  New Posts New Posts RSS Feed - 1965 Mustang Project
mackwrench View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mackwrench Quote  Post ReplyReply Direct Link To This Post Topic: 1965 Mustang Project
    Posted: January-20-2012 at 5:29pm
Project- 1965 Mustang, reverse rotation 351PCM 260HP. Engine has 90 orginal hours, stainless steel braided hose exhaust from manifods to transom, Engine needs nothing, runs excellent. Holly 4 barrel, electronic ingition, newer exhaust manifods, Gel coat has spider cracks thoughout, Champagne off white color. Boat needs floor replaced, currently has plywood floor screwed in, not glassed, easy to replace, floor not rotted, incorrect plywood & de-laminated in places. Stringer have some rot but engine mounts are solid, Stainless steel engine mount brackets with insulated big block Chevy mercruiser mounts. Boat has not been in water since engine replacment. 1 to 1 B/W transmission, gasket/seals replaced at time of engine replacement. Boat has orginal correct winshield, orginal correct fiberglass engine cover, all trim, lights etc...are on boat and work, bilge pump, blower work. Aluminum fuel tank was steam cleaned out during engine replacement, new fuel line from tank to fuel pump. NO INTERIOR.....road worthly trailer with good tires, will pull anywhere in country, needs lights. Non orginal front seat pedstals. Battery Box relocated to under bow, no battery but new 2//0 battery cables with solder end connections. All wiring in boat replaced with new. Teak Swim Platform. Boat nor Engine never been in salt water.
Before I put on e-bay, I wanted to give the ones that love these boats the most a chance for this project. All boat needs is floor replacement, front seats and build a rear bench and battery. Needs some TLC labor and a little money to finish, Or would be a good doner engine/trans/shaft/prop parts boat. I have had boat since 1990 last time boat was in water was 2004. Located in Tallahassee, Florida. Clear Florida Boat title. Lots of pics available. E-mail mackwrench@gmail for pics. Would like to sell as is, complete before parting out for the same reason I'm selling it, no time to fininsh.
$1500
Thanks,
Todd O'Neal
NO LONGER A MEMBER
Post Options Post Options   Thanks (0) Thanks(0)   Quote mackwrench Quote  Post ReplyReply Direct Link To This Post Posted: January-22-2012 at 2:33am
NO LONGER A MEMBER
Post Options Post Options   Thanks (0) Thanks(0)   Quote mackwrench Quote  Post ReplyReply Direct Link To This Post Posted: January-22-2012 at 2:34am
NO LONGER A MEMBER
Post Options Post Options   Thanks (0) Thanks(0)   Quote mackwrench Quote  Post ReplyReply Direct Link To This Post Posted: January-29-2012 at 1:15am
http://cgi.ebay.com/ebaymotors/1965-Correct-Craft-Mustang-Ski-nautique-/130638411374?pt=Power_Motorboats&hash=item1e6aa7f66e
Want to sell to a good home, MAKE OFFER?
NO LONGER A MEMBER
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: February-02-2012 at 9:23pm
Are you sure its a reverse rotation engine? Looks like a LH prop.
OverMyHead View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote OverMyHead Quote  Post ReplyReply Direct Link To This Post Posted: February-02-2012 at 9:32pm
That will make someone a nice boat!
1987 Ski Nautique
Post Options Post Options   Thanks (0) Thanks(0)   Quote mackwrench Quote  Post ReplyReply Direct Link To This Post Posted: February-02-2012 at 9:35pm
Engine and wheel are reverse rotation, prop on boat in that pic was taken before current engine was installed....
NO LONGER A MEMBER
NO LONGER A MEMBER
Post Options Post Options   Thanks (0) Thanks(0)   Quote mackwrench Quote  Post ReplyReply Direct Link To This Post Posted: February-02-2012 at 9:36pm
NO LONGER A MEMBER
Hussler View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hussler Quote  Post ReplyReply Direct Link To This Post Posted: December-31-2015 at 5:40am
What a pile of sh*t
Post Options Post Options   Thanks (0) Thanks(0)   Quote 75 Tique Quote  Post ReplyReply Direct Link To This Post Posted: December-31-2015 at 11:15am
Never underestimate the restorability of a boat. I heard that some guy picked that one up and did a fairly respectable job of bringing it back.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: December-31-2015 at 11:33am
Originally posted by Hussler Hussler wrote:
What a pile of sh*t
WOW!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: December-31-2015 at 12:45pm
His boat Pete, try to keep up
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: December-31-2015 at 2:29pm
After just under 3 years? Just wait Tim, your time will come too!
64mustang16 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 64mustang16 Quote  Post ReplyReply Direct Link To This Post Posted: January-10-2016 at 5:41pm
Love those Mustangs from the sixties
Post Options Post Options   Thanks (0) Thanks(0)   Quote 64mustang16 Quote  Post ReplyReply Direct Link To This Post Posted: January-10-2016 at 5:43pm
Def. not pile of Sh*t
