  New Posts New Posts RSS Feed - Timing gears
Timing gears
forvicjr View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote forvicjr Quote  Post ReplyReply Direct Link To This Post Topic: Timing gears
    Posted: January-23-2013 at 5:29am
Needing timing gear set for small block chevy. Needing the crank gear and cam gear. The type that is two piece and doesn't include a chain .
62 wood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 62 wood Quote  Post ReplyReply Direct Link To This Post Posted: January-23-2013 at 10:57am
You building something?
64 American Skier
62 Classic..
73 Ski Nautique
Post Options Post Options   Thanks (0) Thanks(0)   Quote 62 wood Quote  Post ReplyReply Direct Link To This Post Posted: January-23-2013 at 11:01am
Ive got a set or two. Not sure I want to get rid of them..
check out good ol ebay
64 American Skier
62 Classic..
73 Ski Nautique
Post Options Post Options   Thanks (0) Thanks(0)   Quote forvicjr Quote  Post ReplyReply Direct Link To This Post Posted: January-23-2013 at 11:42am
Yeah Im gona sneek somthing together over time, part here part there kinda thing. The flee bay gears seem scary cheap.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 62 wood Quote  Post ReplyReply Direct Link To This Post Posted: January-23-2013 at 11:51am
Wanna buy a set of mine for 75 bucks?
BTW, I have a complete RH 283 ready to put together. Everything is fresh. ...heads, block, new pistons, etc ... (dang project change LOL)
64 American Skier
62 Classic..
73 Ski Nautique
Florida Inboards View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Florida Inboards Quote  Post ReplyReply Direct Link To This Post Posted: January-23-2013 at 11:54am
Being that I will never build a right hand chevy the old school way, I have a gear set you can have, pick up the bus ride it is yours!
Money Talks! BS Walks! and loose change rides the bus!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote forvicjr Quote  Post ReplyReply Direct Link To This Post Posted: January-23-2013 at 11:55am
Thanks on the 283, think Ill be going after more cid than that. More like 350 to 400 or so.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: January-23-2013 at 12:06pm
Whats wrong with your old timing set? We reused the gear/gear RR set on our 454 as it showed next to no wear.
Post Options Post Options   Thanks (0) Thanks(0)   Quote forvicjr Quote  Post ReplyReply Direct Link To This Post Posted: January-23-2013 at 12:19pm
I want to build a complete second motor, a turn key drop in. The motor thats going in after my stringer job will be a spare motor for next season.
Post Options Post Options   Thanks (0) Thanks(0)   Quote forvicjr Quote  Post ReplyReply Direct Link To This Post Posted: January-23-2013 at 12:22pm
You have a pm.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Florida Inboards Quote  Post ReplyReply Direct Link To This Post Posted: January-23-2013 at 12:28pm
This is a real deal Stamped GM set from the 60's it will need to be bead blasted as it has some surface rust on it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote forvicjr Quote  Post ReplyReply Direct Link To This Post Posted: January-23-2013 at 12:34pm
That's cool. I'd rather clean up an old quality part than buy new junk. Thanks alot! Vic...
Post Options Post Options   Thanks (0) Thanks(0)   Quote forvicjr Quote  Post ReplyReply Direct Link To This Post Posted: January-25-2013 at 7:59pm
Just received, as described. Great gift from Florida inboards. Thanks so much, the timing set already off to the machine shop for cleaning. Let me know when check arrives for the shipping. Thanks Vic........
