  New Posts New Posts RSS Feed - Back side of Temp Gauge
OldSchoolBlue84 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote OldSchoolBlue84 Quote  Post ReplyReply Direct Link To This Post Topic: Back side of Temp Gauge
    Posted: May-06-2014 at 5:05pm
Hey guys, was doing some cleaning behind the dash and on the back side of the temp gauge the jumper broke. Now, is that a special kind of jumper? Rectifier Diode? The jumper that broke has 2 female connectors with a black cylinder in the middle of the wire. Will try to post a pic after work. Do appreciate it. Thanks
Bri892001 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bri892001 Quote  Post ReplyReply Direct Link To This Post Posted: May-07-2014 at 12:29am
Was it definitely part of the temp gauge?
Does yours have an alarm? Maybe it had something to do with sharing the sender wire with the alarm?
Post Options Post Options   Thanks (0) Thanks(0)   Quote OldSchoolBlue84 Quote  Post ReplyReply Direct Link To This Post Posted: May-07-2014 at 12:39am
Yes, it was the temp gauge. No alarm on this one, its an 84SN2001. Below is a pic of the before and after. I just dewinterized her on the trailer this evening and the temp seems to work good with new fix. I installed a new rectifier diode, specs below;
Peak inverse voltage (PIV): 600V
Forward voltage drop (VF) at (lf): 1.6V
Forward current (lf): 1A
Max. surge current (16ms): 30A
Reverse current at (PIV): 10ua
