  New Posts New Posts RSS Feed - seeking a high gloss shine
Swatkinz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Swatkinz Quote  Post ReplyReply Direct Link To This Post Topic: seeking a high gloss shine
    Posted: March-16-2013 at 6:37pm
Hey guys,
I've spent the day working on my gelcoat. Arms feel like jelly.
Decided to replace my decals and when I pulled off the old ones, there was significant oxidation "ghosting" in the gel. Rubbing compound wouldn't even make a dent in removing it so I started wetsanding. So far, I've made a pass with 600, 1000, 1500, 2000 and 3000 grit paper. I then applied a West Marine marine polish (by hand). While the gel is free of oxidation and the ghosting is 99% gone (good enough for me), the gel still duller than I'd like.
I want the gel to pop. Really want a mirror finish.   Other wetsanding threads reference the 3M products and some mention an orbital buffer. Are the 3M products that much better? Is the buffer a necessity to getting the shine I want?
Steve
2011 Sport/Air 200
Excalibur 343
2017 Boatmate Tandem Axle Trailer
Former Malibu owner (07, 09)
SNobsessed View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote SNobsessed Quote  Post ReplyReply Direct Link To This Post Posted: March-16-2013 at 7:11pm
I would use a rotary buffer. The surface speed is what creates the heat to make the polish work. the orbital doesn't move fast enough.
I use a wool pad, mainly because i have about 4 of them.
Others prefer a foam pad.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: March-16-2013 at 7:17pm
Some 3M products recommend the foam pad and since I didn't have any at all I got their waffle pads.
tbeard View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbeard Quote  Post ReplyReply Direct Link To This Post Posted: March-16-2013 at 7:24pm
I just went through the process. You have to do all the steps...We wet sanded as you did, buffed 3 X with 3M heavy duty, 3X with Med 3M and then with Finess. Then clean with alcohol and apply decals. Let cure in sun a few days then wax.
Thanks.......Tom
audiodude View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote audiodude Quote  Post ReplyReply Direct Link To This Post Posted: March-16-2013 at 10:34pm
I used Presta Ultra Cutting Creme, then Presta Chroma and waxed with collinite 885 fleet wax. Used wool pad for the cutting creme, foam pad for Chroma with a rotary buffer and hand waxed. The boat looks pretty good but I know wet sanding is in my future.
2000 Ski Nautique 1989 Correct Craft 2001
In the words of Milton Berle: "You can lead a man to Congress but you can't make him think"
Waternut View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Waternut Quote  Post ReplyReply Direct Link To This Post Posted: March-17-2013 at 2:24am
I'm sure some people will not like this answer but here goes anyway...
Gelcoat has always been an nuisance for me. If you don't stay on top of it, it gets powdery. So the only option was to buff it at least once a year. If it gets too far, I was wet sanding and buffing. When that's done, then it's time to clean the inside of the boat thanks to all the splatter.
I gave up about 1.5 years ago. Sanded the hull once and painted it. The paint has held up great, I've barely even touched it, and it still looks shiney and new... This is despite having left it uncovered all summer long where it never see's shade.
TX Foilhead View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TX Foilhead Quote  Post ReplyReply Direct Link To This Post Posted: March-17-2013 at 4:31am
You were doing something wrong if it didn't stay looking good after a wetsanding and polishing. Either you didn't go far enough with the sanding, or you didn't take care of it afterwards.
The 3M stuff with their matching pads is pretty foolproof and works much quicker than trying to do it with wool pads. I wetsanded my blue stripe last year and its amazing what just getting rid of the orange peal does for the shine. New stripes coming this year so I'll get the orange peal out of silver cloud below the rub rail this year.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: March-17-2013 at 1:15pm
Short answer: you're not going to restore the shine by hand, you need a machine. An orbital might get you there since you sanded so far up (normally you'd only have to go to 1000-1200 if using a real aggressive compound and a rotary buffer)... But that's tbd. A rotary is much more aggressive, which is a plus when working on gel... It's much harder an thicker than paint. The 3m products are very good and will produce proven results that are detailed in the common questions forum. There are other ways to skin a cat, but you may be on your own in figuring out how to get what you want using products that we aren't familiar with.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Morfoot Quote  Post ReplyReply Direct Link To This Post Posted: March-17-2013 at 4:49pm
I know the factory uses 3M stuff and non rotary buffers I should have taken a picture of the container they were using for a final buff but figured I'd remember what it was. Needless to say I didn't. I'm pretty sure Tom nailed it when he said Finese. Sounds familiar and you know how they look right out of the factory.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: March-17-2013 at 6:38pm
There is no short cut thats for sure.I tried everything before too
like using rubbing compound. Wasn't until I started sanding from
220 in spots to 2000 then using 3m 05973 rubbing compound and 05996
Perfect II,which I learned of here,that anything "took".
M3Fan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote M3Fan Quote  Post ReplyReply Direct Link To This Post Posted: March-17-2013 at 8:20pm
Rotary with 3 levels of 3M compounds:
2016 SN 200 OB 5.3L DI
https://forum.fifteenoff.com
KRoundy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KRoundy Quote  Post ReplyReply Direct Link To This Post Posted: March-17-2013 at 9:25pm
WOW!!!! That's on black, which reflects well, but that is incredible.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Swatkinz Quote  Post ReplyReply Direct Link To This Post Posted: March-18-2013 at 11:23am
Joel,
That's what's I'm looking for. Thanks for the help, guys.
Steve
2011 Sport/Air 200
Excalibur 343
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: March-18-2013 at 1:48pm
Steve, FYI, Joel followed the suggestions I gave him on the products/pads/etc that I detailed in the for common questions forum. I know several people who have used this recipe and turned out some amazing results. Check out pictures of Brad's (Barracuda) '86 or the Hart's boats... theyve got it down to a science!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Swatkinz Quote  Post ReplyReply Direct Link To This Post Posted: March-18-2013 at 2:19pm
All,
If you complete your wetsanding with 2000 or 3000 grit paper like I did, does going over it with the 3M super duty compound not undo what you did with the fine paper? Hard to argue with results but dang that 3M SD is some gritty stuff
Steve
2011 Sport/Air 200
Excalibur 343
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: March-18-2013 at 2:24pm
If youre sure that you got all of the scratches from previous rounds with the 2000 or 3000, then start with the middle step instead (medium grade compound) and see how it looks afterwards. If you dont see any larger scratches left, then proceed to the Finesse-It II.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Donald80SN Quote  Post ReplyReply Direct Link To This Post Posted: March-18-2013 at 7:31pm
Steve,
Stop sanding and check those stringers by taking some deep core samples. There could be problems down under.
Donald
Air206 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Air206 Quote  Post ReplyReply Direct Link To This Post Posted: March-18-2013 at 8:05pm
Originally posted by Donald80SN Donald80SN wrote:
Steve,
Donald
Now Donald, be nice.... you know you gotta hide the rot inside by keeping it shiny outside! Isn't that what we all do? Even sometimes with our boats....
Post Options Post Options   Thanks (0) Thanks(0)   Quote Donald80SN Quote  Post ReplyReply Direct Link To This Post Posted: March-18-2013 at 8:31pm
Steve K,
Water could be coming in from inside the boat and going through the glass, resin and gel from the inside and causing the dull finish.
Just trying to help.
Donald
iplan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote iplan Quote  Post ReplyReply Direct Link To This Post Posted: November-17-2014 at 4:10pm
This is an amazing transformation... Should give everyone hope that their gelcoat is incapable of being salvaged...
85 Ski Nautique 2001.
Stringer replacement job completed July 3 2014.
Exterior painted June 2015.
The Trailer is next.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hollywood Quote  Post ReplyReply Direct Link To This Post Posted: November-17-2014 at 6:21pm
Holding the buffer up is far easier on the arms than sanding. Super Duty removes 1000 grit scratches. Two passes of 1000 or maybe a 1200 to be safe but no reason to go past that unless you are seeking an upper body workout.
Post Options Post Options   Thanks (0) Thanks(0)   Quote iplan Quote  Post ReplyReply Direct Link To This Post Posted: November-20-2014 at 3:04pm
Hollywood ~~~ Would like to see a picture or link to the buffer your recommending if you get a chance.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hollywood Quote  Post ReplyReply Direct Link To This Post Posted: November-20-2014 at 3:15pm
Google image "rotary buffer"
I like the makitas
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: November-20-2014 at 4:48pm
I like the makitas
I like the Milwaukee. Mine hasn't let me down yet.
DrCC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrCC Quote  Post ReplyReply Direct Link To This Post Posted: November-20-2014 at 4:52pm
I like the Milwaukee, BUT it's a tad fast and a tad heavy.
I think the ideal speed is 1200 to 1500 rpm's my Milw. is 1700.
I agree with H/W over 1000 gt. is a waste, let the compound do it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: November-20-2014 at 6:34pm
Al,
Maybe you bought the cheapest Milwaukee? The one I linked And the one I have is: Operating Speed (RPM): 0 - 1,750 Yes, it is on the heavy side but that's due to it's HD construction.
DrCC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrCC Quote  Post ReplyReply Direct Link To This Post Posted: November-20-2014 at 6:50pm
And, It probably should be noted that four 60.00 machines Does Not equal one 240.00 machine.
Porter-Cable also makes a real good machine.
DrCC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrCC Quote  Post ReplyReply Direct Link To This Post Posted: November-20-2014 at 7:01pm
Pete, I bought my Milwaukee probably before the variable speed was available.   I've had it since the early to mid '80's, back then it was 180.00   So, it's really great to see the costs have not gone up that much.   That's a lot of long lasting machine for 219.00
edit: and I didn't know that last line rhymed until now.
I'm thinking: tag line.
________________
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: November-20-2014 at 7:33pm
Al,
I don't know how you missed the variable speed. I bought mine in 85 to buff the varnish out on my Atom. It was the first bright job I buffed and knew I needed the real low speed. At least on a horizontal surface, they aren't that heavy!
62 wood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 62 wood Quote  Post ReplyReply Direct Link To This Post Posted: November-20-2014 at 8:04pm
I use a Sioux Air buffer A lot lighter, but you need a good air compressor..
btw, I did some "horse trading" to get mine.
There are also some less expensive ones out there that work fine as well.
64 American Skier
62 Classic..
73 Ski Nautique
