ski tique 302 Float Heights(measurements) |
76 Ski Tique
Senior Member Joined: July-23-2008 Location: United States Status: Offline Points: 140 |
Posted: September-12-2014 at 8:06pm |
hey there guys just did a carb rebuild with a holley marine renew kit.
just had a question on the float heights or measurements. does anyone know from experience what the correct heights are. |
B.O.A.T- bust out another thousand
boardersdad
Senior Member Joined: June-18-2013 Location: Wisconsin Status: Offline Points: 409 |
Not sure if you have a 4160 but I just replaced the primary bowl on mine. The floats one both the old and "new" (used) were set so if you hold the bowl upside down, a 7/64" drill bit could barely slide along the bowl inside surface without touching the float. Not sure what is called out in a manual, though.
76 Ski Tique
Thanks for the response. I do have a 4160 holley 450cfm. I spoke with holley and they said set the floats level. Put it back together runs fine but i do need get to to theyou river to check performance.
