1965 Ford Interceptor 260 ci |
Author | |||
jjojr1940
Newbie Joined: May-14-2010 Location: New York Status: Offline Points: 32 |
Posted: March-26-2015 at 4:56pm |
Does anyone have a set of exhaust manifolds for a 1965 Ford Interceptor 260 (Interceptor 140 hp? or 289 165 hp ? for sale ?
connorssons
Platinum Member Joined: January-17-2009 Location: Michigan Status: Offline Points: 1414 |
try daniel at hildabrands marine in mi i think he has a set! 5172382828 tell him jeff connors sent ya!
jjojr1940
thanks Jeff calling him now ! I'll be sure to mention that you referred me !
jjojr1940
Jeff,
hate to be a PITA, but can U double check the # ?? constant busy signal ? tks jjo |
connorssons
he
hello there no is 517 238 2828 u just have to try alot small family business 1 phone keep trying thay will answer. he sounds gruff when he answers but is a super nice guy! |
jjojr1940
Jeff,
Yeah, I googled him & found the other # for the Sea Doo side of things. Didn't think he ha em but said to call today. I reach out a little later , give him some time . Thanks again |
Riley
There's a nice set on ebay right now.
http://www.ebay.com/itm/271814991709?_trksid=p2060353.m1431.l2649&ssPageName=STRK%3AMEBIDX%3AIT |
jjojr1940
I sent him an e mail yesterday. says they are ford but the Bolt flanges and ports don't look the same dimension ? Narrower ?? unless it's photo distortion ? "Interceptor" appears to span more of the exhaust ports than on the ones I have too ?? waiting for reply to E mail ? Thanks for looking out for me though !!
-jjo |
Riley
They look a little different than these which are on a Y Block, but is the bolt pattern the same?
Riley
The bolt pattern is not the same as ours above. If the ebay manifolds aren't for a SBF, what would they be?
jjojr1940
Went back and looked again ? Taking a flyer, bought them ? we'll see ?? thanks again all.
JoeinNY
Those manifolds will work they are for a sbf... happy boating!
dochockey
Gold Member Joined: September-16-2009 Location: Colorado Status: Offline Points: 638 |
Hi John what boat is that going in?
1989 Teal Ski Nautique
1967 Mustang Harris Float Sunfish |
jjojr1940
Well..... depends on how you look at it ? We bought it in Michigan in 2010 and it was listed as a 1967 Mustang. The Michigan title had no actual HIN# only a Michigan re title # ?? apparently someone either salvaged it or lost the old Hull tag?? But as I looked around most of the 67 Mustang's had the molded in front Ventilator, So I looked all over for the Stringer tag, to no avail. We got the engine apart and learned that it was a 1965 260 ci. I know some of the marine engines sat around for a while, and that some of the boats from this era were listed by the year they sell and not by yr. of manufacture .. so all that being said.. I think it was a 1965 ish Mustang that is now a 1967 ish Mustang ?? Makes perfect sense right ? lol !! Anyway it has been a Great project for me and my (25 yo) son to restore. After his 1st season we decided that it was bleeding too much oil (rear main seal) so we decided to do a rebuild. we found a "wife beater" t shirt in the valley under the intake ?? And it Ran !! great !!
Post some pics and we can tell you what year it is with a pretty high degree of confidence.
dochockey
That's great
It's too bad you don't have that model number mime was registered thru the SS as a 69 but Art was able to find out through the archives that it was born on June 6 1967. Yesterday I went out and bought a new cherry picker pulling the engine this weekend. |
Riley
If it's got a deck like ours, it's a 65 or early 66.
jjojr1940
Identical hull ! split windshield & side wings and all !!
They are Osco's but as Joe mentions, will work. |
Riley
Pete, look at top of page. He got what appears to be a really nice set of Interceptors.
jjojr1940
All,
Thanks again for all of the interest in my conundrum. So, new manifolds arrived on Tuesday. They "look" great. They are date stamped from 1963. They appear pretty much identical except for a few little diff's in the castings. But they'll work perfectly provided they don't have the same internal issues as our original set, which leads me to my Q ? Riddle me this: How do we pressure test a manifold that doesn't have a riser to plate off and has a coolant input and co mingles the exhaust prior to the only other location to seal them off ? Do I have to remove the rear elbow & fashion a cover plate & gasket seal that on the manifold log to test them ? Looking forward to this discussion. Happy Easter to those who celebrate it ! -jjo |
JoeinNY
Yep but it ain't worth it to take them apart if you don't know they leak. I would put the exhaust end up and fill the water jackets to the top with water . Look inside the exhaust jacket real good for leaks if you don't see anything put me on and give me a shot.
jjojr1940
Open the petcock or remove the plug at exhaust end of log & when water gets there stop filling ?
