  New Posts New Posts RSS Feed - Dies at idle
Dies at idle
adamo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote adamo Quote  Post ReplyReply Direct Link To This Post Topic: Dies at idle
    Posted: August-30-2021 at 10:19am
I have a 83 southwind with a 351. The boat runs Awsome until it is run pretty hard for about 20-30 min. It runs good above 1000 rpms and accelerates and everything well. The problem is at idle and mainly at idle speeds when in gear. It wants to miss a beat and die. It will start back up no problem, don’t even have to give it gas. But as soon as I put it back in gear it tries to die. It does not do thst until it’s been driven a while then just gets worse and worse the longer I drive it but at higher speeds it does perfectly. I was wondering what could be happening to cause this? The motor runs right at 150-160 but I can feel the carb and air filter getting pretty hot and wonder if it’s getting to warm with the hood down. I feel it has to be a carb issue
SNobsessed View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SNobsessed Quote  Post ReplyReply Direct Link To This Post Posted: August-30-2021 at 6:00pm
Could be carb, could be ignition (like coil).  Check both systems.  Look down carb throat while it idles.  Dripping from venturis is bad.
Check spark for intensity (when problem is present).  Take a spare plug with you so you can just pull a wire to check.  Make sure you don't smell gas at this time . . .
