  New Posts New Posts RSS Feed - prop and prop shaft replacement
pinelake View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pinelake Quote  Post ReplyReply Direct Link To This Post Topic: prop and prop shaft replacement
    Posted: July-23-2006 at 4:50pm
Hi just bought a 82 2001. Last weekend we hit a rock, and deformed the prop. A friend tried straightening it and now its beyond repair. He did say the shaft was slightly bent. Is it hard to remove and replace the prop shaft? any instructions would be appreiciated. It is just every marine engineer is working in France for the next month, and i spent money I didn't have to buy the boat. Still best buy I ever made. thanks for reading hope some one can help
GottaSki View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GottaSki Quote  Post ReplyReply Direct Link To This Post Posted: July-23-2006 at 5:40pm
Slightly bent is like slightly pregnant..
Source your parts at skidim.com and you can't go wrong.
you need a prop-puller to start.
River Rat to Mole
Gonne929 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gonne929 Quote  Post ReplyReply Direct Link To This Post Posted: July-24-2006 at 7:46am
I agree with "GottaSki" the guys at skidim.com will take good care of you. I just replaced my 4 blade OJ to the 3 blade Acme #540 on my 84 2001. That prop will run awsome on your boat.
You are going to have to invest in a prop puller, unfortunately this will probably not be the only time you will have to use it.
If the shaft is bent you will have to replace that as well. The guys at Skidim.com will most likely know what you need but generally it is good to know when ordering 1) length 2) shaft diameter 3)coupler diameter and 4) single or double taper. You may have to invest in a puller for the shaft as well.
How is the strut? Was that damaged as well?
Post Options Post Options   Thanks (0) Thanks(0)   Quote pinelake Quote  Post ReplyReply Direct Link To This Post Posted: July-24-2006 at 9:38am
cheers for the advice. The strut is fine. A couple of friends say that the prop shaft can be straightened? I know that I will need to remove the rudder but is the shaft only held in place by the two screw type things where it meet the engine. I dont want to use brut force unless I know that there is nothing holding it in place. When I open the compartment behind the engine there is a brass fixing around the shaft and a silver case with a allan key fiting. Do any of these need loosening? sorry to be a pain as you can tell, I dont no much about boats.
Cheers
JoeinNY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeinNY Quote  Post ReplyReply Direct Link To This Post Posted: July-24-2006 at 9:50am
Sounds a bit like a Packless Shaft Seal or something similar, if packless it probably doesnt need to be loosened however you should be careful upon reinstall to not damage it. Don't know about the brass fitting, maybe post us a picture?
1983 Ski Nautique 2001
1967 Mustang 302 "Decoy"
Holeshot Video
79nautique View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79nautique Quote  Post ReplyReply Direct Link To This Post Posted: July-24-2006 at 9:59am
can you take any pictures? and post them? regardless if it is a packless seal or not you still have to disconnect it at the coupling where it meets the transmission and you may have to loosen the collar on the packless shaft seal to remove it and you will have to remove the coupler as well before you will be able to remove the shaft.
So to do the job you have to remove the rudder, remove the prop, unbolt the coupling from the transmission, remove the coupling from the shaft, lossen the stuffing box or collar to a dripless shaft seal then slide the shaft out of the boat. If the engine is removed then you don't have to remove the coupler from the shaft, but I'm assuming that the engine is still in.
David F View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David F Quote  Post ReplyReply Direct Link To This Post Posted: July-24-2006 at 11:16am
Since you need to replace the shaft (I advise against trying to have it straightened)and the prop, then you can forego the prop puller and just remove the shaft with the prop still attached. If you are going to have the prop repaired as a spare, then take the prop and shaft to the prop shop and they will remove the prop for you.
Maybe you are just talking about the safety collar on the shaft. If so, simply loosen the set screw and the collar will slide off the shaft as it is pulled from the boat. You will need to loosen the two set screws at the shaft hub, loosen the collar set screw, loosen the packing jamb nut and cap. Remove the rudder. Pull on the shaft or using a block of wood on the hub of the prop give it a blow with a hammer. Not too hard as you do not want to damage anything in the transmission such as a thrust bearing. If the shaft does not want to pull out of the hub, then you should seperate the hub from the tranny flange. Place a short socket of a diameter just smaller than the shaft between the hub and flange. Using longer bolts, slowly and equally pull the hub and flange back together. This will force the shaft out fo the hub. File off any burrs to the collar and packing nut will clear the shaft end.
PS: I am not familiar with dripless packing seals, so follow others advice related to the drippless packing.
stang72 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote stang72 Quote  Post ReplyReply Direct Link To This Post Posted: July-24-2006 at 12:31pm
Agree with the Acme 540 on your boat...my buddy tried mine and kept it...he ordered another for me and tried it this weekend (finally)...great improvement...smooth as butter and a real performer!
stang
The Super Air
Post Options Post Options   Thanks (0) Thanks(0)   Quote GottaSki Quote  Post ReplyReply Direct Link To This Post Posted: July-24-2006 at 1:00pm
Caution, I have seen the flange warp easily using the "press out the shaft using the bolts and a socket" method, it took remarkable little torque to cause the damage and its impossible to align the engine afterward. Warp just a few thousanths, then coupling is then junk.
I'm not saying its impossible, but it would have to be only modestly stuck and done with discipline.
River Rat to Mole
Post Options Post Options   Thanks (0) Thanks(0)   Quote David F Quote  Post ReplyReply Direct Link To This Post Posted: July-24-2006 at 1:04pm
Good word of caution, I did not think of that possibility. So, I suggest you just snug up the bolts and then firmly tap the hub with a hammer to setup a vibration that will hopefully help "break" the shaft free from the hub.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79nautique Quote  Post ReplyReply Direct Link To This Post Posted: July-24-2006 at 1:10pm
that would work fine if it was a tapered shaft but most orgnial shaft are not tapered and beating on it is going to do nothing but damage.
Disconnect the coupling from the output shaft/flange, remove the set screws from the coupling then use a puller to remove the coupling from the shaft then remove the shaft from the hull.
Munday View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Munday Quote  Post ReplyReply Direct Link To This Post Posted: July-24-2006 at 1:17pm
I use an axle puller.With a little rig I built.
Just slide hammer it straight out the back.
Works very well on double tapered shafts too.
My caution is for when you replace these parts.
Be sure your set bolts are well indexed,I've seen plenty that came right out in Reverse.
goodluck Munday
Post Options Post Options   Thanks (0) Thanks(0)   Quote David F Quote  Post ReplyReply Direct Link To This Post Posted: July-24-2006 at 1:32pm
Pure hogwash. Putting pressure or tension on a stuck part and then setting up a vibration frequently allows the part to "break" free. You will notice I said firmly tap, not beat on it. Sheesh!
Of course a puller will work, but not everyone has a puller. And, the tapping works with pullers as well.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79nautique Quote  Post ReplyReply Direct Link To This Post Posted: July-24-2006 at 1:49pm
doesn't work when a keyway is involved, since the keyway takes out most if not all of the slop created by misalignment and size between the coupler and shaft. Hammering fixs everthing for someone that doesn't know what they are doing or one that doesn't care to do the job right.
Post Options Post Options   Thanks (0) Thanks(0)   Quote David F Quote  Post ReplyReply Direct Link To This Post Posted: July-24-2006 at 2:36pm
Craig:
Give it a try, if you wish. 79Nautique is a purist and often disagrees with techniques and tricks of the trade that do not fit within his purist ideals. The "hammering" may not work, but often does. You may find tha that shaft comes out of the hub easily...usaully does.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79nautique Quote  Post ReplyReply Direct Link To This Post Posted: July-24-2006 at 2:55pm
far from a purist just hate when people give bullsh*t advice and use a hammer more than their brain or the proper tools.
There is no excuse for using the wrong tools for the job especially in todays world when 99% of the tools needed for the job can be barrowed/rented/bought from the local automotive parts store to do the job right and not have to worry about some jerry riging bullsh*t contraption that just tears sh*t up and makes things worse.
Post Options Post Options   Thanks (0) Thanks(0)   Quote David F Quote  Post ReplyReply Direct Link To This Post Posted: July-24-2006 at 3:12pm
Sigh!
Jim_In_Houston View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim_In_Houston Quote  Post ReplyReply Direct Link To This Post Posted: July-27-2006 at 2:20am
Man, ya'll sure know how to break in a newbie. (Let him ask me how to do it - I'll tell him to get a torch fired up and burn through the shaft - no hammering or coupler warping there!)
The Dude View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote The Dude Quote  Post ReplyReply Direct Link To This Post Posted: July-27-2006 at 9:25am
After all this, I'm guessing when he loosens things up the shaft will uncontrolably slide out of the hull and he'll wonder what everyone was talking about!
Mullet Free since 93
95 Sport
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeinNY Quote  Post ReplyReply Direct Link To This Post Posted: July-27-2006 at 9:29am
I was thinking the same thing, I have never even needed to use a prop puller a good firm pull and I always end up on my back holding a prop.
Holeshot Video
Post Options Post Options   Thanks (0) Thanks(0)   Quote pinelake Quote  Post ReplyReply Direct Link To This Post Posted: July-30-2006 at 9:41am
Big thankyou to everyone. U guys gave me the confidence to have a go and it came of easy. will be bothering you when the new parts arrive, but i will try everything in reverse first cheers
Boat virgin.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim_In_Houston Quote  Post ReplyReply Direct Link To This Post Posted: July-31-2006 at 10:06pm
Awsome! It wasn't that long ago that I got my CC and I didn't know squat until I found this site. Now I do know squat. Pretty soon you'll know squat too!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote GottaSki Quote  Post ReplyReply Direct Link To This Post Posted: July-31-2006 at 10:15pm
Yup, we don't mind sharing squat.
River Rat to Mole
PNALEWAJK View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote PNALEWAJK Quote  Post ReplyReply Direct Link To This Post Posted: September-12-2013 at 7:38pm
Hey Guys,
Mind if I jump in..? I have a couple of related questions.
First, my grandson hit some rocks with my '87 Ski Nautique. I wasn't with him, so I don't know how hard it hit. I'm sure there is damage to the prop, but again not sure how much. I only took a short test drive afterwards. I could only feel a slight vibration at about 4K. I do however feel a stronger vibration in reverse at maybe 1k. I'm hoping it's just prop damage, and something that can be repaired. What do you think?
The second part of my question is I know very little about these props and should I need to replace it, what would be the best bet. I've seen references to Acme 540 and 542, but don't know what makes them different. We primarily use the boat for tubing and sking.
Any suggestions will be appreciated.
Pete
Corvette Pete
dwouncmd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dwouncmd Quote  Post ReplyReply Direct Link To This Post Posted: September-12-2013 at 9:28pm
Wow, resurrecting an old post. You can use a dial gauge to check deflection of the shaft with the gauge clamped to the strut. There should be no more than .003 inch deflection. Check aft of the strut (most likely place to bend) and forward of the strut. It is also possible for the strut to get bent.
There are many other posts to help. I actually think Google is a little better than site's search feature.
I am not the prop guy, but the ACME CNC props will outperform the original equipment, and I think the 540 is the one, but I will defer to the experts. The old one can be reconditioned as a spare (Delta props has done two of mine).
Hope that helps.
89 SN
<a href="http://www.correctcraftfan.com/diaries/details.asp?ID=6567&sort=&pagenum=1" rel="nofollow">7
Post Options Post Options   Thanks (0) Thanks(0)   Quote PNALEWAJK Quote  Post ReplyReply Direct Link To This Post Posted: September-13-2013 at 11:58am
Thanks. I guess I should have started a new post. I actually found this post on Google, but I didn't look at the date.
Corvette Pete
ChowHound View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ChowHound Quote  Post ReplyReply Direct Link To This Post Posted: September-16-2013 at 9:57pm
-deleted - saw date/resurection
