  New Posts New Posts RSS Feed - Fish Nautique RUDDER
DayTony View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DayTony Quote  Post ReplyReply Direct Link To This Post Topic: Fish Nautique RUDDER
    Posted: May-20-2014 at 12:57am
I know its asking a lot since not many of these are around but i'm looking for a rudder for my 78'
I built one last year out of steel that worked great but it was a test. i wanted to reach out and see if i can pick up an original before i go ordering the stainless to build a permanent replacement.
open to suggestions.
ScottZ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ScottZ Quote  Post ReplyReply Direct Link To This Post Posted: May-23-2014 at 11:26am
I have one that came out of a Southwind and one that came out of a 1986 Marinique (also a deep v boat).
Lake Mitchell , AL
1984 Ski Nautique
1972 Skier
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: May-23-2014 at 3:16pm
SW and Martinique both use the same 11a found on Ski Nautiques. No idea if the larger Fish uses the same. The 11a has a 1-1/4" shaft, so that would be one way to check.
DrCC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrCC Quote  Post ReplyReply Direct Link To This Post Posted: May-23-2014 at 3:23pm
I think yes, same one Tim.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: May-23-2014 at 3:57pm
Didn't Zach post a sheet a few years ago with struts shafts and rudders ? I'll see if I can find it
Post Options Post Options   Thanks (0) Thanks(0)   Quote DayTony Quote  Post ReplyReply Direct Link To This Post Posted: May-23-2014 at 4:14pm
thanks, Let me go check right now what the diameter is. and the depth of the mount.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: May-23-2014 at 4:14pm
Here is everything you need to know thanks to Zach
Post Options Post Options   Thanks (0) Thanks(0)   Quote DayTony Quote  Post ReplyReply Direct Link To This Post Posted: May-23-2014 at 4:28pm
That list may be wrong because i just checked and my shaft dia. is 1.25 and that list says 23' fish as 1 1/8.
Either way if the rudder you have is the 1.25" shaft and the length from the top of the rudder to end of the shaft is around 6".
(when i got the boat it had the wrong rudder so i cant cross reference.)
DrCC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrCC Quote  Post ReplyReply Direct Link To This Post Posted: May-23-2014 at 4:53pm
The 1 1/8" would be the prop shaft column.
11A - rudder column
Post Options Post Options   Thanks (0) Thanks(0)   Quote DayTony Quote  Post ReplyReply Direct Link To This Post Posted: May-27-2014 at 8:54pm
Looks like the 11a is going to be the correct rudder that it would have come with.
Are there any larger rudders that were available /interchangeable with the 11a?
