  New Posts New Posts RSS Feed - GT40 5.8-drain plug question
MontanaSport View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MontanaSport Quote  Post ReplyReply Direct Link To This Post Topic: GT40 5.8-drain plug question
    Posted: September-18-2011 at 12:45pm
I've found 4....2 on each side of the block and two on each manifold.
Is there a 5th one?
Thank you.
Turn Me Loose, Set Me Free
BuffaloBFN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BuffaloBFN Quote  Post ReplyReply Direct Link To This Post Posted: September-18-2011 at 1:01pm
Try a search for winterizing. Use the advanced search and set the time parameter to any date, not the last 6 months. I know I've seen some nice pics of where all the drains are.
You'll have a drain on the hose coming off of the circulation pump and another on the tranny cooler. Most pull the hose from the cooler as the housing can be delicate. The raw water pump is another hose to pull unless you take the pump off and take it inside as some do.
1988 BFN-sold
Post Options Post Options   Thanks (0) Thanks(0)   Quote MontanaSport Quote  Post ReplyReply Direct Link To This Post Posted: September-18-2011 at 1:21pm
let's see here....do it yourself and F up an engine if you don't know what the hell you're doing or grab ankle and pay a "pro" to do it at a marine center.
The problem I've found in all the winterizing threads I've read is that there is something different with just about all of them. Then I read my manual and it's different from what I've seen on threads. And to make it that much more interesting, there's a big fat disclaimer on the manual telling you it's not inclusive and CC's not responsible for you deciding to try and save some $ by doing this yourself.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MontanaSport Quote  Post ReplyReply Direct Link To This Post Posted: September-18-2011 at 1:25pm
Another problem is that I've seen too many threads on this subject. Now my head is spinning with so much conflicting thoughts and info I've read that I've freaked myself out into thinking I'm incompetent, which is true at this here juncture.
Post Options Post Options   Thanks (0) Thanks(0)   Quote BuffaloBFN Quote  Post ReplyReply Direct Link To This Post Posted: September-18-2011 at 1:35pm
You may have a CCFan close by who'll only make you grab knee?
You didn't mention the year of your boat, but try searching for topics instead of posts. Maybe make a list of what you see and check if it's on your engine.
Also, I didn't mention the strainer.
1988 BFN-sold
Post Options Post Options   Thanks (0) Thanks(0)   Quote gun-driver Quote  Post ReplyReply Direct Link To This Post Posted: September-18-2011 at 1:48pm
Spence,
Relax there's not much to winterizing the motor.
You already found four of the plugs, there is a fifth plug it is in the front of the motor on the bottom of the elbow next to the water pump.
What I like to do is run a tap in the plug holes to clean the threads then put the plugs back in.
Do you have a heater, shower, dripless shaft bushing? If so don't forget to drain them.
Now the great debate!!! I like to change the oil then run the motor and circulate the anti-freeze through the motor, heater, shower. Others just pull the hose and fill the block that way, both work and both are equally affective.
Circulating the antifreeze just satisfies my anal tendencies. And I even store my boats in climate controlled storage!!
gtxragtop View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gtxragtop Quote  Post ReplyReply Direct Link To This Post Posted: December-18-2011 at 10:43am
Make sure the tap you use is a 1/4-18 NPT PIPE TAP. A Pipe tap is tapered as are the drain plugs.
1996 Ski Nautique GT40
Worcester, MA.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: December-18-2011 at 10:57am
Welcome to CCfan. How about some pictures of your boat?
BTW, I hope that in 3 months Spencer figured it out.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MontanaSport Quote  Post ReplyReply Direct Link To This Post Posted: December-18-2011 at 12:54pm
Yea, I figured it out. Took it to a Nautique dealer. My starter relay took a dump on me.
Merry Christmas everyone
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hollywood Quote  Post ReplyReply Direct Link To This Post Posted: December-19-2011 at 1:05pm
With time, and this website, you'll feel much more confident in doing your own engine maintenance. Turn on the radio, grab a few beers and look it over for an hour or two. You'll also save a bunch of money. Marinas and dealers aren't perfect either...
