BRASS PLUG HELP |
Revilo ![]() Newbie ![]() Joined: December-16-2019 Location: Seattle Status: Offline Points: 11 |
![]() ![]() ![]() ![]() ![]() Posted: April-13-2020 at 2:25pm |
I bought an 88 SN2001. It came with these brass plugs removed and in a plastic bag. Could someone please help me and tell me where they go. I am trying to get the boat ready for water.
Thank you in advance. ![]() |
The two big ones A&B will be the exhaust manifolds. A is not OEM Then C&D will be the block drains. One on the port side towards the aft and then the starboard side forward. E is the hull garboard drain. Look under the engine towards the forward end.
great! Thank you! And are they removed as part of winterizing?
Oliver,
There should be another small 1/8" NPT plug that goes on the "J" tube on the front of the engine. The tube is between the circulation pump and the T stat housing. |
Sounds like you don't have an engine manual. Take a look in the sites reference section and copy it if you can. |
KENO ![]() Grand Poobah ![]() Joined: June-06-2004 Location: United States Status: Offline Points: 11189 |
Pete, you need to check your glasses, they're making things look smaller than actual. ![]() That plug is 1/4 inch NPT |
