Sport Nautique Guard Rail |
watercraft
Groupie Joined: January-14-2013 Location: WI Status: Offline Points: 38 |
Posted: February-05-2013 at 2:14pm |
Foot_Fungus
Gold Member Joined: February-27-2012 Location: Chapin, SC Status: Offline Points: 501 |
hmm would this fit a 94, been looking for a replacement for a few months.
'94SN Restoration underway...
watercraft
very possibly, i indicated 92-93 because it is written on the parts tag.
Grand Poobah Joined: June-29-2005 Location: NWCT Status: Offline Points: 21136 |
Dont forget that CC curved the transom pretty significantly for '94, whereas 90-93 was pretty flat. I suspect that grab handle might not interchange without modification.
watercraft
I'm still learning a lot about the 90's models. This says specifically 92-93 SN, so if yours has the rounded back, it is a safe bet that it wouldn't fit. I thought that design change came later. Thanks for the info!
94-96 SN's got a gradual curve on the transom (and elsewhere on the deck), whereas the 90-93 boats were flatter and had harder creased edges.
1990: 1995: Not to be confused with the bubble but TSC SN's (1997-2001). Of course, this may be a moot point if the rail in question is for a Sport as you indicated in the thread title, as all 93-97 Sports should be the same (also a rounded transom like the 94-96 Ski's). Id be surprised if the same part could be used on the 89-92 Sports though, as those transoms were flat like the 90-93 Ski's. Then again, maybe the transom curve is gradual enough that it may fit all of the above? Pretty sure they didnt start putting them on boats until '91 or '92. |
Foot_Fungus
So Time you're saying that if that handle is for a 92-93 sport it should fit my regular 94 SN?
If thats the case I'm interested depending if you're firm on $70 or not. |
watercraft
This unit looks like the center post is mounted a little behind the 2 sides, like if i mounted it to a flat surface, the center post would not mount flush.
As far as the $70, make an offer. I also will not stick you with a part that doesn't fit. If you find for some reason it doesn't mount up I have no issue with refunding your costs. |
Florida Inboards
Senior Member Joined: December-27-2012 Location: Panama City, Fl Status: Offline Points: 265 |
They also look great with the powdercoat removed and the stainless polished out!
Money Talks! BS Walks! and loose change rides the bus!!!
N2Deep
Senior Member Joined: April-13-2012 Location: Las Vegas Status: Offline Points: 141 |
If he doesn't take it I will take it - It should fit my 91SN- it didn't come with one but have wanted to add it. Just waiting for one to pop up.
Thanks, Craig |
1991 SN pulled by a 2010 Tundra
Foot_Fungus
have at it n2...
