  New Posts New Posts RSS Feed - Filling hull holes
Filling hull holes
Netdewt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Netdewt Quote  Post ReplyReply Direct Link To This Post Topic: Filling hull holes
    Posted: July-18-2021 at 9:39pm
I changed one of my speedos to a GPS unit, so I removed the pitot for it. It had been hacked on at some point. This doesn’t have to be super graceful. I filled the pitot holes with marine tex. Should I do the same for the tube? It’s much bigger so I’m not sure if it will fill.
For some reason there are no options in my post to add a picture.
1989 Ski Nautique 2001, 940 hours
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jonny Quest Quote  Post ReplyReply Direct Link To This Post Posted: July-18-2021 at 10:52pm
3M 5200 marine sealant.
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: July-19-2021 at 6:16am
If you're filling the 3 screw holes with marine tex, why not use the marine tex to fill the hole where the tubing passes through the transom ?
It'll fill that hole
