exhaust |
Jllogan
Platinum Member Joined: May-18-2011 Location: canton, OH Status: Offline Points: 1728 |
Posted: June-06-2012 at 4:02pm |
really 115? Thats seems like really cool, at least alot cooler than mine I usually run around 160. White smoke is usually water vapor. Gray/black or blueish smoke is usually a fuel or oil problem.
4woody
Groupie Joined: August-19-2011 Location: forney ,tx Status: Offline Points: 58 |
Pete i re-read your question now that iam not driving.air temp I assume it was 75-80 degres .
4woody
It was cloudy out that moring. The temp never got past 115 and that waseing then I took off temp drop back rnd 100..my carb was sucking alot of air when I would hit it out of the to stall back out then it it again ok. Would that cause smoke issue
What was the temp of the air? This question comes up from time to time. The "white smoke" is water vapor caused by the air temp. Think dew point.
4woody
Took my boat out for the first time this summer and I notice a bit more white smoke than normal out the exhaust pipe .can someone help is this bad
