  New Posts New Posts RSS Feed - Fuel lines 2008 SN206
Fatboy206 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fatboy206 Quote  Post ReplyReply Direct Link To This Post Topic: Fuel lines 2008 SN206
    Posted: May-26-2013 at 11:22am
Can anyone please advise how to separate the fuel lines (Item 36 RA085090A & Item 37 RA085091A) from the fuel rail after removing the ReTAiner Clips (Item 35 R127100)
Got the clips off but could not separate the lines and I did not want to damage anything by being heavy handed. Is there a particular knack to getting the hoses off.
Appreciate any advice folks, thanks.
Bri892001 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bri892001 Quote  Post ReplyReply Direct Link To This Post Posted: May-26-2013 at 9:15pm
Do you have any pics? Also, wondering what you're trying to do? I do know on the automotive side there are some special tools required to separate certain types of fuel lines. If you look at Snap-On.com there are a lot, one example: http://buy1.snapon.com/catalog/item.asp?P65=&tool=all&item_ID=637258&group_ID=675558&store=snapon-store&dir=catalog
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bri892001 Quote  Post ReplyReply Direct Link To This Post Posted: May-26-2013 at 9:25pm
Ahh, I just saw your fuel filter post. I know the gt-40s have a Schrader valve for reading fuel pressure. I believe pushing on this will bleed air out? Do you maybe have the same? I think disconnecting the lines downstream of the fcc could be a little dangerous.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fatboy206 Quote  Post ReplyReply Direct Link To This Post Posted: May-27-2013 at 3:20am
I was planning to disconnect the flexible fuel line between the FCC unit and the fuel rail so that I could bleed the line of any air that I may have caused while replacing the in-line fuel filter cannister which is up near the fuel tank.
When I was replacing the fuel filter cannister I did not clamps the hoses either side of the filter as I suspect I should have and I'm sure I alloed a whole lot of air than I needed into the line.
Understand your comment about the safety side of it so I was planning to bleed the line thru a safe clear container container and vent it to prevent any fumes etc.
Thank you for your input.
