  New Posts New Posts RSS Feed - hard to start after warm
heidntique View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote heidntique Quote  Post ReplyReply Direct Link To This Post Topic: hard to start after warm
    Posted: September-22-2006 at 3:43pm
i have a '84 nautique with about 775 hrs. it runs strong but this summer have had times where it won't start after running. basically, it won't start after being warm. after it cools for about 15-20 mins., it finally starts. replaced the points, condensor, carb rebuilt, coil replaced. any suggestions? thanks.
79nautique View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79nautique Quote  Post ReplyReply Direct Link To This Post Posted: September-22-2006 at 6:42pm
ditch the points and condensor and upgrade to a new dist or a conversions kit.
Cape Cod CC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Cape Cod CC Quote  Post ReplyReply Direct Link To This Post Posted: September-22-2006 at 9:47pm
Let me ask you a question, does this happen even if you try to start it right after you shut it off or does the engine need to sit for a few minutes before you have this problem?
The reason I ask is because I had a very similar problem with my 80 SN and it turned out to be a carb issue where a bad seal was letting gas drip into the manifold for a few minutes after the engine was shut off as it bled off pressure in the fuel line. So in effect the engine was getting flooded. If I started it right away I had no problem but if I let it set for 5 minutes or more it would not start. Then if I let it set for 25 minutes it would start again. Once I figured out what was going on I could start it if I treated it like it was flooded, wide open throttle until it started.
I know you had your carb rebuilt but this could still be a problem if it was not done correctly. Just one of the many possible causes…
Vince
Cape Cod
1980 SN
jimbo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jimbo Quote  Post ReplyReply Direct Link To This Post Posted: September-23-2006 at 2:01am
I'd ditch the points too. But I don't think that's the immediate problem...
My first thought was coil but since you had it replaced recently, I agree with Cape Cod.
I had the same problem a couple of years ago. I noticed an oily residue on the the intake; I tightened the carb/spacer/intake bolts down half a turn and the problem went away.
However, don't go torqueing bolts down ad hoc.   With the engine idling, spray a little carb clean around the intake and carb mounts. If the idle changes, then you have a leak. Some more brave souls than mine have took a draw on a cigar and blown the smoke over the manifold, watching for suction. The latter is more fun, I'm sure, especially in the case of a backfire.
nuttyskier2002 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nuttyskier2002 Quote  Post ReplyReply Direct Link To This Post Posted: September-23-2006 at 2:31am
I've seen a bad ballast resistor cause this ame problem.
Former boats:
88 Ski Centurion Tru Trac II
59 Chris Craft Capri (woody)
Jim_In_Houston View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim_In_Houston Quote  Post ReplyReply Direct Link To This Post Posted: September-23-2006 at 9:08am
Replacing the points with a electronic conversion is the very first thing to do.
In my endevor to keep my CC as original as possible I struggled with whether or not to get rid of the points. I decided on a compromise - I pulled out my points and saved them in a zip lock bag under my seat. I have since lost that bag and I hope I never see it again. So, what's the point? Throw away the points! There is just no other point. Do you get the point?
eric lavine View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote eric lavine Quote  Post ReplyReply Direct Link To This Post Posted: September-23-2006 at 10:52am
check all of what these guys said and sneak in a compression test also to be on the safe side its not that many hours but you never know. definitly get rid of the points. it seems that everytime an engine runs bad it always ends up being in the points.
boat dr View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote boat dr Quote  Post ReplyReply Direct Link To This Post Posted: September-24-2006 at 8:05pm
with the conversion kits so cheap and the installation so easy,why would anyone not replace or should i just agree with jim ditch the points,that way you can look someplace else for a problem....but look at what you would lose,hard start,poor idle and the constant adj. of dwell,and lubing the points cam(the little red pill)no brainer...... boat dr
bmiller View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bmiller Quote  Post ReplyReply Direct Link To This Post Posted: September-27-2006 at 11:02am
Had the same problem with my carb.Gas was dripping down the intake after I shut it off,It was flooding my 302 out.When you shut it off take the flame arestor off and see if thats what is happening.I had to adjust the floats.After I did that my boat starts all the time.Good luck.
79Tique View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79Tique Quote  Post ReplyReply Direct Link To This Post Posted: September-27-2006 at 3:46pm
I had a simular problem with my 302 in my 79 Ski Tique. The boat would always be hard to start after warming up had to give it full throtle and it would start because it ws flooded. I thought it was adjusted too rich because I live at higher elevation. I took the boat to the local auto mechanic and he said he adjusted and tightened somethings up. After that the problem went away.
Before that the boat started fine cold and hard when warm. Opsite now becaus I can't get the electronic choke to work for sh*t.
Work to live, not live to work.
Barracuda View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Barracuda Quote  Post ReplyReply Direct Link To This Post Posted: September-29-2006 at 10:42am
I have a similar problem..When the engine is warm and I go to restart it, I have to give a very small amount of throttle.
Just a quick little (1/16) of a pump on the throlle lever and it fires right up.
It would be nice to fix that..any thoughts guys? thanks
GottaSki View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GottaSki Quote  Post ReplyReply Direct Link To This Post Posted: September-30-2006 at 5:01pm
Barracuda
Set the air screws for best idle IN GEAR and that will go away. Its actually too lean to start, you are exposing more of the slots when you nudge the throttle. Off-idle performance will also improve, no stutter when you hammer it
If either air screw is not responsive, the idle circuit is clogged; most often the fuel orifice in the metering block, sometimes just the air bleed from belt shmutz.
If your timing is retarded, it overrules everythign above. 10 degrees initial is best.
River Rat to Mole
Post Options Post Options   Thanks (0) Thanks(0)   Quote Barracuda Quote  Post ReplyReply Direct Link To This Post Posted: October-02-2006 at 8:05am
Gotta- thanks for the tips. I'll check it all out before pulling it out for the season (end of this week).I don't have any performance problems at all- no stutter anytime, doesn't miss a beat. The above is really just an annoyance.
Thanks again
-Brad
Post Options Post Options   Thanks (0) Thanks(0)   Quote heidntique Quote  Post ReplyReply Direct Link To This Post Posted: October-21-2006 at 5:43pm
i replaced the resistor and only ran it once after that, but it seemed to fix the problem. thanks for the advice from everybody. i get the feeling i should upgrade to hei ignition...when Dan H. sees this, here's your reminder that you need to get back to work! -Rick
stang72 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote stang72 Quote  Post ReplyReply Direct Link To This Post Posted: October-21-2006 at 8:01pm
Glad it did OK! Yes...do ditch the points! You will be eliminating one element that is often a source of problem! For about $120.00 and a half hour of time...you will have one less worry! I like making things better!
stang
The Super Air
