Morse throttle slips |
gjsullivan
Newbie Joined: November-08-2004 Location: Hillsboro, OR Status: Offline Points: 13 |
Posted: June-11-2006 at 12:38pm |
I have a 90 sport and the Morse MV2 throttle slips back when running. I thought I saw an adjustment post on this site a few years ago but can't find it now.
Does anyone know how to make an adjustment on the throttle control so it stays in position? Thanks, Glenn |
David F
I just read the entire Owner's Manual for my Morse MV-2 control. The manual does not mention any adjustment to solve your condition. I can only offer the suggestion that you possibly go to lighter spring on the carburetor arm. I will warn against removing the spring as it serves a very important safety purpose in returning the carburetor to idle if the throttle cable should break.
Greg_SA
Senior Member Joined: April-19-2007 Location: South Africa Status: Offline Points: 183 |
Hi,
Did you ever solve the problem on your throttle slipping? Maybe the "built-in friction drag" wears out? Maybe there is something that can be replaced inside the MV-2? Regards, Greg |
