1984 Ski Natique Wheel Bearing |
Jabel1986
Newbie Joined: June-12-2016 Location: California Status: Offline Points: 2 |
Posted: June-12-2016 at 8:12pm |
I am new to the boating forum, I have a 1984 Ski Natique and today the wheel bearing burnt out and the grease fitting is gone. It looks like the wheel needs to replaced. I left the boat at a tire shop and was wondering if anyone knows the parts I will have to buy and where to buy them? I was also wondering if there is a different modern arrangement to instal instead of grease added seals? I was also wondering if anyone knows how to get a schematic of the 1984 correct craft trailer. Everything is original! The hub looks def cracked. The grease housing is gone. Any help will be greatly appreciated.
Jonny Quest
Grand Poobah Joined: August-20-2013 Location: Utah--via Texas Status: Offline Points: 2976 |
You will need to measure the axle spindles to be sure. Get a good micrometer or caliper. The diagram will show you the measurements to take. With those measurements, you can order the proper bearings, races and seals.
Image from etrailer.com JQ |
OldSchoolBlue84
Assuming it's an original trailer, below is what I used. Good luck
1984 Correct Craft Trailer #3 Trailer (single axle) Tires: 205/75D/14 - 5 Bolt (F78-14 or G78-14) Trailer Tongue: 3500 Gross Weight Spindle = #84 (1-3/8" inner, 1-1/16" outer) Inner Bearing = L68149 Inner Race = L44610 Inner Seal = 10-19 Outer Bearing = L44649 |
Kostas
1984 Ski Nautique 2001 |
Jonny Quest
OldSchool nailed it. Your axle most likely has a #84 spindle. You can do a search for "number 84 spindle" and get plenty of options. In my area, many of the local auto parts stores carry these bearings, races and seals. My personal preference is Made in the USA stuff. I've had some bad experiences with some cheap Asian bearings.
JQ |
