplyReply Direct Link To This Post Posted: August-15-2011 at 2:44pm
Exactly.
Thanks for the correction HW - That's something I didn't know
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: August-15-2011 at 2:53pm
Exactly.
When you add the weight of the windshield, dash, helm, seats and battery to that of the driver, youre talking about a pretty significant weight shift towards the front, even though that shift was less than a foot. Like HW said, the 87+ boats tend to be 1-3mph slower than the earlier 2001's. The '89 with the 1.23 seems to be an exception though... for some reason, most people Ive spoken to can eek 46-47mph out of those boats.
Like it was alluded to above, '89 was also the first year for the AME4000 (vinylester) resin.
