  New Posts New Posts RSS Feed - pos. to pos.: neg. to ????
curbsidegold View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote curbsidegold Quote  Post ReplyReply Direct Link To This Post Topic: pos. to pos.: neg. to ????
    Posted: June-01-2004 at 2:53am
OK ... I don't get this. I have been pouring over the wiring diagram to my Greymarine 4 -75 and one thing doesn't make sense ... Does the negative terminal on the battery attach to a bolt on the engine housing to complete a circuit when the starter is turned, or is the negative terminal on the battery supposed to be run directly to a grounding bar on the hull. Thanks.
sm
64 Skier View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 64 Skier Quote  Post ReplyReply Direct Link To This Post Posted: June-02-2004 at 8:31am
Grounding to the engine is the best. Grounding to the hull and then to the engine is OK...if that's what your talking about.
I burned a "Field" wire and had a very tough time trouble shooting an old Ford before I found out the engine ground was loose.
Good Luck
64 Skier
66" HO VTX and 67" HO Triumph
71CC
