Need advice please Keno |
Post Reply | Page 12> |
Tko87
Groupie Joined: June-19-2012 Location: Louisiana Status: Offline Points: 59 |
Posted: March-21-2021 at 6:41pm |
Just put a used Gen 4 454 in my fish nautique the engine had only 90 hours on it from brand new ,guy didn't use it much
I'm running raw water When I start my boat 70-75 lbs of oil pressure even after it warms up it only drops down to 55 when I'm on step it goes back up to around 75 even once the oil is hot... Hooked up a manual gauge to confirm as well. Boat is running perfectly fine Is this anything to worry about? |
Grand Poobah Joined: June-06-2004 Location: United States Status: Offline Points: 11118 |
What weight oil are you using? Maybe the relief valve on the oil pump is set a little higher than normal. After it's warmed up and been running at speed for 20 minutes or so and the oil is good and hot, does it drop off any? I think that if the boat is running perfectly fine as you said, I'd not worry about it. Some others should chime in on this, I would think.
Tko87
Straight 40
Drops to 55 at idle when hot but on step it gets 70-75 If this isn't too high I won't stress about it I definitely don't have any leaks or nothing like that |
MrMcD
Grand Poobah Joined: January-28-2014 Location: Folsom, CA Status: Offline Points: 3750 |
Smokey Yanuck always said you need 10 PSI per 1000 RPM. Smokey is still considered a pretty good egg when it comes to engine advice.
With that said, I like to build mine to have 40 PSI minimum at idle and 60 or so at speed. Just personal preference. Running 75 PSI in an engine that never see's RPM above 4500 is a little overkill but as Ken pointed out it is nothing to worry about. It will not hurt your engine at all. If it was my engine and I had 75 PSI with 40W I would install 30W. Pressure will drop a little, maybe to 65 PSI hot but again, you have plenty of Oil Pressure so your engine will run a very long time. Most likely your engine has very good/tight clearances inside and that will make it last a long time if you take care of it. I know of race engines running Pro Stock that run Zero Weight oil today. You are in good shape, run it and smile. I know guys in the old C2 Corvette club and they get all excited if they have more than 40 PSI running hot because the C2 Club will dock them points when the car is judged. Not because there is anything wrong with running a little higher pressure, only because they use a judging book that tells them what oil pressure to look for because that is what they had from the factory in 1966. Does not mean it is the best for today it just means it is good for judging. Hope this helps. Mark
Tko87
Man, thanks for the details , feeling much better already .
I just knew MrMcD would come drop in from the west coast with some more good info for you
BTW I'm not sure if you have an earlier Mark4 or a later Gen5 or Gen6 because Chevy never called any of their 454s a Gen4
Tko87
Gen 4
U guys are awesome |
do you mean Mark4?
Tko87
Yes sorry Mark 4
I was only wondering because the later engines used thinner oil with some tighter engine clearances but your Mark4 with hydraulic flat tappet lifters/cam should be pretty happy with something like Rotella 15w40 Diesel oil with decent zinc(ZDDP) levels
How much zinc is really needed is one of them things plenty of people have plenty of opinions about, but the Rotella mentioned above has plenty in most everybody's opinion
Tko87
I've always taken your recommendations. What's your opinion on straight 30w
I guess my opinion is that i don't have one on the 30 weight without knowing the brand, but I kinda like the Rotella mentioned previously.
Amazing how modern engines have progressed- 10 years ago BMW F1 engines were turning 19k, oil pressures ranging around 10 pounds. The wife’s newish cars oil pressure I have never seen go over 20 lbs hot or cold. It uses 0-40 oil and the pumps output is controlled by the ECM. I have also heard in Ford Windsor applications that a standard oil pump is preferred.
MrMcD
I agree 100% on Rotella, Delo is also available, both are HD Diesel oils. They work well protecting the older flat tappet camshafts, I’ve run it for nearing 20 years now. I think I saw Rotella 10-30 at Walmart.
The only negative I ever saw from high oil pressure was one guy in cold country blew his oil filter off on a cold morning start, temp was around zero, car sat out all night and he had a high volume high pressure pump installed. Those pumps used a big block pump body adapted to run in a small block Chevy.
Tko87
Thank u for your input
SNobsessed
Another factor not mentioned yet is that oi flow takes heat away from the bearings. So if 30W gets you the oil pressure you need, then that would flow more oil & theoretically carry away more heat.,
Tko87
Okay guys, couldn't wait to get home and conduct more experiments. I drained the oil and put 10w30 rotella with a manual gauge
cranked it up and it was 75 lb I let it idle for about 20 minutes and it came down to 70 If I idle it up to about 1700 for about 5 seconds it will jump up to about 85 Then back down to 70 at idle a little more info, my oil sending unit is up right by the oil filter with the relocation housing. There is a 90° elbow coming out and the oil sending unit screws into that 90° elbow.... A friend of mine (lol) told me to move the oil sending unit down by the old oil filter housing. They're now is my oil temperature sender.. If it matters my oil when running it this weekend really didn't get over 150 degrees it was a cold day in louisiana, raw water pump , and 65° water as well It's possible that my temperature sender is not working correctly And this is your nightly update. Thank you very much |
Sounds like a newscast Keep em' coming I think in warmer conditions your pressure will come down some with warmer oil and harder running.
Tko87
Lol
MrMcD
I hate to even suggest it but oil pressure that high might indicate the relief valve in the oil pump is stuck. I expected more of a drop with lighter oil. You still won't hurt the engine bearings, they like lots of oil. Some of the excess from the connecting rods might end up on the cylinder walls but if it is not burning oil that indicates your oil rings are good and can handle it so don't worry. Maybe the previous owner installed a very strong spring on the oil pump by pass because he wanted high oil pressure.
Tko87
Does not burn oil and runs so very good . Going to take her on a longer test drive this weekend with warmer weather in the 80's
Can a "stuck" relief valve free up? Also I assume moving the oil sending unit away from the 90 at the relocation kit filter down to the old oil filter housing would not accomplish anything. |
63 Skier
Grand Poobah Joined: October-06-2006 Location: Concord, NH Status: Offline Points: 4269 |
I agree that the high pressure shouldn't cause problems. But, 85 psi is pretty unusual so like you, I wish I knew what was causing it. The other 99 times out of 100 the person posting about their 454 would be saying "I only have 15 psi at idle, 30 running hard, what should I do?" so your situation is a bit unusual. Having said that, I'd run it and enjoy it and see if it changes with warmer weather and hours of run time.
MrMcD
The by pass in your GM oil pump is a piston floating in a cylinder, oil pressure on one side and a spring on the other side in the cylinder. When the pressure is too high the piston will compress the spring and as it moves it opens a by pass channel which allows the excess oil pressure to dump so it keeps a steady oil pressure in the engine. I have been told that a good oil pump will be opening the bypass at any RPM over 500 in a tight engine because they produce more oil pressure than you need. To answer your question about can it fix itself, remote chance but not likely. If some particle is stuck in that cylinder and the piston is wedged against it odds are it will not fix itself. It is possible the previous owner liked high oil pressure and installed a high pressure spring in that pump. I would not sweat it. If someone comments about your very high oil pressure just tell them you like a tight engine, they last a long time!
Tko87
Amen to that again thanks for the very detailed answers
Tko87
Is it okay if I relocate my oil pressure sending unit away from the oil filter itself that comes with the bypass kit and move it down to the bottom of the engine where the stock oil filter was.
One of the reasons I'm asking it is a tight fit there where it's at. I'm sure if this will affect the readings or not |
MrMcD
Oil pressure should remain exactly the same as long as you are tapped into the oil gallery. The ports just open an access into the gallery.
Tko87
Like mentioned I'd put it back in the stock location and expect no problems at all because of the move.
Tko87
You guys are too Notch !!!
Tko87
Thank you
