  New Posts New Posts RSS Feed - does anyone know this boat
Post Options Post Options   Thanks (0) Thanks(0)   Quote SNobsessed Quote  Post ReplyReply Direct Link To This Post Posted: March-13-2012 at 10:43am
Pete - You need to call Joe in NY!
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: March-13-2012 at 9:38am
Jason,
Excuse my high jack here but I see you a a refrigeration tech. I have a issue wih a compressed air drier at the plant. I'm trying to figure the Total Heat of Rejection from a Tecumseh condensing unit model AWG4516EXTXC at 20 degrees suction. Can you come up with an answer and the formula?
john b View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john b Quote  Post ReplyReply Direct Link To This Post Posted: March-13-2012 at 3:18am
Please post some photos when you get a chance. The fixed link doesn't work.
i feel that boats are for enjoyment. If you enjoy this one then it is well bought. Good luck with the project. i know you will receive helpful guidance from site members. They may be rough at times, but they grow on you like a pilonidal cyst.
reftech View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote reftech Quote  Post ReplyReply Direct Link To This Post Posted: March-12-2012 at 11:32pm
storm thats awesome! this boat has been sitting since 2009 and i hope it goes as smoothly as yours did when i try to start it.im waiting to get the starter back from being rebuilt by wednesday and im getting all the other stuff ready in the meantime. i hope to turn the key friday.
storm34 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote storm34 Quote  Post ReplyReply Direct Link To This Post Posted: March-12-2012 at 8:51pm
Gotta love starting a new project for the first time! Good luck, be sure to take some pics/video!
This was my weekend adventure. Been sitting for 2 years or more. Fuel out of a gas can, swapped carbs, plugs/wires, some fresh oil and it ran like a top. Should be able to go for a ride with a new set of trans hoses then the rebuild begins. Got a long ways to go with this one, but it's all original and runs like a top.
EDIT- sorry for the funky video format.
Post Options Post Options   Thanks (0) Thanks(0)   Quote reftech Quote  Post ReplyReply Direct Link To This Post Posted: March-12-2012 at 8:24pm
kapla the firing order it was set up for made no sense...it was 1-5-6-4-8-2-3-7.the motor is a reverse rot motor and should be 1-8-4-5-6-2-7-3. drcc that my plan i have already pulled the carb and it is soaking in cleaner i am going to rebuild it.i bought the filter today and will be draining the tank and refilling thursday or so.
DrCC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrCC Quote  Post ReplyReply Direct Link To This Post Posted: March-12-2012 at 5:18pm
Actually, I would probably drain the Holley bowls, blow out all the fuel lines, change the filter, siphon off the fuel tank and then start with fresh 93 octane.
DrCC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrCC Quote  Post ReplyReply Direct Link To This Post Posted: March-12-2012 at 4:49pm
Check it for water in the gas tank and siphon out any old fuel.
kapla View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kapla Quote  Post ReplyReply Direct Link To This Post Posted: March-12-2012 at 4:43pm
what firing order did it had RH or LH ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote reftech Quote  Post ReplyReply Direct Link To This Post Posted: March-12-2012 at 4:28pm
Tim I gave 1600.00 for the boat and I have 450.00 in a trailer that is now totally new with lights new bunks winch jack and paint so I don't think I'm hurting at this point.I took the starter today for a rebuild as it was dead shorted.the motor turns freely by hand and everything looks good visually except they had the plug wires landed wrong and the firing order screwed up.so when I get the starter back this week I will prime the oil pump and attempt to start the motor.
TimSpangler View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TimSpangler Quote  Post ReplyReply Direct Link To This Post Posted: March-12-2012 at 3:58pm
@Jason,
Great project! I looked at that boat about 1-1/2 year ago but I couldn't justify the $ for what was offered (maybe with a trailer, maybe). What did you end up giving for it?
TIM
Post Options Post Options   Thanks (0) Thanks(0)   Quote TimSpangler Quote  Post ReplyReply Direct Link To This Post Posted: March-12-2012 at 3:55pm
(1) piece and he wants $100, He may have it for a while.
Post Options Post Options   Thanks (0) Thanks(0)   Quote reftech Quote  Post ReplyReply Direct Link To This Post Posted: March-12-2012 at 3:52pm
Thanks for noticing Donald actually the hardware is all therebut the glass is busted so I'm just gonna have some cut locally
Post Options Post Options   Thanks (0) Thanks(0)   Quote reftech Quote  Post ReplyReply Direct Link To This Post Posted: March-12-2012 at 3:48pm
No actually the boat didn't come with a trailer so I bought a supra boat that was in a warehouse fire and had a trailer on eBay for 255.00.after paint and all I have 450.00 in the trailer.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Donald80SN Quote  Post ReplyReply Direct Link To This Post Posted: March-12-2012 at 1:10pm
Originally posted by GlassSeeker GlassSeeker wrote:
just saw this the other day...looks like you might need it
wing window
You will need the metal hinge to make that window work. It is a channel that slides on the glass and glues in place.
There also seems to be a difference in the 80 / 81 and the 82+ hinge. I know from experience.
FYI,
Donald
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: March-12-2012 at 1:02pm
Originally posted by DrCC DrCC wrote:
Congrats reftech!    I see nothing but "positive" all over that boat. Looks un-molested.    Looks like it's all there. Original graphics, original interior.   I'd much rather start a resto with a boat like that than with someones molested custom job with half the parts missing.
Enjoy
Other than the missing CC trailer, I agree! Hope you got it for cheap, but it looks like a great starting point for a project.
GlassSeeker View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote GlassSeeker Quote  Post ReplyReply Direct Link To This Post Posted: March-12-2012 at 2:35am
wing window
This is the life
Post Options Post Options   Thanks (0) Thanks(0)   Quote ultrarunner Quote  Post ReplyReply Direct Link To This Post Posted: March-12-2012 at 1:52am
Yep, nice to see the boat complete, right down to the dash, gauges AND the Airguides. And you got a dual axel trailer! What did you give for it?
DrCC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrCC Quote  Post ReplyReply Direct Link To This Post Posted: March-11-2012 at 1:46am
Just as long as there is not many trees growing out of it.
I'm not seeing any abuse.
Use and neglect, yes.
Post Options Post Options   Thanks (0) Thanks(0)   Quote reftech Quote  Post ReplyReply Direct Link To This Post Posted: March-11-2012 at 1:42am
oh i see.ouch!
Post Options Post Options   Thanks (0) Thanks(0)   Quote GlassSeeker Quote  Post ReplyReply Direct Link To This Post Posted: March-11-2012 at 1:31am
No, it's in another rebuild thread, boat was smashed good...we predicted a possible divorce if he bought it.
This is the life
OverMyHead View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote OverMyHead Quote  Post ReplyReply Direct Link To This Post Posted: March-11-2012 at 1:30am
Abused children need more love than the ones well cared for. You are a good man.
1987 Ski Nautique
Post Options Post Options   Thanks (0) Thanks(0)   Quote reftech Quote  Post ReplyReply Direct Link To This Post Posted: March-11-2012 at 1:28am
thats true glassseeker! did that happen to u?
Post Options Post Options   Thanks (0) Thanks(0)   Quote GlassSeeker Quote  Post ReplyReply Direct Link To This Post Posted: March-11-2012 at 1:20am
At least no trees fell on it
This is the life
Post Options Post Options   Thanks (0) Thanks(0)   Quote reftech Quote  Post ReplyReply Direct Link To This Post Posted: March-11-2012 at 1:02am
thank u drstevens i thought about the project thing for a long time but im excited to get started.
DrStevens View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrStevens Quote  Post ReplyReply Direct Link To This Post Posted: March-11-2012 at 12:57am
Congrats, nice to see another older CC avoid the parts pile.
Post Options Post Options   Thanks (0) Thanks(0)   Quote reftech Quote  Post ReplyReply Direct Link To This Post Posted: March-11-2012 at 12:26am
thanks dr
DrCC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrCC Quote  Post ReplyReply Direct Link To This Post Posted: March-11-2012 at 12:01am
Enjoy
Post Options Post Options   Thanks (0) Thanks(0)   Quote reftech Quote  Post ReplyReply Direct Link To This Post Posted: March-10-2012 at 11:52pm
ohhhh pete check out your post on rtsuggs thread about and alternator rebuild where u said "I have NEVER had to needed to change out an alternator or generator on any of my boats." now seriously man is that proper english?? hahahaha!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote reftech Quote  Post ReplyReply Direct Link To This Post Posted: March-10-2012 at 11:40pm
i dont really understand the insults as i have seen some projects on here that are the same as this one but whatever.thanks to those who actually helped i appreciate it...and pete i i i i i i love u man u need a hug
