  New Posts New Posts RSS Feed - 1978 SN radio
1978 SN radio
jeremy087 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jeremy087 Quote  Post ReplyReply Direct Link To This Post Topic: 1978 SN radio
    Posted: June-06-2016 at 12:39am
So has anyone put a radio in their older Nautiques? How much work is there in doing it? I was looking to put a radio, 4 seperate speakers, and a self powered sub. If you have done it share some pics if you don't mind.
sberard5 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote sberard5 Quote  Post ReplyReply Direct Link To This Post Posted: June-08-2016 at 1:36pm
Hey Jeremy,
I have a 76 SN and asked the same question on here less than a year ago. If your boat is set-up like mine, with a spotters bench seat, there isn't a lot of dash room to play with. I was close to purchasing a head unit with a remote controller than would fit into a small gauge size hole but didn't have the heart to drill or cut into the dash.
So, I ended up researching and purchasing a Bose Soundlink that hooks up with the Bluetooth on my smartphone. It works awesome. I don't bother using it while my engines running, because you cant beat the classic inboard exhaust sound. We use it when were swimming or hanging out at the sand bar. It says its good for an 8hr charge but I find it goes way longer. Just in case I installed a USB charging port under my dash to recharge the Bose if necessary. Just a thought....
74Wind View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 74Wind Quote  Post ReplyReply Direct Link To This Post Posted: June-08-2016 at 4:46pm
I got a cheap $20 one just to try it and it sounds way far greater than ever expected. My friend has a better one with a little flip-up solar panel, that's what i'd look for.
1974 Southwind 18
1975 Century Mark II
phatsat67 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote phatsat67 Quote  Post ReplyReply Direct Link To This Post Posted: June-08-2016 at 5:32pm
Don't waste money or cut holes for a head unit if you're like the rest of the world and use a device or phone for music. Buy an amp and proper splitters to attach a 3.5mm mic to rca cord directly to the amp. Tune the amp and sub with your phone equalizer set where you want it to stay and never look back at a head unit. The amp gets hidden and other than speakers it all looks stock.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Morfoot Quote  Post ReplyReply Direct Link To This Post Posted: June-09-2016 at 10:18am
There's no way I could cut holes for a stereo or speakers in the 72' Mustang so I opted for a JBL Bluetooth speaker. The thing is pretty loud and about the only time I ever listen to it is when we're anchored. It's worked well and most everyone has a playlist on their phone so let your friends/family play DJ and of course there is always Pandora . I prefer the HolmanMoody subwoofers myself underway!
