  New Posts New Posts RSS Feed - Starting problem
Starting problem
leftseat88 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote leftseat88 Quote  Post ReplyReply Direct Link To This Post Topic: Starting problem
    Posted: June-13-2019 at 9:47pm
96 sport with efi.
Turned the key to start and nothing happened. Heard the fuel pump engage but didn’t start. Tried again, nothing. Third time a charm, fired right away as it always does. This was the second time this has happened. Both times it started on the third attempt. Before I go and start replacing parts “Willy Nilly”, what should I look at first? Ignition switch? Starter? Relay? I wouldn’t call myself mechanically inclined so speak slowly !!!!
Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: June-13-2019 at 9:51pm
Jason,
The first thing to look at is the battery cable connections. Make sure they are clean and tight. Clean both wit a battery post/cable terminal cleaner. It has male and female wire brushes that do a great job.
Post Options Post Options   Thanks (0) Thanks(0)   Quote leftseat88 Quote  Post ReplyReply Direct Link To This Post Posted: June-13-2019 at 9:56pm
Battery connections are tight and clean.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: June-13-2019 at 10:00pm
Next when it happens again is to jiggle the throttle/shift to see if maybe the NSS (neutral safety switch) is open not allowing the start relay to energize. If that is the problem then a shift cable adjustment is needed.
Post Options Post Options   Thanks (0) Thanks(0)   Quote leftseat88 Quote  Post ReplyReply Direct Link To This Post Posted: June-13-2019 at 10:05pm
Sounds good thanks. There are 2 relays on the back of the motor. I believe that one maybe the the fuel pump relay, is the other one a start relay?
