Pitot tubing |
AlfaDon
Senior Member Joined: September-18-2011 Location: San Leandro, Ca Status: Offline Points: 407 |
Posted: October-01-2020 at 11:59am |
Hi all,
The speedo's on my 96 176 aren't working very well, specifically they're reading low and take a few minutes to come up at all. I've got new Faria senders at the stern, and have checked the connections at both ends of the tubing. I suspect the tubing is bad, but they're both reading equally low. My old guy tendency is to find natural rubber, but I wonder if vinyl with last longer? Any other suggestions for getting them to be more accurate? They're probably 15 mph low? Thanks, Don
Jonny Quest
Grand Poobah Joined: August-20-2013 Location: Utah--via Texas Status: Offline Points: 2995 |
That sounds like a clog or partial clog to me. What I have done the past is to remove the Speedo tubing from the speedometer end and then carefully and gently, blow compressed air backwards through the Speedo line back to the pitot pick up. The I buy a GPS speedometer so I don’t have to worry about it...
